- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Process of Using APIG
- Creating a User and Granting APIG Permissions
- Creating a Gateway
- Opening APIs
- (Optional) Configuring Authorization for API Calling
- Calling APIs
Managing APIs
- Overview
- Viewing or Modifying API Information
- Configuring Custom API Authentication
- Configuring API Parameter Orchestration Rules
- Customizing Error Response for APIs
- Cloning an API
- Taking an API Offline
- Importing and Exporting APIs
API Design File Extension Definitions
- x-apigateway-auth-type
- x-apigateway-request-type
- x-apigateway-match-mode
- x-apigateway-cors
- x-apigateway-is-send-fg-body-base64
- x-apigateway-any-method
- x-apigateway-backend
- x-apigateway-backend.parameters
- x-apigateway-backend.httpEndpoints
- x-apigateway-backend.httpVpcEndpoints
- x-apigateway-backend.functionEndpoints
- x-apigateway-backend.mockEndpoints
- x-apigateway-backend-policies
- x-apigateway-backend-policies.conditions
- x-apigateway-ratelimit
- x-apigateway-ratelimits
- x-apigateway-ratelimits.policy
- x-apigateway-ratelimits.policy.special
- x-apigateway-access-control
- x-apigateway-access-controls
- x-apigateway-access-controls.policy
- x-apigateway-plugins
- x-apigateway-auth-opt
- x-apigateway-result-normal-sample
- x-apigateway-result-failure-sample
- x-apigateway-authorizer
- x-apigateway-response
- x-apigateway-responses
- x-apigateway-pass-through
- x-apigateway-sample
- x-apigateway-content-type
- x-apigateway-orchestrations
- Configuring API Policies
- Configuring a Credential Policy
- Managing APIG Gateways
- Viewing Metrics and Configuring Alarms
- Viewing Audit Logs
- Shared Gateway (for Existing Users)
Best Practices
- Overview
API Openness
- Selectively Exposing CCE Workloads with a Dedicated Gateway
- Selectively Exposing Service Capabilities of a Data Center Using a Dedicated Gateway
- Exposing Backend Services Across VPCs Using a Dedicated Gateway
- Routing gRPC Service Requests Using a Dedicated Gateway
- Forwarding WebSocket Service Requests Using a Dedicated Gateway
- HTTP-to-HTTPS Auto Redirection with a Dedicated Gateway
- Calling Different Backend Services Using a Dedicated Gateway
- API Authentication
- API Policies
- API Security
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
Dedicated Gateway APIs (V2)
- API Group Management
- Environment Management
- Environment Variable Management
- Request Throttling Policy Management
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API or Taking an API Offline
- Querying API Details
- Querying APIs
- Verifying the API Definition
- Debugging an API
- Publishing APIs or Taking APIs Offline
- Querying Historical Versions of an API
- Switching the Version of an API
- Querying the Runtime Definition of an API
- Querying API Version Details
- Taking an API Version Offline
- Signature Key Management
- Binding/Unbinding Signature Keys
- Binding/Unbinding Request Throttling Policies
- Excluded Request Throttling Configuration
- App Authorization Management
- Resource Query
- Domain Name Management
- Access Control Policy Management
- Binding/Unbinding Access Control Policies
- Custom Authorizer Management
- API Import and Export
VPC Channel Management
- Creating a VPC Channel
- Updating a VPC Channel
- Deleting a VPC Channel
- Querying VPC Channel Details
- Querying VPC Channels
- Adding or Updating Backend Instances
- Querying Backend Servers of a VPC Channel
- Updating Backend Instances
- Removing a Backend Server
- Enabling Backend Servers
- Disabling Backend Servers
- Modifying VPC Channel Health Check
- Adding or Updating a Backend Server Group of a VPC Channel
- Querying Backend Server Groups of a VPC Channel
- Querying a Backend Server Group of a VPC Channel
- Deleting a Backend Server Group of a VPC Channel
- Updating a Backend Server Group of a VPC Channel
- Monitoring Information Query
- Group Response Management
- Tag Management
- Gateway Feature Management
- Configuration Management
Gateway Management
- Creating a Dedicated Gateway (Pay-Per-Use)
- Querying Dedicated Gateway Details
- Updating a Dedicated Gateway
- Querying the Creation Progress of a Dedicated Gateway
- Updating or Binding an EIP to a Dedicated Gateway
- Unbinding the EIP of a Dedicated Gateway
- Enabling Public Access for a Dedicated Gateway
- Updating the Outbound Access Bandwidth of a Dedicated Gateway
- Disabling Public Access for a Dedicated Gateway
- Enabling Public Inbound Access
- Updating Public Inbound Access Bandwidth of a Gateway
- Disabling Public Inbound Access for a Gateway
- Querying AZs
- Querying Dedicated Gateways
- Deleting a Dedicated Gateway
- Modifying the Specifications of a Pay-Per-Use Gateway
- Querying Gateway Constraints
- VPC Endpoint Management
- Gateway Tag Management
- Microservice Center Management
SSL Certificate Management
- Querying SSL Certificates
- Creating an SSL Certificate
- Binding a Domain Name with SSL Certificates
- Unbinding a Domain Name's SSL Certificates
- Querying Certificate Details
- Deleting an SSL Certificate
- Modifying an SSL Certificate
- Binding an SSL Certificate to a Domain Name
- Unbinding an SSL Certificate from a Domain Name
- Querying Domain Names of an SSL Certificate
Plug-in Management
- Creating a Plug-in
- Modifying a Plug-in
- Deleting a Plug-in
- Querying Plug-ins
- Querying Plug-in Details
- Binding a Plug-in to APIs
- Binding an API with Plug-ins
- Unbinding a Plug-in from All APIs
- Unbinding an API's Plug-ins
- Querying APIs Bound with a Plug-in
- Querying Plug-ins Bound to an API
- Querying APIs to Which a Plug-in Can Be Bound
- Querying Plug-ins That Can Be Bound to an API
Credential Management
- Creating an App
- Modifying an App
- Deleting an App
- Resetting the AppSecret of an App
- Verifying an App
- Querying App Details
- Querying Apps
- Creating an AppCode
- Generating an AppCode
- Deleting an AppCode
- Querying AppCode Details
- Querying AppCodes of an App
- Querying Quotas Associated with a Credential
- Configuring Access Control Settings for an App
- Querying Access Control Details About an App
- Deleting Access Control Settings of an App
Credential Quota Management
- Creating a Credential Quota
- Querying Credential Quota Details
- Querying Credential Quotas
- Modifying a Credential Quota
- Deleting a Credential Quota
- Querying the Credentials Bound to a Specified Quota
- Binding a Credential Quota with Credentials
- Unbinding a Credential Quota from a Credential
- Querying Credentials That Can Be Bound to a Credential Quota
- Asynchronous Task Management
- Orchestration Rule Management
- Gateway Custom Inbound Port Management
Shared Gateway APIs (for Existing Users)
API Management
- Object Model
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API
- Publishing Multiple APIs or Taking Multiple APIs Offline
- Querying an API List
- Querying Historical API Versions
- Taking an Effective Version of an API Offline
- Querying Details of an API Version
- Debugging an API
- App Management
- Binding Request Throttling Policies
Binding Access Control Policies
- Object Model
- Binding an Access Control Policy to an API
- Querying the List of Access Control Policies Bound to an API
- Querying the List of APIs Bound to an Access Control Policy
- Querying the List of APIs Not Bound to an Access Control Policy
- Unbinding an Access Control Policy from an API
- Unbinding Multiple Access Control Policies from APIs
- Querying Subscription Information in KooGallery
- Resource Query
- Binding Signature Keys
- VPC Channel Management
- Querying Metrics
- OpenAPI
- Appendix
- Change History
- SDK Reference
- Common FAQs
- Product Consulting FAQs
Opening APIs
- Why Can't I Create APIs?
- How Do I Define Response Codes for an API?
- Can I Specify a Private Network Load Balancer Address for the Backend Service?
- Can I Specify the Backend Address as a Subnet IP Address?
- Does APIG Support Multiple Backend Endpoints?
- Can I Bind Private Domain Names for API Access?
- Why Do I Fail to Call an API Across Domains?
- How Do I Use APIG to Open Up Services Deployed on Huawei Cloud?
- Publishing an API
Calling APIs
- What Are the Possible Causes for an API Calling Failure?
- Why Am I Seeing the Error Message "414 Request URI too large" When I Call an API?
- Why Am I Seeing the Error Message "The API does not exist or has not been published in the environment" When I Call an API?
- Why Am I Seeing the Error Message "No backend available" When I Call an API?
- Why Am I Seeing the Error Message "Backend unavailable" or "Backend timeout" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Backend domain name resolution failed" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Incorrect IAM authentication information" When I Call an API?
- Why Am I Seeing the Error Message "Incorrect app authentication information" When I Call an API?
- Why Doesn't Modification of the backend_timeout Parameter Take Effect?
- Does APIG Have a Limit on the Size of the API Request Body?
- Is There a Limit on the Size of the Response to an API Request?
- How Do I Call an API Using App Authentication in iOS System?
- Why Can't I Create a Header Parameter Named x-auth-token for an API Called Through IAM Authentication?
- Can Mobile Apps Call APIs?
- Can Applications Deployed in a VPC Call APIs?
- Does APIG Support WebSocket Data Transmission?
- How Will the Requests for an API with Multiple Backend Policies Be Matched and Executed?
- How Can I Access Backend Services over Public Networks Through APIG?
API Policies
- Can I Configure the Maximum Number of Concurrent Requests?
- Is the Restriction of 1,000 Requests Per Day to a Debugging Domain Name Applied to Enterprise Accounts?
- Does APIG Have Bandwidth Limits?
- Why Doesn't a Request Throttling Policy Take Effect?
- How Do I Provide an Open API to Specific Users?
- Are Client IP Addresses Verified for Access Control?
- Videos
More Documents
- Getting Started
- Comparing Versions
- Overview
API Management
- Creating an API Group
- Creating an Environment Variable
- Creating a Gateway Response
- Creating an API
- Cloning an API
- CORS
- Debugging an API
- Authorizing API Access
- Publishing an API
Importing and Exorting APIs
- Restrictions and Compatibility
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- Monitoring & Analysis
- Gateway Management
- SDKs
- Published API Calling
- Permissions Management
- Auditing
- Common FAQs
API Creation
- How Do I Specify the Host Port for a VPC Channel (or Load Balance Channel)?
- How Do I Set the Backend Address If I Will Not Use a VPC Channel (or Load Balance Channel)?
- How Can I Configure the Backend Service Address?
- What Should I Do After Applying for an Independent Domain Name?
- Why Does an API Failed to Be Called Across Domains?
API Calling
- What Should I Do If an Error Code Is Returned During API Calling?
- What Should I Do If "The API does not exist or has not been published in the environment." Is Displayed?
- Why Am I Seeing the Message "No backend available"?
- What Are the Possible Causes If the Message "Backend unavailable" or "Backend timeout" Is Displayed?
- Why Am I Seeing the Message "Backend domain name resolution failed" When a Backend Service Is Called?
- How Do I Switch the Environment for API Calling?
- What Is the Maximum Size of an API Request Package?
- How Do I Perform App Authentication in iOS System?
- App (Credential) FAQs
- Does APIG Support Persistent Connections?
API Authentication
- Does APIG Support HTTPS Two-Way Authentication?
- How Do I Call an API That Does Not Require Authentication?
- Which TLS Versions Does APIG Support?
- Does APIG Support Custom Authentication?
- Will the Request Body Be Signed for Security Authentication?
- Common Errors Related to IAM Authentication Information
- What Should I Do If the App Authentication Information Is Incorrect?
- API Control Policies
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (Kuala Lumpur Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- Appendix
- Change History
- Getting Started
- Overview
API Management
- Importing a CCE Workload
- Creating an API
- Creating a gRPC API
- Cloning an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- SDKs
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- This API is used to creat a credential quota.
- Appendix
- Change History
Best Practices (ME-Abu Dhabi Region)
- Developing a Custom Authorizer with FunctionGraph
- Interconnecting a Dedicated Gateway with WAF
- Request Throttling 2.0 with a Dedicated Gateway
- Two-Factor Authentication with a Dedicated Gateway
- Client Authentication with a Dedicated Gateway
- Invoking an API Policy Backend via Frontend Authentication Parameters (System Parameter)
- Forwarding WebSocket Services Using Dedicated Gateway
- Change History
- User Guide (Paris Region)
Developer Guide (Paris Region)
- Application Scenarios
- Calling APIs Through App Authentication
- Calling APIs Through IAM Authentication
- Creating Signatures for Backend Requests
- Extended Definition
- API Import Precautions
- Examples of Importing APIs
- API Export Precautions
- Change History
API Reference (Paris Region)
- Before You Start
- Calling APIs
- Getting Started
Shared Gateway APIs
API Management
- Object Model
- Registering an API
- Modifying an API
- Deleting an API
- Publishing an API
- Debugging an API
- App Management
- Object Model
- Querying Subscription Information in the Marketplace
- Resource Query
- OpenAPI
- Appendix
- Change History
Dedicated API Gateway User Guide (Paris Region)
- Getting Started
- Overview
API Management
- Creating an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- API Policies
- Credentials
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Dedicated API Gateway Developer Guide (Paris Region)
Dedicated API Gateway API Reference (Paris Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- App Management
- Tag Management
Gateway Management
- Querying AZs
- Appendix
- Change History
Importing APIs
You can import Swagger and OpenAPI APIs to a new or existing API group on APIG. Before importing APIs, complete the extended definition of APIG.
Precautions for Importing APIs to a New Group
When you import APIs to a new API group, the system creates an API group.
This function is suitable for importing new APIs to APIG.
Before importing APIs, ensure that the following requirements are met:
- Your API group and API quotas are sufficient.
- Use the title property in Swagger info and OpenAPI info to specify an API group name. The name of a new API group cannot be the same as that of an existing one.
- If a conflict exists when you import APIs, the former API is imported successfully and the latter API cannot be imported. For example, if two APIs with the same name or request path exist in the imported API definition, a success message is displayed for the first imported API, and a failure message is displayed for the API to be imported subsequently.
- If Extended Definition Overwrite is selected, the extended definition items (access control and request throttling policies) of an imported API will overwrite the existing extended definition items with the same name.
- Imported APIs will not be automatically published in an environment. You can choose to publish them immediately or later.
Precautions for Importing APIs to an Existing Group
When you import APIs to a specified API group, the system adds them to the API group while retaining the existing APIs.
This function is suitable for importing new or modified APIs to an existing API group.
- Your API quota is sufficient.
- If the definition of an API you are importing is the same as that of an existing API, you can overwrite the existing API or retain it. If you leave the existing API alone, the new API will not be imported.
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- Choose API Management > APIs.
- Click Import APIs. For details, see Importing an API Design File.
You can also import APIs to APIG by referring to the following examples:
Importing an HTTP Backend Service API
Import the request parameter definition of an HTTP backend service API that uses the GET method and is accessed through IAM authentication.
Swagger example:
swagger: "2.0" info: title: "importHttpEndpoint10" description: "import apis" version: "1.0" host: "api.account.com" paths: '/http/{userId}': get: operationId: "getUser3" description: "get user by userId" security: - apig-auth-iam: [] schemes: - https parameters: - name: "test" description: "authorization token" type: "string" in: "header" required: true - name: "userId" description: "user id" type: "string" in: "path" required: true responses: "200": description: "user information" x-apigateway-request-type: "public" x-apigateway-cors: true x-apigateway-match-mode: "NORMAL" x-apigateway-backend: type: "HTTP" parameters: - name: "userId" value: "userId" in: "query" origin: "REQUEST" description: "user id" - name: "X-Invoke-User" value: "apigateway" in: "header" origin: "CONSTANT" description: "invoke user" httpEndpoints: address: "example.com" scheme: "http" method: "GET" path: "/users" timeout: 30000 securityDefinitions: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM
OpenAPI example:
openapi: 3.0.0 info: title: importHttpEndpoint10 version: '1.0' servers: - url: >- http://abc.com - url: >- https://abc.com paths: '/http/{userId}': get: description: get user by userId operationId: getUser3 parameters: - description: authorization token example: '' in: header name: test required: true schema: maxLength: 0 maximum: 0 minimum: 0 type: string x-apigateway-pass-through: always - description: user id example: '' in: path name: userId required: true schema: maxLength: 0 maximum: 0 minimum: 0 type: string x-apigateway-pass-through: always responses: default-cors: description: response example x-apigateway-result-failure-sample: '' x-apigateway-result-normal-sample: '' security: - apig-auth-iam: [] servers: - url: >- https://abc.com x-apigateway-backend: httpEndpoints: address: example.com description: '' enableClientSsl: false method: GET path: /users retryCount: '-1' scheme: http timeout: 30000 parameters: - description: invoke user in: HEADER name: X-Invoke-User origin: CONSTANT value: apigateway - description: user id in: QUERY name: userId origin: REQUEST value: userId type: HTTP x-apigateway-cors: true x-apigateway-match-mode: NORMAL x-apigateway-request-type: public x-apigateway-response: default components: responses: default-cors: description: response example headers: Access-Control-Allow-Origin: schema: default: '*' type: string securitySchemes: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-app-header: in: header name: Authorization type: apiKey x-apigateway-auth-opt: appcode-auth-type: header x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM x-apigateway-responses: default: {}
Importing an HTTP VPC Backend Service API
Import the request parameter definition of an HTTP VPC backend service API that uses the ANY method and is accessed through app authentication.
Swagger example:
swagger: "2.0" info: title: "importHttpVpcEndpoint" description: "import apis" version: "1.0" host: "api.account.com" paths: '/http-vpc': x-apigateway-any-method: operationId: "userOperation" description: "user operation resource" security: - apig-auth-app: [] schemes: - https parameters: - name: "Authorization" description: "authorization signature" type: "string" in: "header" required: true responses: "default": description: "endpoint response" x-apigateway-request-type: "public" x-apigateway-cors: true x-apigateway-match-mode: "SWA" x-apigateway-backend: type: "HTTP-VPC" parameters: - name: "X-Invoke-User" value: "apigateway" in: "header" origin: "CONSTANT" description: "invoke user" httpVpcEndpoints: name: "userVpc" scheme: "http" method: "GET" path: "/users" timeout: 30000 securityDefinitions: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM
OpenAPI example:
openapi: 3.0.0 info: description: import apis title: importHttpVpcEndpoint version: '1.0' servers: - url: >- http://abc.com - url: >- https://abc.com paths: /http-vpc: x-apigateway-any-method: description: user operation resource operationId: userOperation parameters: - description: authorization signature example: '' in: header name: Authorization required: true schema: maxLength: 0 maximum: 0 minimum: 0 type: string x-apigateway-pass-through: always responses: default-cors: description: response example x-apigateway-result-failure-sample: '' x-apigateway-result-normal-sample: '' security: - apig-auth-app: [] servers: - url: >- https://abc.com x-apigateway-backend: httpVpcEndpoints: cascade_flag: false description: '' enableClientSsl: false method: GET name: userVpc path: /users retryCount: '-1' scheme: http timeout: 30000 parameters: - description: invoke user in: HEADER name: X-Invoke-User origin: CONSTANT value: apigateway type: HTTP-VPC x-apigateway-cors: true x-apigateway-match-mode: SWA x-apigateway-request-type: public components: responses: default-cors: description: response example headers: Access-Control-Allow-Origin: schema: default: '*' type: string securitySchemes: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-app-header: in: header name: Authorization type: apiKey x-apigateway-auth-opt: appcode-auth-type: header x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM x-apigateway-responses: {}
Importing a Function Backend Service API
Import the request parameter definition of a FunctionGraph backend service API that uses the GET method and is accessed through IAM authentication.
Swagger example:
swagger: "2.0" info: title: "importFunctionEndpoint" description: "import apis" version: "1.0" host: "api.account.com" paths: '/function/{name}': get: operationId: "invokeFunction" description: "invoke function by name" security: - apig-auth-iam: [] schemes: - https parameters: - name: "test" description: "authorization token" type: "string" in: "header" required: true - name: "name" description: "function name" type: "string" in: "path" required: true responses: "200": description: "function result" x-apigateway-request-type: "public" x-apigateway-cors: true x-apigateway-match-mode: "NORMAL" x-apigateway-backend: type: "FUNCTION" parameters: - name: "functionName" value: "name" in: "query" origin: "REQUEST" description: "function name" - name: "X-Invoke-User" value: "apigateway" in: "header" origin: "CONSTANT" description: "invoke user" functionEndpoints: function-urn: "your function urn address" version: "your function version" invocation-type: "async" timeout: 30000 securityDefinitions: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM
OpenAPI example:
openapi: 3.0.0 info: description: import apis title: importHttpEndpoint version: '1.0' servers: - url: >- http://api.account.com - url: >- https://api.account.com paths: /function/{name}: get: description: invoke function by name operationId: invokeFunction parameters: - description: function name in: path name: name required: true schema: maxLength: 0 maximum: 0 minimum: 0 type: string x-apigateway-pass-through: always example: '' - description: authorization token in: header name: test required: true schema: maxLength: 0 maximum: 0 minimum: 0 type: string x-apigateway-pass-through: always example: '' responses: default-cors: description: response example x-apigateway-result-failure-sample: '' x-apigateway-result-normal-sample: '' security: - apig-auth-iam: [] servers: - url: >- https://api.account.com x-apigateway-backend: functionEndpoints: alias-urn: '' description: '' function-urn: "your function urn address" invocation-type: async network-type: V1 timeout: 30000 version: "your function version" parameters: - description: invoke user in: HEADER name: X-Invoke-User origin: CONSTANT value: apigateway - description: function name in: QUERY name: functionName origin: REQUEST value: name type: FUNCTION x-apigateway-cors: true x-apigateway-match-mode: NORMAL x-apigateway-request-type: public x-apigateway-response: default components: responses: default-cors: description: response example headers: Access-Control-Allow-Origin: schema: default: '*' type: string securitySchemes: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM x-apigateway-responses: default: {}
Importing a Mock Backend Service API
Import the definition of a Mock backend service API that uses the GET method and is accessed without authentication.
Swagger example:
swagger: "2.0" info: title: "importMockEndpoint" description: "import apis" version: "1.0" host: "api.account.com" paths: '/mock': get: operationId: "mock" description: "mock test" schemes: - http responses: "200": description: "mock result" x-apigateway-request-type: "private" x-apigateway-cors: true x-apigateway-match-mode: "NORMAL" x-apigateway-backend: type: "MOCK" mockEndpoints: result-content: "{\"message\": \"mocked\"}" securityDefinitions: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM
OpenAPI example:
openapi: 3.0.0 info: description: import apis title: importHttpVpcEndpoint version: '1.0' servers: - url: >- http://abc.com - url: >- https://abc.com paths: /mock: get: description: mock test operationId: mock responses: default-cors: description: response example x-apigateway-result-failure-sample: '' x-apigateway-result-normal-sample: '' servers: - url: >- http://abc.com x-apigateway-backend: mockEndpoints: description: '' result-content: '{"message": "mocked"}' type: MOCK x-apigateway-cors: true x-apigateway-match-mode: NORMAL x-apigateway-request-type: private x-apigateway-response: default components: responses: default-cors: description: response example headers: Access-Control-Allow-Origin: schema: default: '*' type: string securitySchemes: apig-auth-app: in: header name: Authorization type: apiKey x-apigateway-auth-type: AppSigv1 apig-auth-app-header: in: header name: Authorization type: apiKey x-apigateway-auth-opt: appcode-auth-type: header x-apigateway-auth-type: AppSigv1 apig-auth-iam: in: header name: unused type: apiKey x-apigateway-auth-type: IAM x-apigateway-responses: default: {}
Follow-Up Operations
Publish the imported APIs in an environment so that they can be called by users.
