Creating an OBS Table Using the Hive Syntax
Function
This statement is used to create an OBS table using the Hive syntax. The main differences between the DataSource and the Hive syntax lie in the supported data formats and the number of supported partitions. For details, see syntax and precautions.
You are advised to use the OBS parallel file system for storage. A parallel file system is a high-performance file system that provides latency in milliseconds, TB/s-level bandwidth, and millions of IOPS. It applies to interactive big data analysis scenarios.
Precautions
- The size of a table is calculated when the table is created.
- When data is added, the table size will not be changed.
- You can check the table size on OBS.
- Table properties cannot be specified using CTAS table creation statements.
- Instructions on using partitioned tables:
- When you create a partitioned table, ensure that the specified column in PARTITIONED BY is not a column in the table and the data type is specified. The partition column supports only the open-source Hive table types including string, boolean, tinyint, smallint, short, int, bigint, long, decimal, float, double, date, and timestamp.
- Multiple partition fields can be specified. The partition fields need to be specified after the PARTITIONED BY keyword, instead of the table name. Otherwise, an error occurs.
- A maximum of 200,000 partitions can be created in a single table.
- Spark 3.3 or later supports creating partitioned tables using CTAS statements of the Hive syntax.
- Instructions on setting the multi-character delimiter during table creation:
- The field delimiter can contain multiple characters only when ROW FORMAT SERDE is set to org.apache.hadoop.hive.contrib.serde2.MultiDelimitSerDe.
- You can only specify multi-character delimiters when creating Hive OBS tables.
- Tables with multi-character delimiters specified do not support data writing statements such as INSERT and IMPORT. To insert data into these tables, save the data file in the OBS path where the tables are located. For example, in Example 7: Creating a Table and Setting a Multi-Character Delimiter, store the data file in obs://bucketName/filePath.
Syntax
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 |
CREATE [EXTERNAL] TABLE [IF NOT EXISTS] [db_name.]table_name [(col_name1 col_type1 [COMMENT col_comment1], ...)] [COMMENT table_comment] [PARTITIONED BY (col_name2 col_type2, [COMMENT col_comment2], ...)] [ROW FORMAT row_format] [STORED AS file_format] LOCATION 'obs_path' [TBLPROPERTIES (key = value)] [AS select_statement] row_format: : SERDE serde_cls [WITH SERDEPROPERTIES (key1=val1, key2=val2, ...)] | DELIMITED [FIELDS TERMINATED BY char [ESCAPED BY char]] [COLLECTION ITEMS TERMINATED BY char] [MAP KEYS TERMINATED BY char] [LINES TERMINATED BY char] [NULL DEFINED AS char] |
Keywords
- EXTERNAL: Creates an OBS table.
- IF NOT EXISTS: Prevents system errors when the created table exists.
- COMMENT: Field or table description.
- PARTITIONED BY: Partition field.
- ROW FORMAT: Row data format.
- STORED AS: Specifies the format of the file to be stored. Currently, only the TEXTFILE, AVRO, ORC, SEQUENCEFILE, RCFILE, and PARQUET format are supported.
- LOCATION: Specifies the path of OBS. This keyword is mandatory when you create OBS tables.
- TBLPROPERTIES: Allows you to add the key/value properties to a table.
- You can use this statement to enable the multiversion function to back up and restore table data. After the multiversion function is enabled, the system automatically backs up table data when you delete or modify the data using insert overwrite or truncate, and retains the data for a certain period. You can quickly restore data within the retention period. For details about the SQL syntax for the multiversion function, see Enabling or Disabling Multiversion Backup and Backing Up and Restoring Data of Multiple Versions.
When creating an OBS table, you can use TBLPROPERTIES ("dli.multi.version.enable"="true") to enable multiversion. For details, see the following example.
Table 1 TBLPROPERTIES parameters Key
Value
- true: Enable the multiversion backup function.
- false: Disable the multiversion backup function.
comment
Description of the table
orc.compress
An attribute of the ORC table, which specifies the compression mode of the ORC storage. Available values are as follows:
- ZLIB
- SNAPPY
- NONE
- PARQUET
auto.purge
If this parameter is set to true, the deleted or overwritten data is removed and will not be dumped to the recycle bin.
- AS: Run the CREATE TABLE AS statement to create a table.
- The field delimiter can contain multiple characters only when ROW FORMAT SERDE is set to org.apache.hadoop.hive.contrib.serde2.MultiDelimitSerDe. For details, see Example 7: Creating a Table and Setting a Multi-Character Delimiter.
Parameters
Parameter |
Mandatory |
Description |
db_name |
No |
Database name The value can contain letters, numbers, and underscores (_), but it cannot contain only numbers or start with a number or underscore (_). |
table_name |
Yes |
Table name in the database The value can contain letters, numbers, and underscores (_), but it cannot contain only numbers or start with a number or underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. Special characters must be enclosed in single quotation marks (''). The table name is case insensitive. |
col_name |
Yes |
Name of a column field The column field can contain letters, numbers, and underscores (_), but it cannot contain only numbers and must contain at least one letter. The column name is case insensitive. |
col_type |
Yes |
Data type of a column field, which is primitive. For details, see Primitive Data Types. |
col_comment |
No |
Column field description, which can only be string constants. |
row_format |
Yes |
Row data format This function is available only for textfile tables. |
file_format |
Yes |
OBS table storage format, which can be TEXTFILE, AVRO, ORC, SEQUENCEFILE, RCFILE, or PARQUET. |
table_comment |
No |
Table description, which can only be string constants. |
obs_path |
Yes |
OBS storage path where data files are stored. You are advised to use an OBS parallel file system for storage. Format: obs://bucketName/tblPath bucketName: bucket name tblPath: directory name. You do not need to specify the file name following the directory. If there is a folder and a file with the same name in the OBS directory, the path pointed to by the OBS table will prioritize the file over the folder. |
key = value |
No |
Set table properties and values. For example, if you want to enable multiversion, you can set "dli.multi.version.enable"="true". |
select_statement |
No |
Used in the CREATE TABLE AS statement to insert the SELECT query results of the source table or a data record to a table newly created in the OBS bucket. |
Example 1: Creating an OBS Non-Partitioned Table
Example description: Create an OBS non-partitioned table named table1 and use the STORED AS keyword to set the storage format of the table to orc.
In practice, you can store OBS tables in textfile, avro, orc, sequencefile, rcfile, or parquet format.
1 2 3 4 5 6 |
CREATE TABLE IF NOT EXISTS table1 ( col_1 STRING, col_2 INT ) STORED AS orc LOCATION 'obs://bucketName/filePath'; |
Example 2: Creating an OBS Partitioned Table
Example description: Create a partitioned table named student, which is partitioned using facultyNo and classNo.
1 2 3 4 5 6 7 8 9 10 |
CREATE TABLE IF NOT EXISTS student( id INT, name STRING ) STORED AS avro LOCATION 'obs://bucketName/filePath' PARTITIONED BY ( facultyNo INT, classNo INT ); |
Example 3: Using CTAS to Create an OBS Table Using All or Part of the Data in the Source Table
Example description: Based on the OBS table table1 created in Example 1: Creating an OBS Non-Partitioned Table, use the CTAS syntax to copy data from table1 to table1_ctas.
When using CTAS to create a table, you can ignore the syntax used to create the table being copied. This means that regardless of the syntax used to create table1, you can use the DataSource syntax to create table1_ctas.
In addition, in this example, the storage format of table1 is orc, and the storage format of table1_ctas may be sequencefile or parquet. This means that the storage format of the table created by CTAS may be different from that of the original table.
Use the SELECT statement following the AS keyword to select required data and insert the data to table1_ctas.
The SELECT syntax is as follows: SELECT <Column name > FROM <Table name > WHERE <Related filter criteria>.
- In this example, SELECT * FROM table1 is used. * indicates that all columns are selected from table1 and all data in table1 is inserted into table1_ctas.
1 2 3 4 5 6
CREATE TABLE IF NOT EXISTS table1_ctas STORED AS sequencefile LOCATION 'obs://bucketName/filePath' AS SELECT * FROM table1;
- To filter and insert data into table1_ctas in a customized way, you can use the following SELECT statement: SELECT col_1 FROM table1 WHERE col_1 = 'Ann'. This will allow you to select only col_1 from table1 and insert data into table1_ctas where the value equals 'Ann'.
1 2 3 4 5 6 7
CREATE TABLE IF NOT EXISTS table1_ctas USING parquet OPTIONS (path 'obs:// bucketName/filePath') AS SELECT col_1 FROM table1 WHERE col_1 = 'Ann';
Example 4: Creating an OBS Non-Partitioned Table and Customizing the Data Type of a Column Field
Example description: Create an OBS non-partitioned table named table2. You can customize the native data types of column fields based on service requirements.
- STRING, CHAR, or VARCHAR can be used for text characters.
- TIMESTAMP or DATE can be used for time characters.
- INT, SMALLINT/SHORT, BIGINT/LONG, or TINYINT can be used for integer characters.
- FLOAT, DOUBLE, or DECIMAL can be used for decimal calculation.
- BOOLEAN can be used if only logical switches are involved.
For details, see "Data Types" > "Primitive Data Types".
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 |
CREATE TABLE IF NOT EXISTS table2 ( col_01 STRING, col_02 CHAR (2), col_03 VARCHAR (32), col_04 TIMESTAMP, col_05 DATE, col_06 INT, col_07 SMALLINT, col_08 BIGINT, col_09 TINYINT, col_10 FLOAT, col_11 DOUBLE, col_12 DECIMAL (10, 3), col_13 BOOLEAN ) STORED AS parquet LOCATION 'obs://bucketName/filePath'; |
Example 5: Creating an OBS Partitioned Table and Customizing TBLPROPERTIES Parameters
Example description: Create an OBS partitioned table named table3 and partition the table based on col_3. Set dli.multi.version.enable, comment, orc.compress, and auto.purge in TBLPROPERTIES.
- dli.multi.version.enable: In this example, set this parameter to true, indicating that the DLI data versioning function is enabled for table data backup and restoration.
- comment: table description, which can be modified later.
- orc.compress: compression mode of the orc format, which is ZLIB in this example.
- auto.purge: In this example, set this parameter to true, indicating that data that is deleted or overwritten will bypass the recycle bin and be permanently deleted.
1 2 3 4 5 6 7 8 9 10 11 12 13 |
CREATE TABLE IF NOT EXISTs table3 ( col_1 STRING, col_2 STRING ) PARTITIONED BY (col_3 DATE) STORED AS rcfile LOCATION 'obs://bucketName/filePath' TBLPROPERTIES ( dli.multi.version.enable = true, comment = 'Created by dli', orc.compress = 'ZLIB', auto.purge = true ); |
Example 6: Creating a Non-Partitioned Table in textfile Format and Setting ROW FORMAT
Example description: Create a non-partitioned table named table4 in the textfile format and set ROW FORMAT (the ROW FORMAT function is available only for textfile tables).
- FIELDS: columns in a table. Each field has a name and data type. Fields in a table are separated by slashes (/).
- COLLECTION ITEMS: A collection item refers to an element in a group of data, which can be an array, a list, or a collection. Collection items in a table are separated by $.
- MAP KEYS: A map key is a data structure of key-value pairs and is used to store a group of associated data. Map keys in a table are separated by number signs (#).
- LINES: rows in a table. Each row contains a group of field values. Rows in a table end with \n. (Note that only \n can be used as the row separator.)
- NULL: a special value that represents a missing or unknown value. In a table, NULL indicates that the field has no value or the value is unknown. When there is a null value in the data, it is represented by the string null.
1 2 3 4 5 6 7 8 9 10 11 12 |
CREATE TABLE IF NOT EXISTS table4 ( col_1 STRING, col_2 INT ) STORED AS textfile LOCATION 'obs://bucketName/filePath' ROW FORMAT DELIMITED FIELDS TERMINATED BY '/' COLLECTION ITEMS TERMINATED BY '$' MAP KEYS TERMINATED BY '#' LINES TERMINATED BY '\n' NULL DEFINED AS 'null'; |
Example description: A Hive table named table5 is created. The serialization and deserialization class ROW FORMAT SERDE is specified for the table, with a field delimiter set to /# and data stored in a text file format.
- Tables with multi-character delimiters specified do not support data writing statements such as INSERT and IMPORT. To insert data into these tables, save the data file in the OBS path where the tables are located. For example, in this example, store the data file in obs://bucketName/filePath.
- In this example, field.delim is set to /#.
- The ROW FORMAT function is available only for textfile tables.
CREATE TABLE IF NOT EXISTS table5 ( col_1 STRING, col_2 INT ) ROW FORMAT SERDE 'org.apache.hadoop.hive.contrib.serde2.MultiDelimitSerDe' WITH SERDEPROPERTIES ( 'field.delim' = '/#' ) STORED AS textfile LOCATION 'obs://bucketName/filePath';
