Updated on 2025-01-09 GMT+08:00
ADD COLUMNS
Function
The ADD COLUMNS command is used to add a column to an existing table.
Syntax
ALTER TABLE Table name ADD COLUMNS(col_spec[, col_spec ...])
Parameter Description
Table 1 ADD COLUMNS parameters
tableName
Table name.
col_spec
Column specifications, consisting of four fields, col_name, col_type, nullable, and comment.
  • col_name: name of the new column. It is mandatory.
    Adding new subcolumns to nested columns is currently not supported.
  • col_type: type of the new column. It is mandatory.
  • nullable: whether the new column can be null. The value can be left empty.
  • comment: comment of the new column. The value can be left empty.
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing ALTER TABLE
Permission Description
ALTER permission on a table
  • Fine-grained permission: dli:table:alter
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
alter table h0 add columns(ext0 string);
alter table h0 add columns(new_col int comment 'add new column');
alter table delta.`obs://bucket_name0/db0/delta_table0` add columns(new_col string);
Response
You can run the DESCRIBE command to view the new column.
