Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Node CPU Cores
Updated on 2025-07-07 GMT+08:00
Node CPU Cores
Check Items
Verify that the master nodes in your cluster have more than 2 CPU cores.
Solution
The master nodes have only 2 CPU cores, which may lead to a cluster upgrade failure.
Contact technical support to expand the number of CPU cores to four or more.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
