CORS
For security purposes, the browser restricts cross-origin requests from being initiated from a page script. In this case, the page can access only the resources from the current domain. CORS allows the browser to send XMLHttpRequest to the server in a different domain. For details about CORS, see CORS Calling of an Open API.
The CORS plug-in provides the capabilities of specifying preflight request headers and response headers and automatically creating preflight request APIs for cross-origin API access.
- If this policy is not supported by your gateway, submit a service ticket to upgrade the gateway to the latest version.
- Policy parameters will be stored as plaintext. To prevent information leakage, do not contain sensitive information in these parameters.
- An API can be bound to only one CORS policy for a given environment, but each CORS policy can be bound to multiple APIs.
- APIs with the same request path in an API group can only be bound with the same CORS plug-in policy.
- If you have enabled CORS for an API and have also bound the CORS plug-in to the API, the CORS plug-in will be used.
- You cannot bind the CORS plug-in to APIs with the same request path as another API that uses the OPTIONS method.
- When you bind a plug-in policy to an API (see Binding the Policy to APIs), ensure that the request method of the API is included in allow_methods.
- Policies are independent of APIs. A policy takes effect for an API only after they are bound to each other. When binding a policy to an API, you must specify an environment where the API has been published. The policy takes effect for the API only in the specified environment.
- After you bind a policy to an API, unbind the policy from the API, or update the policy, you do not need to publish the API again.
- Taking an API offline does not affect the policies bound to it. The policies are still bound to the API if the API is published again.
- Policies that have been bound to APIs cannot be deleted.
Creating a CORS Policy
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Policies.
- On the Policies tab, click Create Policy.
- On the Select Policy Type page, select CORS in the Plug-ins area.
- Set the policy information based on the following table.
Table 1 CORS parameters Parameter
Name
Enter a policy name. Using naming rules facilitates future search.
It can contain 3 to 255 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
Type
Fixed as CORS.
Description about the CORS policy. Enter 1 to 255 characters.
Policy Content
Content of the plug-in, which can be configured in a form or using a script.
Allowed Origins
Access-Control-Allow-Origin response header, which specifies either a single origin, which tells browsers to allow that origin to access an API; or else — for requests without credentials — the "*" wildcard, to tell browsers to allow any origin to access the API. Separate multiple URIs using commas.
Allowed Methods
Access-Control-Allow-Methods response header, which specifies the HTTP methods allowed when accessing the API. Separate multiple methods using commas.
Allowed Headers
Access-Control-Allow-Headers response header, which specifies request headers that can be used when making an XMLHttpRequest. Separate multiple headers using commas.
By default, simple request headers Accept, Accept-Language, Content-Language, and Content-Type (only if the value is application/x-www-form-urlencoded, multipart/form-data, or text/plain) can be carried in requests. You do not need to configure these headers in this parameter.
NOTE:- When you create a CORS policy, Allowed Headers is blank by default, which means cross-origin requests cannot carry any custom headers.
- Setting Allowed Headers to an asterisk (*) means cross-origin requests can carry any custom headers.
Exposed Headers
Access-Control-Expose-Headers response header, which specifies which response headers can be contained in the response of XMLHttpRequest. Separate multiple headers using commas.
By default, basic response headers Cache-Control, Content-Language, Content-Type, Expires, Last-Modified, and Pragma can be contained in the response. You do not need to configure these headers in this parameter.
NOTE:- When you create a CORS policy, Exposed Headers is blank by default, which means the JavaScript code of a browser cannot parse the headers in a cross-origin access response. However, the following basic response headers obtained using the getResponseHeader() method of the XMLHttpRequest object are excluded: Cache-Control, Content-Language, Content-Type, Expires, Last-Modified, and Pragma.
- Setting Exposed Headers to an asterisk (*) means the JavaScript code of a browser can parse all the headers in a cross-origin access response.
Maximum Age
Access-Control-Max-Age response header, which specifies for how many seconds the results of a preflight request can be cached. No more preflight requests will be sent within the specified period.
Allow Credentials
Access-Control-Allow-Credentials response header, which specifies whether XMLHttpRequest requests can carry cookies.
- Click OK.
To clone this policy, click Clone in the Operation column. The name of a cloned policy cannot be the same as that of any existing policy.
- After the policy is created, perform the operations described in Binding the Policy to APIs to apply the policy for the API.
Example Script
"allow_origin": "*",
"allow_methods": "GET,POST,PUT",
"allow_headers": "Content-Type,Accept,Accept-Ranges,Cache-Control",
"expose_headers": "X-Request-Id,X-Apig-Latency",
"max_age": 86400,
"allow_credentials": true
- Click the policy name to go to the policy details page.
- Select an environment and click Select APIs.
- Select the API group, environment, and required APIs.
APIs can be filtered by API name or tag. The tag is defined during API creation.
- Click OK.
- If an API no longer needs this policy, click Unbind in the row that contains the API.
- If there are multiple APIs that no longer need this policy, select these APIs, and click Unbind above the API list. You can unbind a policy from a maximum of 1000 APIs at a time.
