Concepts
Sticky sessions ensure continuity and consistency when you access applications. If a load balancer is deployed between a client and backend servers, connections may be forwarded to different servers for processing. Sticky sessions can resolve this issue. After sticky session is enabled, requests from the same client will be continuously distributed to the same backend server through load balancing.
For example, in most online systems that require user identity authentication, a user needs to interact with the server for multiple times to complete a session. These interactions require continuity. If sticky session is not configured, the load balancer may allocate certain requests to different backend servers. Since user identity has not been authenticated on other backend servers, interaction exceptions such as a user login failure may occur.
Therefore, select a proper sticky session type based on the application environment.
Table 1 Sticky session types
OSI Layer |
Listener Protocol and Networking |
Sticky Session Type |
Scenarios Where Sticky Sessions Become Invalid |
Layer 4 |
TCP- or UDP-compliant Services |
Source IP address: The source IP address of each request is calculated using the consistent hashing algorithm to obtain a unique hashing key, and all backend servers are numbered. The system allocates the client to a particular server based on the generated key. This allows requests from the same IP address are forwarded to the same backend server. |
- Source IP addresses of the clients have changed.
- Requests from the clients exceed the session stickiness duration.
Layer 7 |
HTTP- or HTTPS-compliant ingresses |
- Load balancer cookie: The load balancer generates a cookie after receiving a request from the client. All subsequent requests with the cookie will be routed to the same backend server.
- Application cookie: The application deployed on the backend server generates a cookie after receiving the first request from the client. All subsequent requests with the same cookie will be routed to the same backend server.
- If requests sent by the clients do not contain a cookie, sticky sessions will not take effect.
When creating a load balancer, configure sticky sessions by setting kubernetes.io/elb.lb-algorithm to ROUND_ROBIN or kubernetes.io/elb.lb-algorithm to LEAST_CONNECTIONS. If you set kubernetes.io/elb.lb-algorithm is to SOURCE_IP, source IP address-based sticky sessions are supported. In this case, you do not need to configure sticky sessions again.
Enabling Layer 4 Sticky Session in a CCE Standard Cluster
In a CCE standard cluster, to enable source IP address-based sticky session for a Service, ensure the following conditions are met:
- Service Affinity of the Service must be set to Node-level, where the externalTrafficPolicy value of the Service must be Local.
- Anti-affinity has been enabled on the backend applications of the Service to prevent all pods from being deployed on the same node.
- Create an Nginx workload.
Set the number of pods to 3 and configure podAntiAffinity.
kind: Deployment
apiVersion: apps/v1
namespace: default
replicas: 3
selector:
matchLabels:
app: nginx
template:
labels:
app: nginx
containers:
- name: container-0
image: 'nginx:perl'
resources:
limits:
cpu: 250m
memory: 512Mi
requests:
cpu: 250m
memory: 512Mi
imagePullSecrets:
- name: default-secret
affinity:
podAntiAffinity: # Pod anti-affinity
requiredDuringSchedulingIgnoredDuringExecution:
- labelSelector:
matchExpressions:
- key: app
operator: In
values:
- nginx
topologyKey: kubernetes.io/hostname
- Create a LoadBalancer Service, for example, using an existing load balancer. The following shows an example YAML file for configuring source IP address-based sticky sessions:
apiVersion: v1
kind: Service
namespace: default
annotations:
kubernetes.io/elb.class: union
kubernetes.io/elb.id: *****
kubernetes.io/elb.lb-algorithm: ROUND_ROBIN # Weighted round robin allocation policy
kubernetes.io/elb.session-affinity-mode: SOURCE_IP # Enable source IP address-based sticky session.
selector:
app: nginx
externalTrafficPolicy: Local # Node level Service affinity
ports:
- name: cce-service-0
targetPort: 80
nodePort: 32633
port: 80
protocol: TCP
type: LoadBalancer
- Check whether the Layer 4 sticky session function is enabled.
- Log in to the ELB console, locate the row containing the target load balancer, and click the listener name.
- Check whether the sticky session function is enabled in the backend server group.
Enabling Layer 7 Sticky Session in a CCE Standard Cluster
To enable cookie-based sticky session on an ingress, ensure the following conditions are met:
- Service Affinity of the ingress must be set to Node-level, where the externalTrafficPolicy value of the Service must be Local.
- Anti-affinity must be enabled for the ingress workload to prevent all pods from being deployed on the same node.
kind: Deployment
apiVersion: apps/v1
namespace: default
replicas: 3
selector:
matchLabels:
app: nginx
template:
labels:
app: nginx
containers:
- name: container-0
image: 'nginx:perl'
resources:
limits:
cpu: 250m
memory: 512Mi
requests:
cpu: 250m
memory: 512Mi
imagePullSecrets:
affinity:
- labelSelector:
matchExpressions:
- key: app
operator: In
values:
- nginx
- Create a Service for the workload. This section uses a NodePort Service as an example.
Configure sticky sessions during the creation of a Service. An ingress can access multiple Services, and each Service can have different sticky sessions.
apiVersion: v1
kind: Service
namespace: default
annotations:
kubernetes.io/elb.session-affinity-mode: HTTP_COOKIE # HTTP cookie
kubernetes.io/elb.session-affinity-option: '{"persistence_timeout":"1440"}' # Session stickiness duration, in minutes. The value ranges from 1 to 1440.
selector:
app: nginx
ports:
protocol: TCP
port: 80
targetPort: 80
nodePort: 32633 # Custom node port
type: NodePort
You can also select APP_COOKIE.
Only shared load balancers support application cookie-based sticky sessions.
apiVersion: v1
kind: Service
namespace: default
annotations:
kubernetes.io/elb.session-affinity-mode: APP_COOKIE # Select APP_COOKIE.
kubernetes.io/elb.session-affinity-option: '{"app_cookie_name":"test"}' # Application cookie name
selector:
app: nginx
ports:
protocol: TCP
port: 80
targetPort: 80
type: NodePort
- Create an ingress and associate it with the Service.
kind: Ingress
namespace: default
annotations:
kubernetes.io/elb.port: '80'
rules:
- host: 'www.example.com'
http:
paths:
- path: '/'
backend:
service:
name: nginx # Service name
port:
number: 80
property:
ingressClassName: cce
- Verify that the Layer 7 sticky session function is enabled.
- Click the Forwarding Policies tab, click the backend server group name, and check whether sticky session is enabled for it.
