Updated on 2025-01-09 GMT+08:00
CREATE TABLE AS SELECT
Function
This command creates a Hudi table by specifying a list of fields with table attributes.
Syntax
CREATE[ OR REPLACE] TABLE [ IF NOT EXISTS] [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
USING DELTA
[ COMMENT table_comment ]
[ PARTITIONED BY (partColumnList) ]
[ LOCATION location_path]
[ AS query_statement ]
Parameter Description
Table 1 Parameter descriptions of CREATE TABLE AS SELECT
database_name
Name of the database, consisting of letters, numbers, and underscores (_)
table_name
Name of the table in the database, consisting of letters, numbers, and underscores (_)
bucket_name
OBS bucket name
tbl_path
Storage location of the Delta table in the OBS bucket
using
Parameter delta, defines and creates the Delta table
table_comment
Description of the table
location_path
Storage location of the Delta table. In the current version, it must be specified when a Delta table is created based on the table name and can only support OBS paths. Specifying this path creates the Delta table as a foreign table.
query_statement
SELECT statement
Required Permissions
  • SQL permissions
    Table 2 Permissions required for executing CREATE TABLE AS SELECT
    Permission Description
    CREATE_TABLE permission on the database
    SELECT permission to query a table
  • Fine-grained permissions: dli:database:createTable and dli:table:select
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
  • Create a partitioned table.
    create table if not exists delta_table0
    using delta
    partitioned by (dt)
    location 'obs://bucket_name0/db0/delta_table0'
    as
    select 1 as id, 'a1' as name, 10 as price, 1000 as dt;
  • Create a non-partitioned table.
    using delta
    as
    select 1 as id, 'a1' as name, 10 as price;
    create table delta.`obs://bucket_name0/db0/delta_table0`
    using delta
    partitioned by (part_col1, part_col2)
    as select id,name,year,class_name from table1 where part_col1=2024;
