- Encrypt the MySQL password.
   - Log in to the MySQL server and run the cd /home/rdadmin/Agent/bin/ command to go to the Agent directory.
- Run the /home/rdadmin/Agent/bin/agentcli encpwd command. The following information is displayed:
     Enter password: Enter the MySQL password and press Enter. After the encrypted password is displayed, copy it to the clipboard.
- Run the cd /home/rdadmin/Agent/bin/thirdparty/ebk_user command to go to the directory saving the custom scripts and run the vi mysql_freeze.sh command to open the example MySQL freezing script.
   The following figure shows an example. Set MYSQL_USER and MYSQL_PASSWORD based on your actual conditions, where MYSQL_PASSWORD should be the encrypted password obtained in 1.  You can also run the sed command to modify the configuration: sed -i 's/^MYSQL_PASSWORD=.*/MYSQL_PASSWORD="XXX"/' mysql_freeze.sh mysql_unfreeze.sh, where XXX indicates the password obtained in step 1. If you run this command, both the freezing and unfreezing scripts will be modified and therefore 3 is not needed.
- Run the vi mysql_unfreeze.sh command to open the example MySQL unfreezing script and change the username and password in the script to be consistent with your actual settings.
   The mysql_unfreeze.sh and mysql_freeze.sh scripts can only be used to freeze and unfreeze databases. If other operations are required, you can add them in the scripts via compilation. For details, see Using a Custom Script to Implement Consistent Backup for Other Linux Applications.   MySQL is frozen by running the FLUSH TABLES WITH READ LOCK command. This command will not trigger disk flushing on bin log. If bin log is enabled and the value of sync_binlog is not 1, some SQL operations saved in the backup image may not be recorded in bin log. To realize complete protection on bin log, set sync_binlog to 1.
