Help Center/ Bare Metal Server/ User Guide/ Instances/ Installing Drivers and Toolkits/ Installing the NVIDIA GPU Driver and CUDA Toolkit on a P2 BMS
Updated on 2025-11-21 GMT+08:00
After a GPU-accelerated P2 BMS (using the physical.p2.large flavor) is created, the NVIDIA GPU driver and CUDA Toolkit must be installed on it for computing acceleration.
The procedure of installing the NVIDIA GPU driver and CUDA Toolkit varies depending on the OS.
CentOS 7.4
  1. Log in to the target BMS and run the following command to switch to user root:
    su root
  2. (Optional) If the gcc, gcc-c++, make, and kernel-devel dependency packages do not exist, run the following commands to install the gcc, gcc-c++, make, and kernel-devel tools:
    yum install gcc
    yum install gcc-c++
    yum install make
    yum install kernel-devel-`uname -r`
  3. (Optional) Add the Nouveau driver to the blacklist.
    If the Nouveau driver has been installed and loaded, perform the following operations to add the Nouveau driver to the blacklist to avoid conflicts:
    1. Add blacklist nouveau to the end of the /etc/modprobe.d/blacklist.conf file.
    2. Run the following commands to back up and reconstruct initramfs:
      mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r).img.bak
      dracut -v /boot/initramfs-$(uname -r).img $(uname -r)
    3. Run the reboot command to restart the BMS.
  4. (Optional) If the X service is running, run the systemctl set-default multi-user.target command and restart the BMS to enter multi-user mode.
  5. (Optional) Install the NVIDIA GPU driver.
    If you selected a specified version of NVIDIA GPU driver rather than a version contained in the CUDA Toolkit, perform this step.
    1. Download NVIDIA GPU driver installation package NVIDIA-Linux-x86_64-xxx.yy.run from https://www.nvidia.com/Download/index.aspx?lang=en, and upload this package to the /tmp directory on the BMS.
      Figure 1 Searching for the NVIDIA GPU driver package (CentOS 7.4)
    2. Run the following command to install the NVIDIA GPU driver:
      sh ./NVIDIA-Linux-x86_64-xxx.yy.run
    3. Run the following command to delete the installation package:
      rm -f NVIDIA-Linux-x86_64-xxx.yy.run
  6. Install the CUDA Toolkit.
    1. Download CUDA Toolkit installation package cuda_a.b.cc_xxx.yy_linux.run from https://developer.nvidia.com/cuda-downloads, and upload this package to the /tmp directory on the BMS.
    2. Run the following command to change the permission to the installation package:
      chmod +x cuda_a.b.cc_xxx.yy_linux.run
    3. Run the following command to install the CUDA Toolkit:
      ./cuda_a.b.cc_xxx.yy_linux.run --toolkit --samples --silent --override --tmpdir=/tmp/
    4. Run the following command to delete the installation package:
      rm -f cuda_a.b.cc_xxx.yy_linux.run
    5. Run the following commands to check whether the installation is successful:
      cd /usr/local/cuda/samples/1_Utilities/deviceQueryDrv/
      make
      ./deviceQueryDrv
      If the command output contains "Result = PASS", the CUDA Toolkit and the NVIDIA GPU driver have been installed successfully.
Ubuntu 16.04
    sudo root
  2. (Optional) If the gcc, g++, and make dependency packages do not exist, run the following commands to install the gcc, g++, and make tools:
    apt-get install gcc
    apt-get install g++
    apt-get install make
    1. Add the following information to the end of the /etc/modprobe.d/blacklist.conf file:
      blacklist nouveau
      options nouveau modeset=0
      sudo update-initramfs -u
    3. Run the sudo reboot command to restart the BMS.
      Figure 2 Searching for the NVIDIA GPU driver package (Ubuntu 16.04)
      make
      ./deviceQueryDrv
