Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ FAQs/ Storage/ What Are the Differences Among CCE Storage Classes in Terms of Persistent Storage and Multi-Node Mounting?
Updated on 2025-07-07 GMT+08:00
Container storage provides storage for container workloads. It supports multiple storage classes. A pod can use any amount of storage.
Currently, CCE supports local, EVS, SFS, SFS Turbo, and OBS volumes.
The following table lists the differences among these storage classes.
Table 1 Differences among storage classes
Storage Class
Persistent Storage
Automatic Migration with Containers
Multi-Node Mounting
Local disks
Supported
Not supported
Not supported
EVS
Supported
Supported
Not supported
OBS
Supported
Supported
Supported. This type of volumes can be shared among multiple nodes or workloads.
SFS Turbo
Supported
Supported
Dedicated Distributed Storage Service (DSS)
Supported
Supported
Not supported
Selecting a Storage Class
You can use the following types of storage volumes when creating a workload. You are advised to store workload data on EVS volumes. If you store workload data on a local volume, the data cannot be restored when a fault occurs on the node.
  • Local volumes: Mount the file directory of the host where a container is located to a specified container path (corresponding to hostPath in Kubernetes). Alternatively, you can leave the source path empty (corresponding to emptyDir in Kubernetes). If the source path is left empty, a temporary directory of the host will be mounted to the mount point of the container. A specified source path is used when data needs to be persistently stored on the host, while emptyDir is used when temporary storage is needed. A ConfigMap is a type of resource that stores configuration data required by a workload. Its contents are user-defined. A secret is an object that contains sensitive data such as workload authentication information and keys. Information stored in a secret is determined by users.
  • EVS volumes: Mount an EVS volume to a container path. When the container is migrated, the mounted EVS volume is migrated together. This storage class is applicable when data needs to be stored permanently.
  • OBS volumes: Create OBS volumes and mount them to a container path. OBS volumes are applicable to scenarios such as cloud workload, data analysis, content analysis, and hotspot objects.
  • SFS Turbo volumes: Create SFS Turbo volumes and mount them to a container path. SFS Turbo volumes are fast, on-demand, and scalable, which makes them suitable for DevOps, containerized microservices, and enterprise office applications.
  • DSS volumes: CCE allows you to create DSS volumes and mount them to a container path. DSS offers dedicated, physical storage resources tailored to fulfill the needs of high-performance and low-latency storage. It is ideal for scenarios such as high-performance computing, real-time analysis and processing, and handling mixed workloads.
