Overview
Introduction
An instance is a purchased BMS. Different instance types provide different compute capabilities, storage, and network performance. You can select whichever type best meets your service requirements. After purchasing a BMS, you have full control over it, including startup, shutdown, and in-band management.
BMS Types
A BMS has x86 or Kunpeng CPUs. Huawei-developed high-performance physical servers with exclusive optimization algorithms provide a reliable hardware environment for all the BMSs. You can choose from different BMS flavors based on your service requirements.
- For more information, see Instance Family.
