Querying the DWS Table
This statement is used to query data in a DWS table.
Syntax
        SELECT * FROM table_name LIMIT number;  |
Keywords
LIMIT is used to limit the query results. Only INT type is supported by the number parameter.
Precautions
The table to be queried must exist. Otherwise, an error is reported.
Example
To query data in the dli_to_dws table, enter the following statement:
        SELECT * FROM dli_to_dws limit 100;  |
