Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ Auto Scaling/ Using HPA and CA for Auto Scaling of Workloads and Nodes
Application Scenarios
The best way to handle surging traffic is to automatically adjust the number of machines based on the traffic volume or resource usage, which is called scaling.
When deploying applications in pods, you can configure requested resources and resource limits for the pods to prevent unlimited usage of resources during peak hours. However, after the upper limit is reached, an application error may occur. Pod scaling can effectively resolve this issue. If the resource usage on the node increases to a certain extent, newly added pods cannot be scheduled to this node. In this case, CCE will add nodes accordingly.
Solution
Two major auto scaling policies are HPA (Horizontal Pod Autoscaling) and CA (Cluster AutoScaling). HPA is for workload auto scaling and CA is for node auto scaling.
HPA and CA work with each other. HPA requires sufficient cluster resources for successful scaling. When the cluster resources are insufficient, CA is needed to add nodes. If HPA reduces workloads, the cluster will have a large number of idle resources. In this case, CA needs to release nodes to avoid resource waste.
As shown in Figure 1, HPA performs scale-out based on the monitoring metrics. When cluster resources are insufficient, newly created pods are in Pending state. CA then checks these pending pods and selects the most appropriate node pool based on the configured scaling policy to scale out the node pool.
Figure 1 HPA and CA working flows
Using HPA and CA enables automatic scaling for most scenarios while also providing monitoring capabilities.
This section uses an example to describe the auto scaling process using HPA and CA policies together.
Preparations
  1. Create a cluster with one node. The node should have 2 cores of vCPUs and 4 GiB of memory, or a higher specification, as well as an EIP to allow external access. If no EIP is bound to the node during node creation, you can manually bind one on the ECS console after creating the node.
  2. Install add-ons for the cluster.
    • autoscaler: node scaling add-on
    • metrics-server: an aggregator of resource usage data in a Kubernetes cluster. It can collect measurement data of major Kubernetes resources, such as pods, nodes, containers, and Services.
  3. Log in to the cluster node and run a computing-intensive application. When a user sends a request, the result needs to be calculated before being returned to the user.
    1. Create a PHP file named index.php to calculate the square root of the request for 1,000,000 times before returning OK!.
      vi index.php
      The file content is as follows:
      <?php
        $x = 0.0001;
        for ($i = 0; $i <= 1000000; $i++) {
          $x += sqrt($x);
        echo "OK!";
    2. Compile a Dockerfile file to build an image.
      vi Dockerfile
      The content is as follows:
      FROM php:5-apache
      COPY index.php /var/www/html/index.php
      RUN chmod a+rx index.php
    3. Run the following command to build an image named hpa-example with the tag latest.
      docker build -t hpa-example:latest .
    4. (Optional) Log in to the SWR console, choose Organizations in the navigation pane, and click Create Organization in the upper right corner.
      Skip this step if you already have an organization.
    5. In the navigation pane, choose My Images and then click Upload Through Client. On the page displayed, click Generate a temporary login command and click to copy the command.
    6. Run the login command copied in the previous step on the cluster node. If the login is successful, the message "Login Succeeded" is displayed.
    7. Tag the hpa-example image.
      docker tag {Image name 1:Tag 1}/{Image repository address}/{Organization name}/{Image name 2:Tag 2}
      • {Image name 1:Tag 1}: name and tag of the local image to be uploaded.
      • {Image repository address}: the domain name at the end of the login command in login command. It can be obtained on the SWR console.
      • {Organization name}: name of the created organization.
      • {Image name 2:Tag 2}: desired image name and tag to be displayed on the SWR console.
      The following is an example:
      docker tag hpa-example:latest {Image repository address}/group/hpa-example:latest
    8. Push the image to the image repository.
      docker push {Image repository address}/{Organization name}/{Image name 2:Tag 2}
      docker push {Image repository address}/group/hpa-example:latest
      The following information will be returned upon a successful push:
      6d6b9812c8ae: Pushed
      fe4c16cbf7a4: Pushed
      latest: digest: sha256:eb7e3bbd*** size: **
      To view the pushed image, go to the SWR console and refresh the My Images page.
Creating a Node Pool and a Node Scaling Policy
  1. Log in to the CCE console, access the created cluster, click Nodes on the left, click the Node Pools tab, and click Create Node Pool in the upper right corner.
  2. Configure the node pool.
    • Node Type: Select a node type.
    • Specifications: 2 vCPUs | 4 GiB
    Retain the defaults for other parameters.
  3. Locate the row containing the newly created node pool and click Auto Scaling in the upper right corner.
    If the CCE Cluster Autoscaler add-on is not installed in the cluster, install it first.
    • Customize scale-out rules.: Click Add Rule. In the dialog box displayed, configure parameters. If the CPU allocation rate is greater than 70%, a node is added to each associated node pool. A node scaling policy needs to be associated with a node pool. Multiple node pools can be associated. When you need to scale nodes, node with proper specifications will be added or reduced from the node pool based on the minimum waste principle.
    • Nodes: Modify the node quantity range. The number of nodes in a node pool will always be within the range during auto scaling.
    • Cooldown Period: a period during which the nodes added in the current node pool cannot be scaled in
  4. Click OK.
Creating a Workload
Use the hpa-example image to create a Deployment with one replica. The image path is related to the organization uploaded to the SWR repository and needs to be replaced with the actual value.
kind: Deployment
apiVersion: apps/v1
  replicas: 1
  selector:
    matchLabels:
      app: hpa-example
  template:
      labels:
        app: hpa-example
      containers:
      - name: container-1
        image: 'hpa-example:latest' # Replace it with the address of the image you uploaded to SWR.
        resources:
          limits:                  # The value of limits must be the same as that of requests to prevent flapping during scaling.
            cpu: 500m
            memory: 200Mi
          requests:
            cpu: 500m
            memory: 200Mi
      imagePullSecrets:
      - name: default-secret
Then, create a NodePort Service for the workload so that the workload can be accessed from external networks.
kind: Service
apiVersion: v1
  ports:
    - name: cce-service-0
      protocol: TCP
      port: 80
      targetPort: 80
      nodePort: 31144
  selector:
    app: hpa-example
  type: NodePort
Creating an HPA Policy
Create an HPA policy. As shown below, the policy is associated with the hpa-example workload, and the target CPU usage is 50%.
There are two other annotations. One annotation defines the CPU thresholds, indicating that scaling is not performed when the CPU usage is between 30% and 70% to prevent impact caused by slight fluctuation. The other is the scaling time window, indicating that after the policy is successfully executed, a scaling operation will not be triggered again in this cooling interval to prevent impact caused by short-term fluctuation.
apiVersion: autoscaling/v2
kind: HorizontalPodAutoscaler
  annotations:
    extendedhpa.metrics: '[{"type":"Resource","name":"cpu","targetType":"Utilization","targetRange":{"low":"30","high":"70"}}]'
    extendedhpa.option: '{"downscaleWindow":"5m","upscaleWindow":"3m"}'
  scaleTargetRef:
    kind: Deployment
    apiVersion: apps/v1
  minReplicas: 1
  maxReplicas: 100
  metrics:
    - type: Resource
      resource:
        target:
          type: Utilization
          averageUtilization: 50
Observing the Auto Scaling Process
  1. Check the cluster node status. In the following example, there are two nodes.
    # kubectl get node
    NAME            STATUS   ROLES    AGE     VERSION
    192.168.0.183   Ready    <none>   2m20s   v1.17.9-r0-CCE21.1.1.3.B001-17.36.8
    192.168.0.26    Ready    <none>   55m     v1.17.9-r0-CCE21.1.1.3.B001-17.36.8
    Check the HPA policy. The CPU usage of the target workload is 0%.
    # kubectl get hpa hpa-policy
    NAME         REFERENCE                TARGETS   MINPODS   MAXPODS   REPLICAS   AGE
    hpa-policy   Deployment/hpa-example   0%/50%    1         100       1          4m
  2. Run the following command to access the workload. In the following command, {ip:port} indicates the access address of the workload, which can be queried on the workload details page.
    while true;do wget -q -O- http://{ip:port}; done
    If no EIP is displayed, the cluster node has not been assigned any EIP. Allocate one, bind it to the node, and synchronize node data.
    Observe the scaling process of the workload.
    # kubectl get hpa hpa-policy --watch
    hpa-policy   Deployment/hpa-example   190%/50%   1         100       1          4m23s
    hpa-policy   Deployment/hpa-example   190%/50%   1         100       4          4m31s
    hpa-policy   Deployment/hpa-example   200%/50%   1         100       4          5m16s
    hpa-policy   Deployment/hpa-example   200%/50%   1         100       4          6m16s
    hpa-policy   Deployment/hpa-example   85%/50%    1         100       4          7m16s
    hpa-policy   Deployment/hpa-example   81%/50%    1         100       4          8m16s
    hpa-policy   Deployment/hpa-example   81%/50%    1         100       7          8m31s
    hpa-policy   Deployment/hpa-example   57%/50%    1         100       7          9m16s
    hpa-policy   Deployment/hpa-example   51%/50%    1         100       7          10m
    hpa-policy   Deployment/hpa-example   58%/50%    1         100       7          11m
    You can see that the CPU usage of the workload is 190% at 4m23s, which exceeds the target value. In this case, scaling is triggered to expand the workload to four replicas/pods. In the subsequent several minutes, the CPU usage does not decrease until 7m16s. This is because the new pods may not be successfully created. The possible cause is that resources are insufficient and the pods are in the pending state. During this period, nodes are being scaled out.
    At 7m16s, the CPU usage decreases, indicating that the pods are successfully created and start to bear traffic. The CPU usage decreases to 81% at 8m, still greater than the target value (50%) and the high threshold (70%). Therefore, 7 pods are added at 9m16s, and the CPU usage decreases to 51%, which is within the range of 30% to 70%. From then on, the number of pods remains 7.
    In the following output, you can see the workload scaling process and the time when the HPA policy takes effect.
    # kubectl describe deploy hpa-example
    Events:
      Type    Reason             Age    From                   Message
      Normal  ScalingReplicaSet  25m    deployment-controller  Scaled up replica set hpa-example-79dd795485 to 1
      Normal  ScalingReplicaSet  20m    deployment-controller  Scaled up replica set hpa-example-79dd795485 to 4
      Normal  ScalingReplicaSet  16m    deployment-controller  Scaled up replica set hpa-example-79dd795485 to 7
    # kubectl describe hpa hpa-policy
    Events:
      Normal  SuccessfulRescale  20m    horizontal-pod-autoscaler  New size: 4; reason: cpu resource utilization (percentage of request) above target
      Normal  SuccessfulRescale  16m    horizontal-pod-autoscaler  New size: 7; reason: cpu resource utilization (percentage of request) above target
    Check the number of nodes. The following output shows that two nodes are added.
    # kubectl get node
    192.168.0.120   Ready    <none>   3m5s    v1.17.9-r0-CCE21.1.1.3.B001-17.36.8
    192.168.0.136   Ready    <none>   6m58s   v1.17.9-r0-CCE21.1.1.3.B001-17.36.8
    192.168.0.183   Ready    <none>   18m     v1.17.9-r0-CCE21.1.1.3.B001-17.36.8
    192.168.0.26    Ready    <none>   71m     v1.17.9-r0-CCE21.1.1.3.B001-17.36.8
    You can also view the scaling history on the console. For example, the CA policy is executed once when the CPU allocation rate in the cluster is greater than 70%, and the number of nodes in the node pool is increased from 2 to 3. The new node is automatically added by autoscaler based on the pending state of pods in the initial phase of HPA.
    The node scaling process is as follows:
    1. After the number of pods changes to 4, the pods are in Pending state due to insufficient resources. As a result, the default scale-out policy of the autoscaler add-on is triggered, and the number of nodes is increased by one.
    2. The second node scale-out is triggered because the CPU allocation rate in the cluster is greater than 70%. As a result, the number of nodes is increased by one, which is recorded in the scaling history on the console. Scaling based on the allocation rate ensures that the cluster has sufficient resources.
  3. Stop accessing the workload and check the number of pods.
    hpa-policy   Deployment/hpa-example   50%/50%    1         100       7          12m
    hpa-policy   Deployment/hpa-example   21%/50%    1         100       7          13m
    hpa-policy   Deployment/hpa-example   0%/50%     1         100       7          14m
    hpa-policy   Deployment/hpa-example   0%/50%     1         100       7          18m
    hpa-policy   Deployment/hpa-example   0%/50%     1         100       3          18m
    hpa-policy   Deployment/hpa-example   0%/50%     1         100       3          19m
    hpa-policy   Deployment/hpa-example   0%/50%     1         100       3          23m
    hpa-policy   Deployment/hpa-example   0%/50%     1         100       1          23m
    You can see that the CPU usage is 21% at 13m. The number of pods is reduced to 3 at 18m, and then reduced to 1 at 23m.
    Events:
      Normal  ScalingReplicaSet  6m28s  deployment-controller  Scaled down replica set hpa-example-79dd795485 to 3
      Normal  ScalingReplicaSet  72s    deployment-controller  Scaled down replica set hpa-example-79dd795485 to 1
    Events:
      Normal  SuccessfulRescale  6m45s  horizontal-pod-autoscaler  New size: 3; reason: All metrics below target
      Normal  SuccessfulRescale  90s    horizontal-pod-autoscaler  New size: 1; reason: All metrics below target
    You can also view the HPA policy execution history on the console. Wait until the one node is reduced.
    The reason why the other two nodes in the node pool are not reduced is that they both have pods in the kube-system namespace (and these pods are not created by DaemonSets).
Summary
By using HPA and CA, auto scaling can be effortlessly implemented in various scenarios. Additionally, the scaling process of nodes and pods can be conveniently tracked.
