On this page
Show all
Error Codes
Updated on 2023-05-06 GMT+08:00
Table 1 lists the error codes that you may encounter when calling APIs. If an error code starting with APIGW is returned after you call an API, rectify the fault by referring to the instructions provided in Error Codes.
  • For details about the error codes that may occur when you manage APIs, see Error Codes.
  • If an error occurs when you use APIG, find the error message and description in the following table according to the error code, for example, APIG.0101. The error messages are subject to change without prior notice.
Table 1 Error codes
Error Code
Error Message
HTTP Status Code
Solution
APIG.0101
The API does not exist or has not been published in the environment.
404
Check whether the domain name, method, and path are consistent with those of the registered API. Check whether the API has been published. If it has been published in a non-production environment, check whether the X-Stage header in the request is the environment name. Check whether the domain name used to call the API has been bound to the group to which the API belongs.
APIG.0101
The API does not exist.
404
The API request method does not exist.
Check whether the API request method is the same as the method defined by the API.
APIG.0103
The backend does not exist.
500
The backend service was not found.
Contact technical support.
APIG.0104
The plug-ins do not exist.
500
No plug-in configurations were found.
APIG.0105
The backend configurations do not exist.
500
No backend configurations were found.
APIG.0106
Orchestration error.
400
An orchestration error occurred.
Check whether the frontend and backend parameters of the API are correct.
APIG.0201
API request error.
400
Invalid request parameters.
Set valid request parameters.
APIG.0201
Request entity too large.
413
The request body exceeds 12 MB.
Reduce the size of the request body.
APIG.0201
Request URI too large.
414
The request URI exceeds 32 KB.
Reduce the size of the request URI.
APIG.0201
Request headers too large.
494
The request headers are too large because one of them exceeds 32 KB or the total length exceeds 128 KB.
Reduce the size of the request headers.
APIG.0201
Backend unavailable.
502
The backend service is unavailable.
Check whether the backend address configured for the API is accessible.
APIG.0201
Backend timeout.
504
The backend service has timed out.
Increase the timeout duration of the backend service or shorten the processing time.
APIG.0201
An unexpected error occurred
500
An internal error occurred.
APIG.0202
Backend unavailable
502
The backend is unavailable.
Check whether the backend request protocol configured for the API is the same as the request protocol used by the backend service.
APIG.0203
Backend timeout.
504
Increase the timeout of the backend service or shorten its processing time.
APIG.0204
SSL protocol is not supported: TLSv1.1
400
The SSL protocol version is not supported.
Use a supported SSL protocol version.
APIG.0301
Incorrect IAM authentication information.
401
The IAM authentication details are incorrect.
Check the token by referring to Common Errors Related to IAM Authentication Information.
APIG.0302
The IAM user is not authorized to access the API.
403
The IAM user is not allowed to access the API.
Check whether the user is controlled by a blacklist or whitelist.
APIG.0303
Incorrect app authentication information.
401
The app authentication details are incorrect.
Perform the following checks for app authentication:
  • Check whether the request method, path, query parameters, and request body are consistent with those used for signing.
  • Check whether the client time is correct.
Check whether the signing code is correct by referring to Calling APIs Through App Authentication.
In the case of AppCode-based simple authentication, check whether the request contains the X-Apig-AppCode header.
APIG.0304
The app is not authorized to access the API.
403
The app is not allowed to access the API.
Check whether the app has been authorized to access the API.
APIG.0305
Incorrect authentication information.
401
The authentication information is incorrect.
Check whether the authentication information is correct.
APIG.0306
API access denied.
403
Access to the API is not allowed.
Check whether you have been authorized to access the API.
APIG.0307
The token must be updated.
401
The token needs to be updated.
Obtain a new token from IAM.
APIG.0308
The throttling threshold has been reached.
429
Try again after the throttling resumes. If the number of subdomain requests per day is reached, bind an independent domain name to the API.
APIG.0310
The project is unavailable.
403
The project is currently unavailable.
Select another project and try again.
APIG.0311
Incorrect debugging authentication information.
401
The debugging authentication details are incorrect.
APIG.0401
Unknown client IP address.
403
The client IP address cannot be identified.
APIG.0402
The IP address is not authorized to access the API.
403
The IP address is not allowed to access the API.
Check whether the IP address is controlled by a blacklist or whitelist.
APIG.0404
Access to the backend IP address has been denied.
403
The backend IP address cannot be accessed.
Check whether the backend IP address or the IP address corresponding to the backend domain name is accessible.
APIG.0501
The app quota has been used up.
405
The app quota has been reached.
Increase the app quota.
APIG.0502
The app has been frozen.
405
Check whether your account balance is sufficient.
APIG.0601
Internal server error.
500
APIG.0602
Bad request.
400
Invalid request.
Check whether the request is valid.
APIG.0605
Domain name resolution failed.
500
Check whether the domain name is correct and has been bound to a correct backend address.
APIG.0606
Failed to load the API configurations.
500
API configurations could not be loaded.
APIG.0607
The following protocol is supported: {xxx}
400
The protocol is not supported. Only xxx is supported.
xxx is subject to the actual value in the response.
Use HTTP or HTTPS to access the API.
APIG.0608
Failed to obtain the admin token.
500
The tenant details cannot be obtained.
APIG.0609
The VPC backend does not exist.
500
The VPC backend service cannot be found.
APIG.0610
No backend available.
502
No backend services are available.
Check whether all backend services are available. For example, check whether the API calling information is consistent with the actual configuration.
APIG.0611
The backend port does not exist.
500
The backend port was not found.
APIG.0612
An API cannot call itself.
500
Modify the backend configurations, and ensure that the number of layers the API is recursively called does not exceed 10.
APIG.0613
The IAM service is currently unavailable.
503
IAM is currently unavailable.
APIG.0705
Backend signature calculation failed.
500
APIG.0802
The IAM user is forbidden in the currently selected region
403
The IAM user is disabled in the current region.
APIG.1009
AppKey or AppSecret is invalid
400
The AppKey or AppSecret is invalid.
Check whether the AppKey or AppSecret in the request is correct.
