Configuring the Alarm Masking Status
If you do not want FusionInsight Manager to report specified alarms in the following scenarios, you can manually mask the alarms.
- Some unimportant alarms and minor alarms need to be masked.
 - When a third-party product is integrated with MRS, some alarms of the product are duplicated with the alarms of MRS and need to be masked.
 - When the deployment environment is special, certain alarms may be falsely reported and need to be masked.
After an alarm is masked, new alarms with the same ID as the alarm are neither displayed on the Alarm page nor counted. The reported alarms are still displayed.
 - Choose O&M > Alarm > Masking Setting.
 - In the Masking Setting area, select the specified service or module.
 - Select an alarm from the alarm list.
    Figure 1 Masking an alarm
    The information about the alarm is displayed, including the alarm name, ID, severity, masking status, and operations can be performed on the alarm.- The masking status includes Display and Masking.
 - Operations include Masking and Help.
      You can filter specified alarms based on the masking status and alarm severity.
 - Set the masking status for an alarm:
- Click Masking. In the displayed dialog box, click OK to change the alarm masking status to Masking.
 - Click Cancel Masking. In the dialog box that is displayed, click OK to change the masking status of the alarm to Display.
