Adding an SQL Inspection
You can add rules for specified tenants and SQL engines on FusionInsight Manager. The system will display hints on, intercept, or block SQL requests matched by the rules.
Exercise caution when you add or modify a SQL inspection rule for a cluster, enable a rule, and set the threshold. An improper rule may cause upper-layer service interruption.
Adding a Rule
- Log in to FusionInsight Manager as a user with the Manager administrator rights.
- Click Cluster and choose SQL Inspector. The SQL Inspector page is displayed.
You can click View Supported Rules to view all SQL inspection rules supported by the current cluster.
- Click Add Rule. After the password of the current user is verified, the Add Rule page is displayed.
- Set the required parameters and click OK.
Name
Name of a SQL inspection rule
ID
Rule ID
For details about meaning of the rules corresponding to the IDs, see Table 1.
Tenant
Click Add to select the name of the tenant to which the current rule will be associated.
If you need to add a new tenant, plan and create a cluster tenant by referring to Tenant Resources.
Services and Actions
Click Add to specify the SQL engine to which this rule will be associated with and set the threshold parameters of the rule.
Each rule can be associated with one SQL engine. If you want to configure a rule for other SQL engines, add new rules.
- Service: Select the SQL engine associated with the current rule.
- If an SQL request meets the rule, the system performs the following operations:
- Hint: Record logs and display a hint for handling the SQL request. If the rule has parameters, you need to configure the threshold.
- Intercept: Intercept the SQL request that meets the rule. If the rule has parameters, you need to configure the threshold.
- Block: Block the SQL request that meets the rule. If the rule has parameters, you need to configure the threshold.
For static and dynamic interception rules, Hint and Block operations are supported. For blocking rules, only the Block operation is supported.
- View the added prevention rule on the SQL Defense page. The rule takes effect dynamically.
To adjust the current rule, click Modify in the Operation column of the row that contains the target rule. After the user password is verified, you can modify rule parameters.
Figure 1 Viewing SQL inspection rules
MRS SQL Inspection Rules
ID |
Description |
Engine |
Threshold |
Example SQL Statement |
static_0001 |
Check whether the number of occurrences of count(distinct) in the SQL statement exceeds the limit. |
Number of occurrences of count(distinct) Recommended value: 10 |
SELECT COUNT(DISTINCT deviceId), COUNT(DISTINCT collDeviceId) FROM table GROUP BY deviceName, collDeviceName, collCurrentVersion; |
static_0002 |
Check whether the not in <subquery> statement is used in the SQL statement. |
N/A |
SELECT * FROM Orders o WHERE Orders.Order_ID not in (Select Order_ID FROM HeldOrders h where h.order_id = o.order_id); |
static_0003 |
Check whether the number of joins in the SQL statement exceeds the limit. |
Number of joins Recommended value: 20 |
N/A |
static_0004 |
Check whether the number of union all times in the SQL statement exceeds the limit. |
Number of union all times Recommended value: 20 |
select * from tables t1 union all select * from tables t2 union all select * from tables t3 union all select * from tables t4 union all select * from tables t5 union all select * from tables t6 union all select * from tables t7 union all select * from tables t8 union all select * from tables t9; |
static_0005 |
The number of subquery nesting layers exceeds the limit. |
Maximum number of nested subqueries Recommended value: 20 |
select * from ( with temp1 as (select * from tables) select * from temp1); |
static_0006 |
Check whether the length of the SQL statement string exceeds the upper limit. |
Length of the SQL string, in KB Recommended value: 10 |
N/A |
static_0007 |
Check whether the Cartesian product exists when multiple tables are associated. |
N/A |
select * from A,B; |
static_0008 |
Check whether alter table update operation is performed at the cluster level (on cluster). |
ClickHouse |
N/A |
alter table testtb1 on cluster default_cluster update price=10.0 where id='100' |
static_0009 |
Check whether alter table delete operation is performed at the cluster level (on cluster). |
ClickHouse |
N/A |
alter table testtb1 on cluster default_cluster delete where id ='10' |
static_0010 |
Check whether the alter table add column operation is performed at the cluster level (on cluster). |
ClickHouse |
N/A |
alter table testtb1 on cluster default_cluster add column testc String |
static_0011 |
Check whether the alter table drop column operation is performed at the cluster level (on cluster). |
ClickHouse |
N/A |
alter table testtb1 on cluster default_cluster drop column testc |
static_0012 |
Check whether the optimize final operation is performed at the cluster level (on cluster). |
ClickHouse |
N/A |
optimize table testtb1 on cluster default_cluster final |
static_0013 |
Check whether drop operations are performed at the cluster level (on cluster). |
ClickHouse |
N/A |
drop table/database test on cluster default_cluster; |
static_0014 |
Check whether the truncate table operation is performed at the cluster level (on cluster). |
ClickHouse |
N/A |
truncate table testtb1 on cluster default_cluster; |
dynamic_0001 |
Check whether the number of scanned files exceeds the limit. |
Number of files that will be scanned or have been scanned Recommended value: 100,000 |
SELECT ss_ticket_number FROM store_sales WHERE ss_ticket_number=72291252 LIMIT 10; |
dynamic_0002 |
Check whether the number of partitions involved in operations (select, delete, update, and alter) on a table exceeds the upper limit. |
Number of partitions involved in the delete or alter operation Recommended value: 10,000 |
DELETE FROM table_name WHERE column_name = value |
dynamic_0003 |
When the right table of a join is a distributed table, check whether the data volume of the right table exceeds the upper limit. |
ClickHouse |
Number of rows in the right table when the join operation is performed. Recommended value: 100,000,000 |
SELECT name, text FROM table_1 JOIN table_2 ON table_1.Id = table_2.Id |
running_0001 |
Check whether the number of result rows returned by the Select statement to the client exceeds the upper limit. |
Number of rows in the query result Recommended value: 100,000 |
select * from table |
running_0002 |
Check whether the peak memory usage of the SQL statement exceeds the absolute value limit. |
Memory occupied by SQL running, in MB |
N/A |
running_0003 |
Check whether the running duration of the SQL statement exceeds the upper limit. |
SQL running duration threshold, in seconds |
N/A |
running_0004 |
The amount of data scanned by the SQL statements. |
Amount of data scanned by the SQL statement, in GB Recommended value: 10,240 |
N/A |
