Default GPU Scheduling in Kubernetes
You can use GPUs in CCE containers.
- A GPU node has been created. For details, see Creating a Node.
- The CCE AI Suite (NVIDIA GPU) add-on has been installed, with the selected driver matching the GPU model on the node. For details, see CCE AI Suite (NVIDIA GPU).
- When default GPU scheduling is used in clusters of v1.27 or earlier, the CCE AI Suite (NVIDIA GPU) add-on mounts the driver directory to /usr/local/nvidia/lib64. To use GPU resources in containers, you need to add /usr/local/nvidia/lib64 to the LD_LIBRARY_PATH environment variable. You can skip this step for clusters of v1.28 or later.
You can add environment variables in any of the following ways:
- Configure the LD_LIBRARY_PATH environment variable in the Dockerfile used for creating an image. (Recommended)
ENV LD_LIBRARY_PATH /usr/local/nvidia/lib64:$LD_LIBRARY_PATH
- Configure the LD_LIBRARY_PATH environment variable in the image startup command.
/bin/bash -c "export LD_LIBRARY_PATH=/usr/local/nvidia/lib64:$LD_LIBRARY_PATH && ..."
- Define the LD_LIBRARY_PATH environment variable when creating a workload. (Ensure that this variable is not configured in the container. Otherwise, it will be overwritten.)
... env: - name: LD_LIBRARY_PATH value: /usr/local/nvidia/lib64 ...
Using GPUs
Create a workload and request GPUs. You can specify the number of GPUs as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: gpu-test namespace: default spec: replicas: 1 selector: matchLabels: app: gpu-test template: metadata: labels: app: gpu-test spec: containers: - image: nginx:perl name: container-0 resources: requests: cpu: 250m memory: 512Mi nvidia.com/gpu: 1 # Number of requested GPUs limits: cpu: 250m memory: 512Mi nvidia.com/gpu: 1 # Maximum number of GPUs that can be used imagePullSecrets: - name: default-secret
nvidia.com/gpu specifies the number of GPUs to be requested. The value can be smaller than 1. For example, nvidia.com/gpu: 0.5 indicates that multiple pods share a GPU. In this case, all the requested GPU resources come from the same GPU card.
When you use nvidia.com/gpu to specify the number of GPUs, the values of requests and limits must be the same.
After nvidia.com/gpu is specified, workloads will not be scheduled to nodes without GPUs. If the node is GPU-starved, Kubernetes events similar to the following are reported:
- 0/2 nodes are available: 2 Insufficient nvidia.com/gpu.
- 0/4 nodes are available: 1 InsufficientResourceOnSingleGPU, 3 Insufficient nvidia.com/gpu.
To use GPU resources on the CCE console, you only need to configure the GPU quota when creating a workload.
GPU Node Labels
CCE will label GPU nodes that are ready to use. When using GPUs, you can enable affinity between pods and nodes based on labels so that the pods can be scheduled to the correct nodes. To do so, perform the following operations:
- Run the following command to view all nodes in the cluster and retrieve the value of the accelerator label (if applicable):
kubectl get node -L accelerator
The following information is displayed, showing the label value:
NAME STATUS ROLES AGE VERSION ACCELERATOR 10.100.2.179 Ready <none> 8m43s v1.19.10-r0-CCE21.11.1.B006-21.11.1.B006 nvidia-t4
- When using a YAML file to create a workload, add the following parameters to define affinity between pods and nodes:
apiVersion: apps/v1 kind: Deployment metadata: name: gpu-test namespace: default spec: replicas: 1 selector: matchLabels: app: gpu-test template: metadata: labels: app: gpu-test spec: nodeSelector: accelerator: nvidia-t4 containers: - image: nginx:perl name: container-0 resources: requests: cpu: 250m memory: 512Mi nvidia.com/gpu: 1 # Number of requested GPUs limits: cpu: 250m memory: 512Mi nvidia.com/gpu: 1 # Maximum number of GPUs that can be used imagePullSecrets: - name: default-secret
