User Account List
User Classification
There are three types of users available in MRS clusters. Do not use the default passwords. Change the passwords periodically.
   This section describes the default users in the MRS cluster.
        User Type  |
        Description  |
        System users  |
        Internal system users  |
        Internal user to perform Kerberos authentication, process communications, save user group information, and associate user permissions. It is recommended that internal system users not be used in O&M scenarios. Operations can be performed as user admin or another user created by the system administrator based on service requirements.  |
        Database users  |
System Users
   - User root of the OS is required, the password of user root on all nodes must be the same.
 - User ldap of the OS is required. Do not delete this account. Otherwise, the cluster may not work properly. The OS administrator maintains the password management policies.
        User Type  |
        Username  |
        Description  |
        Password Change Method  |
        System administrator  |
        admin  |
        FusionInsight Manager administrator.
         By default, user admin does not have the management permission on other components. For example, when accessing the native UI of a component, the user fails to access the complete component information due to insufficient management permission on the component.  |
        For details, see Changing the Password for User admin.  |
        Node OS user  |
        ommdba  |
        User that creates the system database. This user is an OS user generated on the management node and does not require a unified password. This account cannot be used for remote login.  |
        For details, see Changing the Password for an OS User.  |
        omm  |
        Internal running user of the system. This user is an OS user generated on all nodes and does not require a unified password.  |
Internal System Users
        User Type  |
        Default User  |
        Description  |
        Kerberos administrator  |
        kadmin/admin  |
        Used to add, delete, modify, and query user accounts on Kerberos.  |
        For details, see Changing the Password for the Kerberos Administrator.  |
        OMS Kerberos administrator  |
        kadmin/admin  |
        Used to add, delete, modify, and query user accounts on OMS Kerberos.  |
        For details, see Changing the Password for the OMS Kerberos Administrator.  |
        LDAP administrator  |
        cn=root,dc=hadoop,dc=com  |
        Used to add, delete, modify, and query the user account information on LDAP.  |
        For details, see Modifying OMS Service Configuration Parameters.  |
        OMS LDAP administrator  |
        Used to add, delete, modify, and query the user account information on OMS LDAP.  |
        LDAP user  |
        cn=pg_search_dn,ou=Users,dc=hadoop,dc=com  |
        Used to query information about users and user groups on LDAP.  |
        OMS LDAP user  |
        Used to query information about users and user groups on OMS LDAP.  |
        LDAP administrator account  |
        cn=krbkdc,ou=Users,dc=hadoop,dc=com  |
        Used to query Kerberos component authentication account information.  |
        cn=krbadmin,ou=Users,dc=hadoop,dc=com  |
        Used to add, delete, modify, and query Kerberos component authentication account information.  |
        Component running user  |
        iotdb  |
        This user is the IoTDB system administrator and has the following user permissions:
        For details, see Changing the Password for a Component Running User.  |
        hdfs  |
        This user is the HDFS system administrator and has the following permissions:
        hbase  |
        This user is the HBase and HBase1 to HBase4 system administrator and has the following permissions:
        mapred  |
        This user is the MapReduce/Yarn system administrator and has the following permissions:
        zookeeper  |
        This user is the ZooKeeper system administrator and has the following permissions:
        solr  |
        This user has the Solr system management permissions and user permissions:
        Elasticsearch  |
        This user has the Elasticsearch system management permissions and user permissions:
        rangerkms  |
        RangerKMS system administrator  |
        rangeradmin  |
        This user has the Ranger system management permissions and user permissions:
        rangerauditor  |
        Default audit user of the Ranger system.  |
        hive  |
        This user is the Hive system administrator and has the following permissions:
        hive1  |
        This user is the Hive1 system administrator and has the following permissions:
        hive2  |
        This user is the Hive2 system administrator and has the following permissions:
        hive3  |
        This user is the Hive3 system administrator and has the following permissions:
        hive4  |
        This user is the Hive4 system administrator and has the following permissions:
        kafka  |
        This user is the Kafka system administrator and has the following permissions:
        cdl  |
        CDL system administrator Currently, user permissions are not involved in CDL.  |
        rangerusersync  |
        Synchronizes users and internal users of user groups.  |
        rangertagsync  |
        Internal user for synchronizing tags.  |
        oms/manager  |
        Controller and NodeAgent authentication user. The user has the permission on the supergroup group.  |
        backup/manager  |
        User for running backup and restoration tasks. The user has the permission on the supergroup, wheel, and ficommon groups. After cross-system mutual trust is configured, the user has the permission to access data in the HDFS, HBase, Hive, and ZooKeeper systems.  |
        hdfs/hadoop.<System domain name>  |
        This user is used to start the HDFS and has the following permissions:
        hetuserver/hadoop.<System domain name>  |
        This user is used to start HetuEngine and has the following permissions:
        mapred/hadoop.<System domain name>  |
        This user is used to start the MapReduce and has the following permissions:
        mr_zk/hadoop.<System domain name>  |
        Used for MapReduce to access ZooKeeper.  |
        hbase/hadoop.<System domain name>  |
        User for the authentication between internal components during the HBase system startup.  |
        hbase/zkclient.<System domain name>  |
        User for HBase to perform ZooKeeper authentication in a security mode cluster.  |
        thrift/hadoop.<System domain name>  |
        ThriftServer system startup user.  |
        rangerkms/hadoop.<System domain name>  |
        RangerKMS system startup user  |
        rest/hadoop.<System domain name>  |
        RestServer system startup user.  |
        thrift/<hostname>  |
        User for the ThriftServer system to access HBase. This user has the read, write, execution, creation, and administration permission on all NameSpaces and tables of HBase. <hostname> indicates the name of the host where the ThriftServer node is installed in the cluster.  |
        hive/hadoop.<System domain name>  |
        User for the authentication between internal components during the Hive system startup. The user permissions are as follows:
        hive1/hadoop.<System domain name>  |
        User for the authentication between internal components during the Hive1 system startup. The user permissions are as follows:
        hive2/hadoop.<System domain name>  |
        User for the authentication between internal components during the Hive2 system startup. The user permissions are as follows:
        hive3/hadoop.<System domain name>  |
        User for the authentication between internal components during the Hive3 system startup. The user permissions are as follows:
        hive4/hadoop.<System domain name>  |
        User for the authentication between internal components during the Hive4 system startup. The user permissions are as follows:
        loader/hadoop.<System domain name>  |
        User for Loader system startup and Kerberos authentication  |
        HTTP/<hostname>  |
        Used to connect to the HTTP interface of each component. <hostname> indicates the host name of a node in the cluster.  |
        hue  |
        User for Hue system startup, Kerberos authentication, and HDFS and Hive access  |
        flume  |
        User for Flume system startup and HDFS and Kafka access. The user has read and write permission of the HDFS directory /flume.  |
        flume_server  |
        ftpserver  |
        FTP-Server system startup user.  |
        metadata/hadoop.<System domain name>  |
        Metadata system startup user who can access Hive and HBase metadata.  |
        spark_zk/hadoop.<System domain name>  |
        Used for Spark to access ZooKeeper.  |
        spark2x/hadoop.<System domain name>  |
        This user is the Spark system administrator and has the following user permissions: 1. Starts the Spark service. 2. Submits Spark tasks.  |
        spark2x1/hadoop.<System domain name>  |
        This user is the Spark1 system administrator and has the following user permissions:
        spark2x2/hadoop.<System domain name>  |
        This user is the Spark2 system administrator and has the following user permissions:
        spark2x3/hadoop.<System domain name>  |
        This user is the Spark3 system administrator and has the following user permissions:
        spark2x4/hadoop.<System domain name>  |
        This user is the Spark4 system administrator and has the following user permissions:
        zookeeper/hadoop.<System domain name>  |
        ZooKeeper system startup user.  |
        zkcli/hadoop.<System domain name>  |
        ZooKeeper server login user.  |
        oozie  |
        User for Oozie system startup and Kerberos authentication.  |
        solr/hadoop.<System domain name>  |
        elasticsearch/hadoop.<System domain name>  |
        Used to access the ZooKeeper data directory. The user can access all the files in the /elasticsearch directory in ZooKeeper and has the read and write permission of all the files in the directory.  |
        HTTP/<hostname>  |
        Used to perform Kerberos authentication on the HTTP service of Solr.  |
        HTTP/SOLR_FLOAT_IP  |
        kafka/hadoop.<System domain name>  |
        Used for security authentication of Kafka.  |
        redisCli  |
        Redis system administrator  |
        redis/hadoop.<System domain name>  |
        Redis system startup user  |
        flink/hadoop.<System domain name>  |
        Internal user of the Flink service.  |
        check_ker_M  |
        User who performs a system internal test about whether the Kerberos service is normal.  |
        tez  |
        User for TezUI system startup, Kerberos authentication, and access to Yarn  |
        cdl/hadoop.<System domain name>  |
        Internal user of the CDL service.  |
        rangeradmin/hadoop.<System domain name>  |
        Ranger system startup user, which is used for authentication between internal components.  |
        clickhouse/hadoop.<System domain name>  |
        Used for security authentication of ClickHouse. This user is an internal user and can be used only in the cluster.  |
        default  |
        ClickHouse internal user, which is an administrator user that can be used only in non-security mode.  |
        For details, see "Configuring the Password of the Default Account of a ClickHouse Cluster" in .  |
        K/M  |
        Kerberos internal functional user. It cannot be deleted, and its password cannot be changed. This internal account can only be used on nodes where Kerberos service is installed.  |
        None  |
        kadmin/changepw  |
        kadmin/history  |
        krbtgt<System domain name>  |
        root  |
        Used in Doris internally to initialize the doris_manager user.  |
        None  |
        admin  |
        Doris internal user of common clusters  |
        After you can connect to Doris as user admin, run SET PASSWORD = PASSWORD('password'); to change the password. Commands carrying authentication passwords pose security risks. Disable historical command recording before running such commands to prevent information leakage.  |
        doris_manager  |
        Used in Doris internally to add instance, users, and roles  |
        None  |
        doris  |
        Doris internal user, which is used by Hive Catalog to access other components when Kerberos authentication is enabled for the cluster (the cluster is in security mode).  |
        None  |
        doris/hadoop.<System domain name>  |
        None  |
        rangerobs/hadoop.<System domain name>  |
        System administrator used by Guardian to access Ranger  |
        jobserver  |
        This user is the JobGateway system administrator and has the following permissions:
        HTTP/_HOST  |
        Internal user of the JobGateway service, which is used for Kerberos authentication of the HTTP service  |
        LDAP user  |
        admin  |
        FusionInsight Manager administrator. The primary group is compcommon, which does not have the group permission but has the permission of the Manager_administrator role.  |
        The LDAP user cannot log in to the system, and the password cannot be changed.  |
        backup  |
        The primary group is compcommon.  |
        backup/manager  |
        oms  |
        oms/manager  |
        clientregister  |
        zookeeper  |
        The primary group is hadoop.  |
        zkcli  |
        flume  |
        flume_server  |
        ftpserver  |
        The primary group is supergroup.  |
        hdfs  |
        mapred  |
        mr_zk  |
        hue  |
        hive  |
        The primary group is hive.  |
        hive1  |
        The primary group is hive1.  |
        hive2  |
        The primary group is hive2.  |
        hive3  |
        The primary group is hive3.  |
        hive4  |
        The primary group is hive4.  |
        hbase  |
        thrift  |
        oozie  |
        loader  |
        spark2x  |
        spark2x1  |
        spark2x2  |
        spark2x3  |
        spark2x4  |
        metadata  |
        kafka  |
        The primary group is kafkaadmin.  |
        cdl  |
        The primary group is cdladmin.  |
        redisCli  |
        redis  |
        solr  |
        The primary group is ficommon.  |
        Elasticsearch  |
        rangeradmin  |
        rangerusersync  |
        rangertagsync  |
        rangerauditor  |
        kms/hadoop  |
        The primary group is kmsadmin.  |
        knox  |
        executor  |
        doris  |
        LDAP user  |
        jobserver  |
   Log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain. In the preceding table, all letters in the system domain name contained in the username of the system internal user are lowercase letters.
For example, if Local Domain is set to 9427068F-6EFA-4833-B43E-60CB641E5B6C.COM, the username of default HDFS startup user is hdfs/hadoop.9427068f-6efa-4833-b43e-60cb641e5b6c.com.
Database Users
The system database users include OMS database users and DBService database users.
        Database Type  |
        Default User  |
        Description  |
        OMS database  |
        ommdba  |
        OMS database administrator who performs maintenance operations, such as creating, starting, and stopping.  |
        For details, see Changing the Password of the OMS Database Administrator.  |
        omm  |
        User for accessing OMS database data  |
        For details, see Changing the Password for the Data Access User of the OMS Database.  |
        DBService database  |
        omm  |
        Administrator of the GaussDB database in the DBService component  |
        For details, see Resetting the Password for User omm in DBService.  |
        compdbuser  |
        Administrator of the GaussDB database in the DBService component. It is used in service O&M scenarios. If the password of this account has expired, you need to reset the password upon your first login.  |
        For details, see Changing the Password for User compdbuser of the DBService Database.  |
        hetu  |
        User for HetuEngine to connect to the DBService database hetumeta.  |
        For details, see Resetting the Component Database User Password.  |
        hive  |
        User for Hive to connect to the DBService database hivemeta.  |
        hive1  |
        User for Hive1 to connect to the DBService database hivemeta1.  |
        hive2  |
        User for Hive2 to connect to the DBService database hivemeta2.  |
        hive3  |
        User for Hive3 to connect to the DBService database hivemeta3.  |
        hive4  |
        User for Hive4 to connect to the DBService database hivemeta4.  |
        hiveNN  |
        User for Hive-N to connect to the DBService database hiveNmeta when multiple services are installed. For example, the user for Hive-1 to connect to the DBService database hive1meta is hive11.  |
        hue  |
        User for Hue to connect to the DBService database hue.  |
        sqoop  |
        User for Loader to connect to the DBService database sqoop.  |
        sqoopN  |
        User for Loader-N to connect to the DBService database sqoopN when multiple services are installed. For example, the user for Loader-1 to connect to the DBService database sqoop1 is sqoop1.  |
        metadata  |
        User for Metadata to connect to the DBService database metadata.  |
        metadataN  |
        User for Metadata-N to connect to the DBService database metadataN when multiple services are installed. For example, the user for Metadata-1 to connect to the DBService database metadata1 is metadata1.  |
        oozie  |
        User for Oozie to connect to the DBService database oozie.  |
        oozieN  |
        User for Oozie-N to connect to the DBService database oozieN when multiple services are installed. For example, the user for Oozie-1 to connect to the DBService database oozie1 is oozie1.  |
        redis  |
        User for Redis to connect to the DBService database redismeta.  |
        rangeradmin  |
        User for Ranger to connect to the DBService database ranger.  |
        kafkauiN  |
        User for Kafka UI to connect to the DBService database kafkaui.  |
        flink  |
        User for Flink to connect to the DBService database flink.  |
        cdl  |
        User for CDL to connect to the DBService database cdl.  |
        activiti  |
        User for Containers to connect to the DBService database activitidb.  |
        rtd  |
        User for RTDService to connect to the DBService database rtdmeta.  |
        lakesearch  |
        User for LakeSearch to connect to the DBService database lakesearch.  |
        jobgateway  |
        User for JobGateway to connect to the DBService database jobmeta.  |
        MOTService database  |
        omm  |
        Administrator of the database in the MOTService component  |
        Contact the system administrator to obtain the password.  |
