Creating a DLI Table and Associating It with Oracle
Function
This statement is used to create a DLI table and associate it with an existing Oracle table.
- Before creating a DLI table and associating it with Oracle, you need to create an enhanced datasource connection.
For details about operations on the management console, see Enhanced Datasource Connections.
- Only enhanced datasource connections can be used to connect to Oracle, and only pay-per-use and yearly/monthly queues support enhanced datasource connections. So, only SQL jobs on pay-per-use and yearly/monthly queues can be connected to Oracle databases.
Syntax
1 2 3 4 5 6 7 8 9 | CREATE TABLE [IF NOT EXISTS] TABLE_NAME USING ORACLE OPTIONS ( 'url'='xx', 'driver'='DRIVER_NAME', 'dbtable'='db_in_oracle.table_in_oracle', 'user' = 'xxx', 'password' = 'xxx', 'resource' = 'obs://rest-authinfo/tools/oracle/driver/ojdbc6.jar' ); |
Keywords
| Parameter | Description |
| url | URL of the Oracle database. The URL can be in either of the following format:
| driver | Oracle driver class name: oracle.jdbc.driver.OracleDriver |
| dbtable | Name of the table associated with the Oracle database or Username.Table name, for example, public.table_name. |
| user | Oracle username. |
| password | Oracle password. |
| resource | OBS path of the Oracle driver package. Example: obs://rest-authinfo/tools/oracle/driver/ojdbc6.jar If the driver JAR file defined in this parameter is updated, you need to restart the queue for the update to take effect. |
Example
Creating an Oracle datasource table
1 2 3 4 5 6 7 8 9 | CREATE TABLE IF NOT EXISTS oracleTest USING ORACLE OPTIONS ( 'url'='jdbc:oracle:thin:@//192.168.168.40:1521/helowin', 'driver'='oracle.jdbc.driver.OracleDriver', 'dbtable'='test.Student', 'user' = 'test', 'password' = 'test', 'resource' = 'obs://rest-authinfo/tools/oracle/driver/ojdbc6.jar' ); |
