shiftrightunsigned
This function is used to perform an unsigned bitwise right shift. It takes the binary number a and shifts it b positions to the right.
Syntax
shiftrightunsigned(BIGINT a, BIGINT b)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the BIGINT type, the system will implicitly convert it to the BIGINT type for calculation. |
b |
Yes |
Return Values
The return value is of the INT type.
If the value of a or b is NULL, NULL is returned.
Example Code
The value 2 is returned.
select shiftrightunsigned(16,3);
The value 536870910 is returned.
select shiftrightunsigned(-16,3);
select shiftrightunsigned(16.123456,3.123456);
The value NULL is returned.
select shiftrightunsigned(null,3);
