Updated on 2025-10-22 GMT+08:00
Component Overview
An application component implements a service feature of an application. It is in the form of code or software packages and can be deployed independently.
After creating an application on CAE, you can create components in the application.
Component Description
Table 1 lists the languages and runtime systems supported by CAE components.
Table 1 Supported languages and runtime systems
Runtime System
Component Source
Java 8, Java 11, Java 17, Java 21
Source code repository, JAR package
Tomcat 8, Tomcat 9
Source code repository, WAR package
Node.js 8, Node.js 14, Node.js 16
Source code repository, ZIP package
PHP 7, PHP 8
Docker
Image package
Python 3
.net core
Component Source
Component Source
GitHub, GitCode, GitLab, and Bitbucket code can be identified.
If you use a private image to create your containerized application, upload the private image to the image repository. The following upload modes are supported:
  1. Upload the image package by Upload Through Client or Upload Through Page.
  2. Log in to the SWR console and upload the image to the image repository. For details, see Uploading an Image Through SWR Console.
CAE container-based deployment does not support images of the Arm architecture.
Software package
  1. Select the corresponding software package from the CodeArts software release repository. Upload the software package to the release repository in advance. For details, see Uploading Software Packages.
  2. Select the corresponding software package from OBS. Upload the software package to the OBS bucket in advance. For details, see Uploading an Object.
