least
This function is used to return the smallest value in a list of values.
Syntax
least(T v1, T v2, ...)
Parameters
Parameter |
Mandatory |
Type |
Description |
v1 |
Yes |
DOUBLE, BIGINT, or DECIMAL |
The value can be a float or integer. |
v2 |
Yes |
Return Values
The return value is of the DOUBLE type.
- If the value of v1 or v2 is of the STRING type, an error is reported.
- If the values of all parameters are NULL, NULL is returned.
Example Code
The value 1.0 is returned.
select least(1,2.0,3,4.0);
The value NULL is returned.
select least(null);
