Updated on 2024-01-23 GMT+08:00
cume_dist
This function is used to return the cumulative distribution, which is equivalent to calculating the proportion of data in the partition that is greater than or equal to, or less than or equal to, the current row.
Restrictions
The restrictions on using window functions are as follows:
  • Window functions can be used only in select statements.
  • Window functions and aggregate functions cannot be nested in window functions.
  • Window functions cannot be used together with aggregate functions of the same level.
Syntax
cume_dist() over([partition_clause] [orderby_clause])
Parameters
Table 1 Parameters
Mandatory
partition_clause
No
Partition. Rows with the same value in partition columns are considered to be in the same window.
orderby_clause
No
How data is sorted in a window
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
To help you understand how to use functions, this example provides source data and function examples based on the source data. Run the following command to create the salary table and add data:
CREATE EXTERNAL TABLE salary (
dept STRING, -- Department name
userid string, -- Employee ID
sal INT -- Salary
) ROW FORMAT DELIMITED FIELDS TERMINATED BY ','
stored as textfile;
Adds the following data:
d1,user1,1000
d1,user2,2000
d1,user3,3000
d2,user4,4000
d2,user5,5000
  • Calculates the proportion of employees whose salary is less than or equal to the current salary.
    select dept, userid, sal,
           cume_dist() over(order by sal) as cume1
    from salary;
    -- Result:
    d1 user1 1000 0.2
    d1 user2 2000 0.4
    d1 user3 3000 0.6
    d2 user4 4000 0.8
    d2 user5 5000 1.0
  • Calculates the proportion of employees whose salary is less than or equal to the current salary by department.
           cume_dist() over (partition by dept order by sal) as cume2
    from salary;
    -- Result:
    d1 user1 1000 0.3333333333333333
    d1 user2 2000 0.6666666666666666
    d1 user3 3000 1.0
    d2 user4 4000 0.5
    d2 user5 5000 1.0
  • After sorting by sal in descending order, the result is the ratio of employees whose salary is greater than or equal to the current salary.
           cume_dist() over(order by sal desc) as cume3
    from salary;
    -- Result:
    d2 user5 5000 0.2
    d2 user4 4000 0.4
    d1 user3 3000 0.6
    d1 user2 2000 0.8
    d1 user1 1000 1.0
           cume_dist() over(partition by dept order by sal desc) as cume4
    from salary;
    -- Result:
    d1 user3 3000 0.3333333333333333
    d1 user1 1000 1.0
    d2 user5 5000 0.5
    d2 user4 4000 1.0
