Help Center/ Data Lake Insight/ Spark SQL Syntax Reference/ Tables/ Table Lifecycle Management/ Disabling or Restoring the Lifecycle of a Table
Updated on 2024-07-04 GMT+08:00
Function
This section describes how to disable or restore the lifecycle of a specified table or partition.
You can disable or restore the lifecycle of a table in either of the following scenarios:
  1. If the lifecycle function has been enabled for a table or partitioned table, the system allows you to disable or restore the lifecycle of the table by changing the value of dli.table.lifecycle.status.
  2. If the lifecycle function is not enabled for a table or partitioned table, the system will add the dli.table.lifecycle.status property to allow you to disable or restore the lifecycle function of the table.
Notes and Constraints
  • The table lifecycle function is currently in the open beta test (OBT) phase. If necessary, contact customer service to whitelist it.
  • The table lifecycle function currently only supports creating tables and versioning tables using Hive and Datasource syntax.
  • The unit of the lifecycle is in days. The value should be a positive integer.
  • The lifecycle can be set only at the table level. The lifecycle specified for a partitioned table applies to all partitions of the table.
Syntax
  • This syntax can be used to disable or restore the lifecycle of a table at the table level.
    ALTER TABLE table_name SET TBLPROPERTIES("dli.table.lifecycle.status"={enable|disable});
  • This syntax can be used to disable or restore the lifecycle of a specified table at the table or partition table level.
    ALTER TABLE table_name [pt_spec] LIFECYCLE {enable|disable};
Keywords
TBLPROPERTIES: Table properties, which can be used to extend the lifecycle of a table.
Parameters
Table 1 Parameters
Mandatory
table_name
Yes
Name of the table whose lifecycle is to be disabled or restored
pt_spec
No
Partition information of the table whose lifecycle is to be disabled or restored. The format is partition_col1=col1_value1, partition_col2=col2_value1.... For a table with multi-level partitions, all partition values must be specified.
enable
No
Restores the lifecycle function of a table or a specified partition.
  • The table and its partitions participate in lifecycle reclamation again. By default, the lifecycle configuration of the current table and its partitions is used.
  • Before enabling the table lifecycle function, it is recommended to modify the lifecycle configuration of the table and its partitions. This will help prevent any accidental data reclamation caused by the previous configuration once the table lifecycle function is enabled.
disable
No
Disables the lifecycle function of a table or a specified partition.
  • Prevents a table and all its partitions from being reclaimed by the lifecycle. It takes priority over restoring the lifecycle of a table and its partitions. That is, when the lifecycle function of a table or a specified partition is disabled, the partition information of the table whose lifecycle is to be disabled or restored is invalid.
  • After the lifecycle function of a table is disabled, the lifecycle configuration of the table and the enable and disable flags of its partitions are retained.
  • After the lifecycle function of a table is disabled, the lifecycle configuration of the table and partitioned table can still be modified.
Example
  • Example 1: Disable the lifecycle function of the test_lifecycle table.
    alter table test_lifecycle SET TBLPROPERTIES("dli.table.lifecycle.status"='disable');
  • Example 2: Disable the lifecycle function for the partition whose time is 20230520 in the test_lifecycle table.
    alter table test_lifecycle partition (dt='20230520') LIFECYCLE 'disable';
    • After the lifecycle function of a partitioned table is disabled, the lifecycle function of all partitions within the table will also be disabled.
