Trend
Log in to FusionInsight Manager and choose Hosts > Resource Overview. Click Trend to view resource trends of the cluster. By default, the monitoring data of the past one hour (1h) is displayed. You can click
to customize a time range. Time range options are 1h, 2h, 6h, 12h, 1d, 1w, and 1m. By default, the trend chart of each metric displays the maximum, minimum, and average values of the entire cluster.
- You can click Add Host to Chart to add trend lines of up to 12 hosts to the trend charts.
- You can choose
> Customize to customize the metrics to display on the tab page. For details about the metrics, see Table 1 in Distribution. - You can click Export Data to export the maximum, minimum, and average values of all nodes in the cluster for all selected metrics within the time range you have specified.
