Querying the DDS Table
This statement is used to query data in a DDS table.
Syntax
        SELECT * FROM table_name LIMIT number;  |
Keywords
LIMIT is used to limit the query results. Only INT type is supported by the number parameter.
Precautions
If schema information is not specified during table creation, the query result contains the _id field for storing _id in the DOC file.
Example
Query data in the test_table1 table.
        SELECT * FROM test_table1 limit 100;  |
