Updated on 2026-07-02 GMT+08:00
Cloning an API
To improve API creation efficiency, you can clone an API with a custom name and path.
Policies bound to an API cannot be cloned and can only be manually bound to the new API.
You have created an API. If no API is available, create one by referring to Creating a REST API.
Cloning APIs
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > API Groups.
  2. Click a group name to go to the Group Information page.
  3. On the APIs tab, choose More > Clone.
  4. Set the API name and path based on the following table.
    Table 1 Parameters for API cloning
    API Name
    Enter an API name. It is recommended that you enter a name based on naming rules to facilitate search.
    Enter 3 to 255 characters, starting with a letter or digit. Use only letters, digits, and these special characters: -_./:()
    API Path
    Request path of the API. Enclose parameters in braces. For example, /a/{b}. Or use a plus sign (+) to implement prefix matching. For example, /a/{b+}.
    The path is case-sensitive.
  5. Click OK.
    If the cloned API is displayed in the navigation tree on the left, the cloning is successful.
Related Documents
After cloning an API, verify it by following the procedure in Debugging an API.
