Help Center/
      API Gateway/
        User Guide (Kuala Lumpur Region)/
        Getting Started/
        Opening APIs/
      (Optional) Creating an Environment
        Updated on 2024-08-07 GMT+08:00
- In the navigation pane, choose API Management > API Policies. Then click the Environments tab.
 - Click Create Environment and set the environment information.
Table 1 Environment information Parameter
Name
Environment name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the environment.
 - Click OK.
   Parent topic: Opening APIs
