Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
containerd.sock
containerd.sock
Check Items
Check whether the containerd.sock file is on the node. This file affects the startup of container runtime in the Euler OS.
Solution
Scenario: The Docker used by the node is the customized Euler-docker.
- Log in to the node.
- Run the rpm -qa | grep docker | grep euleros command. If the command output is not empty, the Docker used on the node is Euler-docker.
- Run the stat /run/containerd/containerd.sock command. If the file exists, Docker startup will fail.
- Run the rm -rf /run/containerd/containerd.sock command and perform the cluster upgrade check again.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
