Help Center/
API Gateway/
User Guide (Kuala Lumpur Region)/
API Management/
Importing and Exorting APIs/
Extended Definition/
x-apigateway-any-method
Updated on 2024-08-07 GMT+08:00
Meaning: API request method used by default if no HTTP request method is specified.
Scope of effect: Path Item Object (2.0)/Path Item Object (3.0)
Example:
paths:
'/path':
get:
produces:
- application/json
responses:
"200":
description: "get response"
x-apigateway-any-method:
produces:
- application/json
responses:
"200":
description: "any response"
Parameter |
Mandatory |
Type |
Description |
x-apigateway-any-method |
No |
String |
Request method. |
Parent topic: Extended Definition
