lpad
Updated on 2023-10-25 GMT+08:00
This function is used to return a string of a specified length. If the length of the given string (str1) is shorter than the specified length (length), the given string is left-padded with str2 to the specified length.
Syntax
lpad(string <str1>, int <length>, string <str2>)
Parameters
Table 1 Parameters
Mandatory
Type
str1
Yes
STRING
String to be left-padded
length
Yes
STRING
Number of digits to be padded to the left
str2
No
STRING
String used for padding
Return Values
The return value is of the STRING type.
  • If the value of length is smaller than the number of digits in str1, the string whose length is truncated from the left of str1 is returned.
  • If the value of length is 0, an empty string is returned.
  • If there is no input parameter or the value of any input parameter is NULL, NULL is returned.
Example Code
  • Uses string ZZ to left pad string abcdefgh to 10 digits. An example command is as follows:
    The value ZZabcdefgh is returned.
    select lpad('abcdefgh', 10, 'ZZ');
  • Uses string ZZ to left pad string abcdefgh to 5 digits. An example command is as follows:
    The value abcde is returned.
    select lpad('abcdefgh', 5, 'ZZ');
  • The value of length is 0. An example command is as follows:
    An empty string is returned.
    select lpad('abcdefgh', 0, 'ZZ');
  • The value of any input parameter is NULL. An example command is as follows:
    The value NULL is returned.
    select lpad(null ,0, 'ZZ');
