Help Center/
MapReduce Service/
User Guide (Ankara Region)/
FusionInsight Manager Operation Guide/
Tenant Resources/
Using the Superior Scheduler/
Managing Resources/
Modifying a Resource Pool
Updated on 2024-11-29 GMT+08:00
When hosts in a resource pool need to be adjusted based on service requirements, you can modify members in the resource pool on FusionInsight Manager.
- Choose .
- In the resource pool list, locate the row containing the specified resource pool, and click Modify in the Operation column.
- In the Resource area, modify hosts.
- Adding hosts: Select desired hosts in Available Hosts and click
to add them to the resource pool.
- Deleting hosts: Select desired hosts in Selected Hosts and click
to remove them from the resource pool. The host list in the resource pool can be left blank.
- Click OK.
Parent topic: Managing Resources
