Updated on 2026-01-13 GMT+08:00
Searching for Resources by Tag
After tags are added to resources, you can search for resources by tag using either of the following methods.
Filter Resources in the Resource List
On the BMS console, query BMSs by tag key and value.
  1. Log in to the BMS console.
  2. Click Search by Tag above the upper right corner of the BMS list to expand the search area.
  3. Enter the tag of the target BMS.
    Both the tag key and value are mandatory. If the tag key or value is matched, the system automatically displays the target BMSs.
  4. Click to add multiple tags.
    You can add multiple tags. The system will display BMSs that have all the tags.
  5. Click Search.
    The system searches for BMSs based on the specified tag keys and values.
Filter Resources on the TMS Console
  1. Log in to the TMS console.
  2. On the Resource Tags page, set the search criteria, including Region, Resource Type, and Resource Tag.
  3. Click Search.
    All the resources that meet the search criteria will be displayed in the Search Result area.
