Updated on 2026-01-13 GMT+08:00
Restarting a BMS
You can restart a BMS on the console.
Restarting a BMS will interrupt your services. Exercise caution when performing this operation.
The BMS must be in Running state.
  1. Log in to the BMS console.
  2. Locate the row that contains the target BMS, click More in the Operation column, and select Restart from the drop-down list. To restart multiple BMSs, select them and click Restart at the top of the BMS list.
  3. In the displayed dialog box, click Yes.
