- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Process of Using APIG
- Creating a User and Granting APIG Permissions
- Creating a Gateway
- Opening APIs
- (Optional) Configuring Authorization for API Calling
- Calling APIs
Managing APIs
- Viewing or Modifying API Information
- Configuring Custom API Authentication
- Configuring API Parameter Orchestration Rules
- Customizing Error Response for APIs
- Cloning an API
- Authorizing API Access
- Taking an API Offline
- Importing and Exporting APIs
API Design File Extension Definitions
- x-apigateway-auth-type
- x-apigateway-request-type
- x-apigateway-match-mode
- x-apigateway-cors
- x-apigateway-is-send-fg-body-base64
- x-apigateway-any-method
- x-apigateway-backend
- x-apigateway-backend.parameters
- x-apigateway-backend.httpEndpoints
- x-apigateway-backend.httpVpcEndpoints
- x-apigateway-backend.functionEndpoints
- x-apigateway-backend.mockEndpoints
- x-apigateway-backend-policies
- x-apigateway-backend-policies.conditions
- x-apigateway-ratelimit
- x-apigateway-ratelimits
- x-apigateway-ratelimits.policy
- x-apigateway-ratelimits.policy.special
- x-apigateway-access-control
- x-apigateway-access-controls
- x-apigateway-access-controls.policy
- x-apigateway-plugins
- Configuring API Policies
- Configuring a Credential Policy
- Managing APIG Gateways
- Viewing Metrics and Configuring Alarms
- Viewing Audit Logs
- Shared Gateway (for Existing Users)
Best Practices
- Overview
API Openness
- Selectively Exposing CCE Workloads with a Dedicated Gateway
- Selectively Exposing Service Capabilities of a Data Center Using a Dedicated Gateway
- Exposing Backend Services Across VPCs Using a Dedicated Gateway
- Routing gRPC Service Requests Using a Dedicated Gateway
- Forwarding WebSocket Service Requests Using a Dedicated Gateway
- HTTP-to-HTTPS Auto Redirection with a Dedicated Gateway
- Calling Different Backend Services Using a Dedicated Gateway
- API Authentication
- API Policies
- API Security
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
Dedicated Gateway APIs (V2)
- API Group Management
- Environment Management
- Environment Variable Management
- Request Throttling Policy Management
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API or Taking an API Offline
- Querying API Details
- Querying APIs
- Verifying the API Definition
- Debugging an API
- Publishing APIs or Taking APIs Offline
- Querying Historical Versions of an API
- Switching the Version of an API
- Querying the Runtime Definition of an API
- Querying API Version Details
- Taking an API Version Offline
- Signature Key Management
- Binding/Unbinding Signature Keys
- Binding/Unbinding Request Throttling Policies
- Excluded Request Throttling Configuration
- App Authorization Management
- Resource Query
- Domain Name Management
- Access Control Policy Management
- Binding/Unbinding Access Control Policies
- Custom Authorizer Management
- API Import and Export
VPC Channel Management
- Creating a VPC Channel
- Updating a VPC Channel
- Deleting a VPC Channel
- Querying VPC Channel Details
- Querying VPC Channels
- Adding or Updating Backend Instances
- Querying Backend Servers of a VPC Channel
- Updating Backend Instances
- Removing a Backend Server
- Enabling Backend Servers
- Disabling Backend Servers
- Modifying VPC Channel Health Check
- Adding or Updating a Backend Server Group of a VPC Channel
- Querying Backend Server Groups of a VPC Channel
- Querying a Backend Server Group of a VPC Channel
- Deleting a Backend Server Group of a VPC Channel
- Updating a Backend Server Group of a VPC Channel
- Monitoring Information Query
- Group Response Management
- Tag Management
- Gateway Feature Management
- Configuration Management
Gateway Management
- Creating a Dedicated Gateway (Pay-Per-Use)
- Querying Dedicated Gateway Details
- Updating a Dedicated Gateway
- Querying the Creation Progress of a Dedicated Gateway
- Updating or Binding an EIP to a Dedicated Gateway
- Unbinding the EIP of a Dedicated Gateway
- Enabling Public Access for a Dedicated Gateway
- Updating the Outbound Access Bandwidth of a Dedicated Gateway
- Disabling Public Access for a Dedicated Gateway
- Enabling Public Inbound Access
- Updating Public Inbound Access Bandwidth of a Gateway
- Disabling Public Inbound Access for a Gateway
- Querying AZs
- Querying Dedicated Gateways
- Deleting a Dedicated Gateway
- Modifying the Specifications of a Pay-Per-Use Gateway
- Querying Gateway Constraints
- VPC Endpoint Management
- Gateway Tag Management
- Microservice Center Management
SSL Certificate Management
- Querying SSL Certificates
- Creating an SSL Certificate
- Binding a Domain Name with SSL Certificates
- Unbinding a Domain Name's SSL Certificates
- Querying Certificate Details
- Deleting an SSL Certificate
- Modifying an SSL Certificate
- Binding an SSL Certificate to a Domain Name
- Unbinding an SSL Certificate from a Domain Name
- Querying Domain Names of an SSL Certificate
Plug-in Management
- Creating a Plug-in
- Modifying a Plug-in
- Deleting a Plug-in
- Querying Plug-ins
- Querying Plug-in Details
- Binding a Plug-in to APIs
- Binding an API with Plug-ins
- Unbinding a Plug-in from All APIs
- Unbinding an API's Plug-ins
- Querying APIs Bound with a Plug-in
- Querying Plug-ins Bound to an API
- Querying APIs to Which a Plug-in Can Be Bound
- Querying Plug-ins That Can Be Bound to an API
Credential Management
- Creating an App
- Modifying an App
- Deleting an App
- Resetting the AppSecret of an App
- Verifying an App
- Querying App Details
- Querying Apps
- Creating an AppCode
- Generating an AppCode
- Deleting an AppCode
- Querying AppCode Details
- Querying AppCodes of an App
- Querying Quotas Associated with a Credential
- Configuring Access Control Settings for an App
- Querying Access Control Details About an App
- Deleting Access Control Settings of an App
Credential Quota Management
- Creating a Credential Quota
- Querying Credential Quota Details
- Querying Credential Quotas
- Modifying a Credential Quota
- Deleting a Credential Quota
- Querying the Credentials Bound to a Specified Quota
- Binding a Credential Quota with Credentials
- Unbinding a Credential Quota from a Credential
- Querying Credentials That Can Be Bound to a Credential Quota
- Asynchronous Task Management
- Orchestration Rule Management
- Gateway Custom Inbound Port Management
Shared Gateway APIs (for Existing Users)
API Management
- Object Model
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API
- Publishing Multiple APIs or Taking Multiple APIs Offline
- Querying an API List
- Querying Historical API Versions
- Taking an Effective Version of an API Offline
- Querying Details of an API Version
- Debugging an API
- App Management
- Binding Request Throttling Policies
Binding Access Control Policies
- Object Model
- Binding an Access Control Policy to an API
- Querying the List of Access Control Policies Bound to an API
- Querying the List of APIs Bound to an Access Control Policy
- Querying the List of APIs Not Bound to an Access Control Policy
- Unbinding an Access Control Policy from an API
- Unbinding Multiple Access Control Policies from APIs
- Querying Subscription Information in KooGallery
- Resource Query
- Binding Signature Keys
- VPC Channel Management
- Querying Metrics
- OpenAPI
- Appendix
- Change History
- SDK Reference
- Common FAQs
- Product Consulting FAQs
Opening APIs
- Why Can't I Create APIs?
- How Do I Define Response Codes for an API?
- Can I Specify a Private Network Load Balancer Address for the Backend Service?
- Can I Specify the Backend Address as a Subnet IP Address?
- Does APIG Support Multiple Backend Endpoints?
- Can I Bind Private Domain Names for API Access?
- Why Do I Fail to Call an API Across Domains?
- How Do I Use APIG to Open Up Services Deployed on Huawei Cloud?
- Publishing an API
Calling APIs
- What Are the Possible Causes for an API Calling Failure?
- Why Am I Seeing the Error Message "414 Request URI too large" When I Call an API?
- Why Am I Seeing the Error Message "The API does not exist or has not been published in the environment" When I Call an API?
- Why Am I Seeing the Error Message "No backend available" When I Call an API?
- Why Am I Seeing the Error Message "Backend unavailable" or "Backend timeout" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Backend domain name resolution failed" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Incorrect IAM authentication information" When I Call an API?
- Why Am I Seeing the Error Message "Incorrect app authentication information" When I Call an API?
- Why Doesn't Modification of the backend_timeout Parameter Take Effect?
- Does APIG Have a Limit on the Size of the API Request Body?
- Is There a Limit on the Size of the Response to an API Request?
- How Do I Call an API Using App Authentication in iOS System?
- Why Can't I Create a Header Parameter Named x-auth-token for an API Called Through IAM Authentication?
- Can Mobile Apps Call APIs?
- Can Applications Deployed in a VPC Call APIs?
- Does APIG Support WebSocket Data Transmission?
- How Will the Requests for an API with Multiple Backend Policies Be Matched and Executed?
- How Can I Access Backend Services over Public Networks Through APIG?
API Policies
- Can I Configure the Maximum Number of Concurrent Requests?
- Is the Restriction of 1,000 Requests Per Day to a Debugging Domain Name Applied to Enterprise Accounts?
- Does APIG Have Bandwidth Limits?
- Why Doesn't a Request Throttling Policy Take Effect?
- How Do I Provide an Open API to Specific Users?
- Are Client IP Addresses Verified for Access Control?
- Videos
More Documents
- Getting Started
- Comparing Versions
- Overview
API Management
- Creating an API Group
- Creating an Environment Variable
- Creating a Gateway Response
- Creating an API
- Cloning an API
- CORS
- Debugging an API
- Publishing an API
Importing and Exorting APIs
- Restrictions and Compatibility
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- Monitoring & Analysis
- Gateway Management
- SDKs
- Published API Calling
- Permissions Management
- Auditing
- Common FAQs
API Creation
- How Do I Specify the Host Port for a VPC Channel (or Load Balance Channel)?
- How Do I Set the Backend Address If I Will Not Use a VPC Channel (or Load Balance Channel)?
- How Can I Configure the Backend Service Address?
- What Should I Do After Applying for an Independent Domain Name?
- Why Does an API Failed to Be Called Across Domains?
API Calling
- What Should I Do If an Error Code Is Returned During API Calling?
- What Should I Do If "The API does not exist or has not been published in the environment." Is Displayed?
- Why Am I Seeing the Message "No backend available"?
- What Are the Possible Causes If the Message "Backend unavailable" or "Backend timeout" Is Displayed?
- Why Am I Seeing the Message "Backend domain name resolution failed" When a Backend Service Is Called?
- How Do I Switch the Environment for API Calling?
- What Is the Maximum Size of an API Request Package?
- How Do I Perform App Authentication in iOS System?
- App (Credential) FAQs
- Does APIG Support Persistent Connections?
API Authentication
- Does APIG Support HTTPS Two-Way Authentication?
- How Do I Call an API That Does Not Require Authentication?
- Which TLS Versions Does APIG Support?
- Does APIG Support Custom Authentication?
- Will the Request Body Be Signed for Security Authentication?
- Common Errors Related to IAM Authentication Information
- What Should I Do If the App Authentication Information Is Incorrect?
- API Control Policies
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (Kuala Lumpur Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- This API is used to creat a credential quota.
- Appendix
- Change History
- Getting Started
- Overview
API Management
- Importing a CCE Workload
- Creating an API
- Creating a gRPC API
- Cloning an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- SDKs
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- Appendix
- Change History
Best Practices (ME-Abu Dhabi Region)
- Developing a Custom Authorizer with FunctionGraph
- Interconnecting a Dedicated Gateway with WAF
- Request Throttling 2.0 with a Dedicated Gateway
- Two-Factor Authentication with a Dedicated Gateway
- Client Authentication with a Dedicated Gateway
- Invoking an API Policy Backend via Frontend Authentication Parameters (System Parameter)
- Forwarding WebSocket Services Using Dedicated Gateway
- Change History
- User Guide (Paris Region)
- Developer Guide (Paris Region)
API Reference (Paris Region)
- Before You Start
- Calling APIs
- Getting Started
Shared Gateway APIs
API Management
- Object Model
- Registering an API
- Modifying an API
- Deleting an API
- Publishing an API
- Debugging an API
- App Management
- Object Model
- Querying Subscription Information in the Marketplace
- Resource Query
- OpenAPI
- Appendix
- Change History
Dedicated API Gateway User Guide (Paris Region)
- Getting Started
- Overview
API Management
- Creating an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- API Policies
- Credentials
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Dedicated API Gateway Developer Guide (Paris Region)
Dedicated API Gateway API Reference (Paris Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- App Management
- Tag Management
Gateway Management
- Querying AZs
- Appendix
- Change History
On this page
Show all
