Modifying the Lifecycle of a Table
Function
This section describes how to modify the lifecycle of an existing partitioned or non-partitioned table.
When the lifecycle function is enabled for the first time, the system scans tables or partitions, scans table data files in the path, and updates LAST_ACCESS_TIME of tables or partitions. The time required depends on the number of partitions and files.
Notes and Constraints
- The table lifecycle function is currently in the OBT phase. If necessary, contact customer service to whitelist it.
- The table lifecycle function currently only supports creating tables and versioning tables using Hive and Datasource syntax.
- The unit of the lifecycle is in days. The value should be a positive integer.
- The lifecycle can be set only at the table level. The lifecycle specified for a partitioned table applies to all partitions of the table.
Syntax
ALTER TABLE table_name
SET TBLPROPERTIES("dli.lifecycle.days"='N') Keywords
TBLPROPERTIES: Table properties, which can be used to extend the lifecycle of a table.
Parameters
| Parameter | Mandatory | Description |
| table_name | Yes | Name of the table whose lifecycle needs to be modified |
| dli.lifecycle.days | Yes | Lifecycle duration after the modification. The value must be a positive integer, in days. |
Example
- Example 1: Enable the lifecycle function for the test_lifecycle_exists table and set the lifecycle to 50 days.
alter table test_lifecycle_exists SET TBLPROPERTIES("dli.lifecycle.days"='50'); - Example 2: Enable the lifecycle function for an existing partitioned or non-partitioned table for which lifecycle is not set, for example, for the test_lifecycle_exists table, and set the lifecycle to 50 days.
alter table test_lifecycle_exists SET TBLPROPERTIES( "dli.lifecycle.days"='50', "dli.table.lifecycle.status"='enable' );
