regexp_extract
Updated on 2023-10-25 GMT+08:00
This function is used to match the string source based on the pattern grouping rule and return the string content that matches groupid.
Syntax
regexp_extract(string <source>, string <pattern>[, bigint <groupid>])
Parameters
Table 1 Parameters
Mandatory
Type
source
Yes
STRING
String to be split
pattern
Yes
STRING
Constant or regular expression of the STRING type. Pattern to be matched.
groupid
No
BIGINT
Constant of the BIGINT type. The value must be greater than or equal to 0.
Return Values
The return value is of the STRING type.
  • If the value of pattern is an empty string or there is no group in pattern, an error is reported.
  • If the value of groupid is not of the BIGINT type or is less than 0, an error is reported.
  • If this parameter is not specified, the default value 1 is used, indicating that the first group is returned.
  • If the value of groupid is 0, the substring that meets the entire pattern is returned.
  • If the value of source, pattern, or groupid is NULL, NULL is returned.
Example Code
Splits basketball by bas(.*?)(ball). The value ket is returned.
select regexp_extract('basketball', 'bas(.*?)(ball)');
The value basketball is returned.
select regexp_extract('basketball', 'bas(.*?)(ball)',0);
The value 99 is returned. When submitting SQL statements for regular expression calculation on DLI, two backslashes (\) are used as escape characters.
select regexp_extract('8d99d8', '8d(\\d+)d8');
The value [Hello] is returned.
select regexp_extract('[Hello] hello', '([^\\x{00}-\\x{ff}]+)');
The value Hello is returned.
select regexp_extract('[Hello] hello', '([\\x{4e00}-\\x{9fa5}]+)');
