Cloud Data Center
DataArts Fabric
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
Cloud Container Instance (CCI)
Industry Video Management Service
Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
regexp_replace
Updated on 2025-04-02 GMT+08:00
This function has slight variations in its functionality depending on the version of Spark being used.
  • For Spark 2.4.5 or earlier: Replaces the substring that matches pattern in the string source with the specified string replace_string and returns the result string.
  • For Spark 3.1.1: Replaces the substring that matches the pattern for the occurrence time in the source string and the substring that matches the pattern later with the specified string replace_string and returns the result string.
Similar function: regexp_replace1. The regexp_replace1 function is used to replace the substring that matches pattern for the occurrence time in the source string with the specified string replace_string and return the result string. However, the egexp_replace1 function applies only to Spark 2.4.5 or earlier.
The regexp_replace1 function is applicable to Spark 2.4.5. It supports specifying the occurrence parameter, whereas the regexp_replace function does not support it.
Syntax
  • Spark 2.4.5 or earlier
    regexp_replace(string <source>, string <pattern>, string <replace_string>)
  • Spark 3.1.1
    regexp_replace(string <source>, string <pattern>, string <replace_string>[, bigint <occurrence>])
Parameters
Table 1 Parameters
Mandatory
Type
source
Yes
STRING
String to be replaced
pattern
Yes
STRING
Constant or regular expression of the STRING type. Pattern to be matched. For more guidelines on writing regular expressions, refer to the regular expression specifications. If the value of this parameter is an empty string, an error is reported.
replace_string
Yes
STRING
String that replaces the one matching the pattern parameter
occurrence
No
BIGINT
The value must be greater than or equal to 1, indicating that the string that is matched for the occurrence time is replaced with replace_string. When the value is 1, all matched substrings are replaced. If the value is of another type or is less than 1, an error is reported. The default value is 1.
This parameter is available only when Spark 3.1.1 is used.
Return Values
The return value is of the STRING type.
  • If the value of pattern is an empty string or there is no group in pattern, an error is reported.
  • If a group that does not exist is referenced, the group is not replaced.
  • If the value of replace_string is NULL and the pattern is matched, NULL is returned.
  • If the value of replace_string is NULL but the pattern is not matched, NULL is returned.
  • If the value of source, pattern, or occurrence is NULL, NULL is returned.
Example Code
    The value num-num is returned.
    SELECT regexp_replace('100-200', '(\\d+)', 'num');
  • For Spark 3.1.1
    The value 2222 is returned.
    select regexp_replace('abcd', '[a-z]', '2');
    select regexp_replace('abcd', '[a-z]', '2', 1);
    The value a222 is returned.
    select regexp_replace('abcd', '[a-z]', '2', 2);
    The value ab22 is returned.
    select regexp_replace('abcd', '[a-z]', '2', 3);
    The value abc2 is returned.
    select regexp_replace('abcd', '[a-z]', '2', 4);
咨询盘古Doer
