Easily Switch Between Product Types
You can click the drop-down list box to switch between different product types.
Configuring Multiple Forwarding Policies for a LoadBalancer Ingress
An ingress can route requests to multiple backend Services based on different matching policies. For example, requests can be routed to three different backend Services separately by accessing www.example.com/foo, www.example.com/bar, and foo.example.com/.
NOTICE:
The URL registered in an ingress forwarding policy must be the same as the URL used to access the backend Service. Otherwise, a 404 error will be returned.
For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
Using the CCE Console
  2. Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring forwarding policies. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer.
    Shared
    Listener
    • External Protocol: HTTP and HTTPS are available.
    • External Port: specifies the port of the load balancer listener.
    • External Port: 80
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service or create a Service. Any Services that do not match the search criteria will be filtered out automatically.
    • Destination Service Port: Select the access port of the destination Service.
    Forwarding rule 1:
    • Domain Name: www.example.com
    • Path Matching Rule: Prefix match
    • Path: /foo
    • Destination Service: nginx
    • Destination Service Port: 80
    Forwarding rule 2:
    • Path: /bar
    Forwarding rule 3:
    • Domain Name: foo.example.com
    • Path: /
  4. Click OK.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    For clusters of v1.23 or later:
    kind: Ingress
      annotations:
        kubernetes.io/elb.id: <your_elb_id>  #Replace it with the ID of your existing load balancer.
        kubernetes.io/elb.class: performance  # Load balancer type
        kubernetes.io/elb.port: '80'
      rules:
      - host: 'www.example.com'
        http:
          paths:
          - path: '/foo'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: 80             # Replace 80 with the port number of your target Service.
            property:
          - path: '/bar'
            backend:
              service:
                port:
            property:
      - host: 'foo.example.com'
        http:
          paths:
          - path: '/'
            backend:
              service:
                port:
            property:
      ingressClassName: cce
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/ingress.class: cce
      rules:
        http:
          paths:
          - path: '/foo'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: 80
            property:
          - path: '/bar'
            backend:
              servicePort: 80
            property:
        http:
          paths:
          - path: '/'
            backend:
              servicePort: 80
            property:
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME           CLASS  HOSTS                               ADDRESS          PORTS   AGE
    ingress-test   cce    www.example.com,foo.example.com     121.**.**.**     80      10s
