Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
FAQs/
Workload/
Workload Exception Troubleshooting/
What Should I Do If a Workload Is Stopped Caused by Pod Deletion?
Updated on 2025-07-07 GMT+08:00
Symptom
A workload is in Stopped state.
Possible Cause
The metadata.enable field in the YAML file of the workload is false. As a result, the pod of the workload is deleted and the workload is in the stopped status.
Solution
Delete the enable field or set it to true.
Parent topic: Workload Exception Troubleshooting
