Cloud Native Cluster Monitoring
Updated on 2024-12-18 GMT+08:00
Introduction
Cloud Native Cluster Monitoring (kube-prometheus-stack) uses Prometheus-operator and Prometheus to provide easy-to-use, end-to-end Kubernetes cluster monitoring.
Open source community: https://github.com/prometheus/prometheus
Notes and Constraints
  • By default, the kube-state-metrics component of the add-on does not collect labels and annotations of Kubernetes resources. To collect these labels and annotations, manually enable the collection function in the startup parameters and check whether the corresponding metrics are added to the collection trustlist of ServiceMonitor named kube-state-metrics. For details, see Collecting All Labels and Annotations of a Pod.
  • In 3.8.0 and later versions, component metrics in the kube-system and monitoring namespaces are not collected by default. If you have workloads in the two namespaces, use Pod Monitor or Service Monitor to collect these metrics.
  • In 3.8.0 and later versions, etcd-server, kube-controller, kube-scheduler, autoscaler, fluent-bit, volcano-agent, volcano-scheduler and otel-collector metrics are not collected by default. Enable the collection as required.
    To enable this function, on the ConfigMaps and Secrets page, expand the dropdown list of Namespace, and select monitoring. Locate the row that contains the configuration item named persistent-user-config, and click Edit YAML in the operation column. Remove the serviceMonitorDisable or podMonitorDisable configuration in the customSettings field as required or set the configuration to an empty array.
       customSettings:
          podMonitorDisable: []
          serviceMonitorDisable: []
Permissions
The node-exporter component of the Cloud Native Cluster Monitoring add-on needs to read the Docker info data from the /var/run/docker.sock directory on the host for monitoring the Docker disk space.
The following permission is required for running node-exporter:
  • cap_dac_override: reads the Docker info data.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane, locate Cloud Native Cluster Monitoring on the right, and click Install.
  2. On the Install Add-on page, configure the specifications.
    • Deployment Mode: This parameter is available for the Cloud Native Cluster Monitoring version 3.7.1 or later.
      • Agent mode: Data is not stored locally, requiring fewer resources than the server mode. However, this mode does not support HPA.
        In the agent mode, monitoring data is no longer stored locally. Therefore, AOM or a third-party monitoring system must be accessed.
      • Server mode: Data is stored locally, requiring more resources than the agent mode. In this mode, all Cloud Native Cluster Monitoring functions are supported.
    • Containers: component instance created by the add-on. For details, see Components. You can select or customize a specification as required.
  3. Configure related parameters.
    • Interconnecting with AOM: Report Prometheus data to AOM. After this function is enabled, you can select the corresponding AOM instance.
    • Connect to Third Party: To report Prometheus data to a third-party monitoring system, enter the address and token of the third-party monitoring system and determine whether to skip certificate authentication.
    • User-defined Metrics Service Discovery: Application metrics are automatically collected in the form of service discovery.
    • Prometheus HA: The Prometheus-server, Prometheus-operator, thanos-query, custom-metrics-apiserver and alertmanager components are deployed in multi-instance mode in the cluster.
    • Number of collected shards: Collected targets are distributed among different Prometheus shards. This increases the upper limit of the metrics collection throughput but will consume more resources. Therefore, this parameter is recommended for large-scale clusters.
    • Collection Interval: Configure the collection interval.
    • Storage: Select the type and size of the disk for storing monitoring data. Uninstalling the add-on will not delete this volume.
      An available PVC named pvc-prometheus-server exists in namespace monitoring and will be used as the storage source.
    • Scheduling Policies: Support node affinity, taint, and tolerations. Multiple scheduling policies can be configured. If no affinity node label key or toleration node taint key is configured, this function is disabled by default.
      • Range: You can select the add-on pods for which the scheduling policy takes effect. By default, the scheduling policy takes effect for all pods. If a pod is specified, the scheduling policies configured for all pods are overwritten.
      • Affinity Node Label Key: Enter a node label key to set node affinity for the add-on pods.
      • Affinity Node Label Value: Enter a node label value to set node affinity for the add-on pods.
      • Toleration Node Taint Key: A component can be scheduled to a node that has the taint key you specify.
  4. Click Install.
    After the add-on is installed, you may need to perform the following operations:
Components
All Kubernetes resources created during the Cloud Native Cluster Monitoring add-on installation are created in the namespace named monitoring.
Table 1 Add-on components
Component
Resource Type
prometheusOperator
(workload name: prometheus-operator)
Deploys and manages the Prometheus Server based on CustomResourceDefinitions (CRDs), and monitors and processes the events related to these CRDs. It is the control center of the entire system.
Deployment
prometheus
(workload name: prometheus-server)
A Prometheus Server cluster deployed by the operator based on the Prometheus CRDs that can be regarded as StatefulSets.
StatefulSet
alertmanager
(workload name: alertmanager-alertmanager)
Alarm center of the add-on. It receives alarms sent by Prometheus and manages alarm information by deduplicating, grouping, and distributing.
StatefulSet
thanosSidecar
Available only in HA mode. Runs with prometheus-server in the same pod to implement persistent storage of Prometheus metric data.
Container
thanosQuery
Available only in HA mode. Entry for PromQL query when Prometheus is in HA scenarios. It can delete duplicate metrics from Store or Prometheus.
Deployment
adapter
(workload name: custom-metrics-apiserver)
Aggregates custom metrics to the native Kubernetes API Server.
Deployment
kubeStateMetrics
(workload name: kube-state-metrics)
Converts the Prometheus metric data into a format that can be identified by Kubernetes APIs. By default, the kube-state-metrics component does not collect all labels and annotations of Kubernetes resources. To collect all labels and annotations, see Collecting All Labels and Annotations of a Pod.
If the components run in multiple pods, only one pod provides metrics.
Deployment
nodeExporter
(workload name: node-exporter)
Deployed on each node to collect node monitoring data.
DaemonSet
grafana
(workload name: grafana)
Visualizes monitoring data. Grafana creates a 5 GiB storage volume by default. Uninstalling the add-on will not delete this volume.
Deployment
clusterProblemDetector
(workload name: cluster-problem-detector)
Monitors cluster exceptions.
Deployment
Providing Resource Metrics Through the Metrics API
Resource metrics of containers and nodes, such as CPU and memory usage, can be obtained through the Kubernetes Metrics API. Resource metrics can be directly accessed, for example, by using the kubectl top command, or used by HPA or CustomedHPA policies for auto scaling.
The add-on can provide the Kubernetes Metrics API that is disabled by default. To enable the API, create the following APIService object:
apiVersion: apiregistration.k8s.io/v1
kind: APIService
  labels:
    app: custom-metrics-apiserver
    release: cceaddon-prometheus
  group: metrics.k8s.io
  groupPriorityMinimum: 100
  insecureSkipTLSVerify: true
  service:
    namespace: monitoring
    port: 443
  version: v1beta1
  versionPriority: 100
You can save the object as a file, name it metrics-apiservice.yaml, and run the following command:
kubectl create -f metrics-apiservice.yaml
Run the kubectl top pod -n monitoring command. If the following information is displayed, the Metrics API can be accessed:
# kubectl top pod -n monitoring
NAME                                                      CPU(cores)   MEMORY(bytes)
custom-metrics-apiserver-d4f556ff9-l2j2m                  38m          44Mi
NOTICE:
To uninstall the add-on, run the following kubectl command and delete the APIService object. Otherwise, the metrics-server add-on cannot be installed due to residual APIService resources.
kubectl delete APIService v1beta1.metrics.k8s.io
Creating an HPA Policy Using Custom Metrics
HPA policies can only be used when Cloud Native Cluster Monitoring is deployed in the server mode. You can configure custom metrics required by HPA policies in the user-adapter-config ConfigMap.
NOTICE:
To use Prometheus to monitor custom metrics, the application needs to provide a metric monitoring API. For details, see Prometheus Monitoring Data Collection.
In this section, the nginx metric (nginx_connections_accepted) in Monitoring Custom Metrics Using Cloud Native Cluster Monitoring is used as an example.
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose ConfigMaps and Secrets.
  2. Click the ConfigMaps tab, select the monitoring namespace, locate the row containing user-adapter-config (or adapter-config), and click Update.
  3. In Data, click Edit for the config.yaml file to add a custom metric collection rule under the rules field. Click OK.
    You can add multiple collection rules by adding multiple configurations under the rules field. For details, see Metrics Discovery and Presentation Configuration.
    Example custom metric rule:
    rules:
    # Match the metric whose name is nginx_connections_accepted. The metric name must be confirmed. Otherwise, the HPA controller cannot get the metric.
    - seriesQuery: '{__name__=~"nginx_connections_accepted",container!="POD",namespace!="",pod!=""}'
      resources:
        # Specify pod and namespace resources.
        overrides:
          namespace:
            resource: namespace
          pod:
            resource: pod
      name:
        #Use nginx_connections_accepted"
        matches: "nginx_connections_accepted"
        #Use nginx_connections_accepted_per_second to represent the metric. The name is the custom metric name in a custom HPA policy.
        as: "nginx_connections_accepted_per_second"
        # Calculate rate(nginx_connections_accepted[2m]) to specify the number of requests received per second.
      metricsQuery: 'rate(<<.Series>>{<<.LabelMatchers>>,container!="POD"}[2m])'
  4. Redeploy the custom-metrics-apiserver workload in the monitoring namespace.
  5. In the navigation pane, choose Workloads. Locate the workload for which you want to create an HPA policy and choose More > Auto Scaling. In the Custom Policy area, you can select the preceding parameters to create an auto scaling policy.
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Workloads.
  2. Switch to the monitoring namespace, find the kube-state-metrics workload on the Deployments tab page, and click Upgrade in the Operation column.
  3. In the Lifecycle area of the container settings, edit the startup command.
    To collect labels, add the following information to the end of the original kube-state-metrics startup parameter:
    --metric-labels-allowlist=pods=[*],nodes=[node,failure-domain.beta.kubernetes.io/zone,topology.kubernetes.io/zone]
    To collect annotations, add parameters in the startup parameters in the same way.
    --metric-annotations-allowlist=pods=[*],nodes=[node,failure-domain.beta.kubernetes.io/zone,topology.kubernetes.io/zone]
    NOTICE:
    When editing the startup command, do not modify other original startup parameters. Otherwise, the component may be abnormal.
  4. kube-state-metrics starts to collect the labels/annotations of pods and nodes and checks whether kube_pod_labels/kube_pod_annotations is in the collection task of CloudScope.
    kubectl get servicemonitor kube-state-metrics -nmonitoring -oyaml | grep kube_pod_labels
For more kube-state-metrics startup parameters, see kube-state-metrics/cli-arguments.
