SDK Overview
This document describes different SDK runtimes supported by CCE Autopilot and provides the addresses for obtaining the latest SDK versions.
SDKs
Before you start, make sure you have installed the latest SDKs. Earlier SDKs may not be compatible, or lack the latest features. To query the version, see SDK Center.
Table 1 lists SDKs supported by CCE Autopilot. You can view the SDK update history, obtain the SDK installation packages, and view SDK user guides in GitHub.
