Importing APIs through an API Design File
You can import Swagger and OpenAPI APIs to a new or existing API group on APIG. Before importing APIs, complete the extended definition of APIG.
Precautions
- The API group and API quotas in API Gateway are sufficient.
- If you use the title property in Swagger info and OpenAPI info to specify an API group name, the name of a new API group cannot be the same as that of an existing one.
- If a conflict exists when you import APIs, the former API is imported successfully and the latter API cannot be imported. For example, if two APIs with the same name or request path exist in the imported API definition, a success message is displayed for the first imported API, and a failure message is displayed for the API to be imported subsequently.
- If the definition of an API you are importing is the same as that of an existing API, you can overwrite the existing API or retain it. If you leave the existing API alone, the new API will not be imported.
- If Extended Definition Overwrite is selected, the extended definition items (access control and request throttling policies) of an imported API will overwrite the existing extended definition items with the same name.
- Imported APIs will not be automatically published in an environment. You can choose to publish them immediately or later.
- The load balance channel, SSL certificate, and credential of an API cannot be imported.
Importing an API Design File
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- APIs can be imported in the following path:
- In the navigation pane, choose API Management > API Groups. Choose Create API Group > Import API Design File.
- Choose API Management > APIs. Click Import APIs.
- Select an API file and click Open.
- Set the parameters according to the following table.
Table 1 Parameters for importing APIs Parameter
Import
Options:
- New group: Import APIs to a new API group. If you select this option, the system automatically creates an API group and imports the APIs into this group.
- Existing group: Import APIs to an existing API group. If you select this option, the system adds the APIs to the selected API group while retaining the existing APIs in the API group.
API group
Select an API group if you set Import to Existing group.
Basic Definition Overwrite
Determine whether to overwrite an existing API if the name of the API is the same as that of an imported API.
This parameter is available only if you set Import to Existing group.
If this option is selected, the extended definition items (access control and request throttling policies) of an imported API will overwrite the existing policies with the same name.
- (Optional) To configure the APIs, click Configure Global Settings.
- In the displayed dialog box, determine whether to publish the APIs now.
- Now: Publish the APIs in a specified environment now.
- Later: Publish the APIs later.
- Click OK. The APIs tab is displayed, showing the imported APIs.
You can also import APIs to APIG by referring to the following examples:
Importing an HTTP Backend Service API
Import the request parameter definition of an HTTP backend service API that uses the GET method and is accessed through IAM authentication.
Swagger example:
swagger: "2.0"
info:
title: "importHttpEndpoint10"
description: "import apis"
version: "1.0"
host: "api.account.com"
paths:
'/http/{userId}':
get:
operationId: "getUser3"
description: "get user by userId"
security:
- apig-auth-iam: []
schemes:
- https
parameters:
- name: "test"
description: "authorization token"
type: "string"
in: "header"
required: true
- name: "userId"
description: "user id"
type: "string"
in: "path"
required: true
responses:
"200":
description: "user information"
x-apigateway-request-type: "public"
x-apigateway-cors: true
x-apigateway-is-send-fg-body-base64: true
x-apigateway-match-mode: "NORMAL"
x-apigateway-backend:
type: "HTTP"
parameters:
- name: "userId"
value: "userId"
in: "query"
origin: "REQUEST"
- name: "X-Invoke-User"
value: "apigateway"
in: "header"
origin: "CONSTANT"
description: "invoke user"
httpEndpoints:
address: "example.com"
scheme: "http"
method: "GET"
path: "/users"
timeout: 30000
securityDefinitions:
apig-auth-app:
in: header
type: apiKey
x-apigateway-auth-type: AppSigv1
apig-auth-iam:
in: header
type: apiKey
x-apigateway-auth-type: IAM
OpenAPI example:
openapi: 3.0.0
info:
title: importHttpEndpoint10
version: '1.0'
servers:
- url: >-
http://abc.com
- url: >-
https://abc.com
paths:
'/http/{userId}':
get:
description: get user by userId
operationId: getUser3
parameters:
- description: authorization token
example: ''
in: header
required: true
schema:
maxLength: 0
maximum: 0
minimum: 0
type: string
x-apigateway-pass-through: always
- description: user id
example: ''
in: path
required: true
schema:
maxLength: 0
maximum: 0
minimum: 0
type: string
responses:
default-cors:
description: response example
x-apigateway-result-failure-sample: ''
x-apigateway-result-normal-sample: ''
security:
- apig-auth-iam: []
servers:
- url: >-
https://abc.com
httpEndpoints:
address: example.com
description: ''
enableClientSsl: false
method: GET
path: /users
retryCount: '-1'
scheme: http
timeout: 30000
parameters:
- description: invoke user
in: HEADER
origin: CONSTANT
value: apigateway
in: QUERY
origin: REQUEST
value: userId
type: HTTP
x-apigateway-match-mode: NORMAL
x-apigateway-request-type: public
x-apigateway-response: default
components:
responses:
default-cors:
headers:
Access-Control-Allow-Origin:
schema:
default: '*'
type: string
securitySchemes:
apig-auth-app:
in: header
type: apiKey
apig-auth-app-header:
in: header
type: apiKey
x-apigateway-auth-opt:
appcode-auth-type: header
apig-auth-iam:
in: header
type: apiKey
x-apigateway-responses:
default: {}
Importing an HTTP VPC Backend Service API
Import the request parameter definition of an HTTP VPC backend service API that uses the ANY method and is accessed through app authentication.
Swagger example:
swagger: "2.0"
info:
title: "importHttpVpcEndpoint"
version: "1.0"
paths:
'/http-vpc':
x-apigateway-any-method:
operationId: "userOperation"
description: "user operation resource"
security:
- apig-auth-app: []
schemes:
- https
parameters:
- name: "Authorization"
description: "authorization signature"
type: "string"
in: "header"
required: true
responses:
"default":
description: "endpoint response"
x-apigateway-match-mode: "SWA"
type: "HTTP-VPC"
parameters:
value: "apigateway"
in: "header"
origin: "CONSTANT"
httpVpcEndpoints:
scheme: "http"
method: "GET"
path: "/users"
timeout: 30000
apig-auth-app:
in: header
type: apiKey
apig-auth-iam:
in: header
type: apiKey
OpenAPI example:
openapi: 3.0.0
info:
description: import apis
title: importHttpVpcEndpoint
version: '1.0'
servers:
- url: >-
http://abc.com
- url: >-
https://abc.com
paths:
/http-vpc:
description: user operation resource
operationId: userOperation
parameters:
- description: authorization signature
example: ''
in: header
required: true
schema:
maxLength: 0
maximum: 0
minimum: 0
type: string
responses:
default-cors:
security:
- apig-auth-app: []
servers:
- url: >-
https://abc.com
httpVpcEndpoints:
cascade_flag: false
description: ''
method: GET
path: /users
retryCount: '-1'
scheme: http
timeout: 30000
parameters:
in: HEADER
origin: CONSTANT
value: apigateway
type: HTTP-VPC
x-apigateway-match-mode: SWA
components:
responses:
default-cors:
headers:
schema:
default: '*'
type: string
securitySchemes:
apig-auth-app:
in: header
type: apiKey
in: header
type: apiKey
apig-auth-iam:
in: header
type: apiKey
x-apigateway-responses: {}
Importing a Function Backend Service API
Import the request parameter definition of a FunctionGraph backend service API that uses the GET method and is accessed through IAM authentication.
Swagger example:
swagger: "2.0"
info:
title: "importFunctionEndpoint"
version: "1.0"
paths:
'/function/{name}':
get:
operationId: "invokeFunction"
description: "invoke function by name"
security:
- apig-auth-iam: []
schemes:
- https
parameters:
- name: "test"
type: "string"
in: "header"
required: true
- name: "name"
description: "function name"
type: "string"
in: "path"
required: true
responses:
"200":
description: "function result"
type: "FUNCTION"
parameters:
- name: "functionName"
value: "name"
in: "query"
origin: "REQUEST"
value: "apigateway"
in: "header"
origin: "CONSTANT"
functionEndpoints:
function-urn: "your function urn address"
version: "your function version"
invocation-type: "async"
timeout: 30000
apig-auth-app:
in: header
type: apiKey
apig-auth-iam:
in: header
type: apiKey
OpenAPI example:
openapi: 3.0.0
info:
version: '1.0'
servers:
- url: >-
http://api.account.com
- url: >-
https://api.account.com
paths:
/function/{name}:
get:
description: invoke function by name
operationId: invokeFunction
parameters:
- description: function name
in: path
required: true
schema:
maxLength: 0
maximum: 0
minimum: 0
type: string
example: ''
in: header
required: true
schema:
maxLength: 0
maximum: 0
minimum: 0
type: string
example: ''
responses:
default-cors:
security:
- apig-auth-iam: []
servers:
- url: >-
functionEndpoints:
alias-urn: ''
description: ''
invocation-type: async
network-type: V1
timeout: 30000
parameters:
in: HEADER
origin: CONSTANT
value: apigateway
in: QUERY
origin: REQUEST
value: name
type: FUNCTION
components:
responses:
default-cors:
headers:
schema:
default: '*'
type: string
securitySchemes:
apig-auth-app:
in: header
type: apiKey
apig-auth-iam:
in: header
type: apiKey
default: {}
Importing a Mock Backend Service API
Import the definition of a Mock backend service API that uses the GET method and is accessed without authentication.
Swagger example:
swagger: "2.0"
info:
title: "importMockEndpoint"
version: "1.0"
paths:
'/mock':
get:
operationId: "mock"
description: "mock test"
schemes:
- http
responses:
"200":
description: "mock result"
x-apigateway-request-type: "private"
type: "MOCK"
mockEndpoints:
result-content: "{\"message\": \"mocked\"}"
apig-auth-app:
in: header
type: apiKey
apig-auth-iam:
in: header
type: apiKey
OpenAPI example:
openapi: 3.0.0
info:
version: '1.0'
servers:
- url: >-
http://abc.com
- url: >-
https://abc.com
paths:
/mock:
get:
description: mock test
operationId: mock
responses:
default-cors:
servers:
- url: >-
http://abc.com
mockEndpoints:
description: ''
result-content: '{"message": "mocked"}'
type: MOCK
x-apigateway-request-type: private
components:
responses:
default-cors:
headers:
schema:
default: '*'
type: string
securitySchemes:
apig-auth-app:
in: header
type: apiKey
in: header
type: apiKey
apig-auth-iam:
in: header
type: apiKey
default: {}
Follow-Up Operations
Publish the imported APIs in an environment so that they can be called by users.
