Updated on 2026-07-15 GMT+08:00
Anthropic-compatible APIs
This function is only supported in CN-Hong Kong.
API Information
Example Value
API URL
API URL for calling the model service.
https://api-ap-southeast-1.modelarts-maas.com/anthropic/v1/messages
Authentication request header
Provides the server with identity authentication/authorization credentials.
"x-api-key": "$MaaS_API_Key"
Supported Models
You can log in to the MaaS console and enable the following models on the Model Inference > Real-Time Inference > Built-in Services page. On the model details page in the Model Square, you can view detailed information about the models.
Model
Version
Supported Region
Value of model
GLM
GLM-5
CN-Hong Kong
glm-5
GLM-5.1
CN-Hong Kong
glm-5.1
GLM-5.2
CN-Hong Kong
glm-5.2
DeepSeek
DeepSeek-V4-Pro
CN-Hong Kong
deepseek-v4-pro
DeepSeek-V4-Flash
CN-Hong Kong
deepseek-v4-flash
DeepSeek-V3.1
CN-Hong Kong
deepseek-v3.1-terminus
DeepSeek-V3
CN-Hong Kong
DeepSeek-V3
DeepSeek-V3.2
CN-Hong Kong
deepseek-v3.2
DeepSeek-R1-0528
CN-Hong Kong
deepseek-r1-250528
Request Parameters
Category
Type
Mandatory
Range
General
model
string
Yes
Model ID being requested.
Default value: N/A
system
string
No
System prompt, which can be used to assign a specific goal or role to the model.
Default value: N/A
messages
object[]
Yes
List of messages in a dialog. Different models support different types of messages.
Default value: N/A
messages.role
enum<string>
Yes
  • assistant
  • user
Role that sends a message.
Default value: N/A
messages.content
string/array
Yes
Message sent by the current role.
Default value: N/A
messages.content.type
enum<string>
Yes
  • text
  • tool_use
  • tool_result
Message type.
Default value: N/A
Tool call result section (When messages.content.type is set tool_result)
messages.content.tool_use_id
string
Yes
Tool call ID.
Default value: N/A
messages.content.content
string
No
Result obtained after the tool is called.
Default value: N/A
Deep thinking control
thinking
object
No
Controls whether to enable the deep thinking mode for a model.
Default value: N/A
thinking.type
string
Yes
  • enabled
  • disabled
  • enabled: The thinking mode is enabled. The model must think before answering.
  • disabled: The thinking mode is disabled. The model directly answers questions without thinking.
Default value: The default value varies depending on the model. For details, see Thinking Control for Deep Thinking Models.
Model output behavior configuration
max_tokens
integer/null
No
The value varies depending on the model. For details, see the maximum output length and maximum CoT length on the model details page.
Maximum length of the model answer (only the content part). After this parameter is set, the token length of the model output content does not exceed the value of max_tokens.
Default Value: 4K
temperature
number
No
[0.0, 1.0]
top_p
float/null
No
(0,1]
Nucleus sampling probability threshold, used to control the diversity of the content generated by the model. Similar to the temperature parameter but operates differently, allowing finer control over the vocabulary range of the model's output.
  • When set close to 0, the model samples from only the most probable tokens, resulting in very conservative and highly deterministic outputs.
  • When set close to 1, there is virtually no restriction on the vocabulary, leading to more random and divergent outputs.
It is advised to adjust either temperature or top_p, but not both simultaneously.
Default value:
  • DeepSeek-V4: In thinking mode, the value is always 1.0, regardless of the user input.
  • This parameter is not applicable to other models.
stream
boolean/null
No
Determines if the response content is returned in a streaming manner.
  • false: Returns results once all content has been generated by the model.
  • true: Returns content piece by piece, ending with data: [DONE].
Default value: false
stop_sequences
string[]
No
null
Stops the model from generating content when it encounters the string specified in the stop_sequences field.
The stop token does not hit the token in the CoT, but only hits the part in the formal answer content.
Default value: N/A
reasoning_effort
string
No
  • high
  • max
Tool calls
tools
array
No
List of tools to be calls.
Default value: N/A
tools.name
string
Yes
Name of the function to be called.
Default value: N/A
tools.description
string
No
Description of the function to be called. The foundation model will determine whether to call this tool based on this description.
Default value: N/A
tools.input_schema
object
No
Function request parameters, described in JSON format. Example:
  "type": "object",
  "properties": {
    "parameter name": {
      "type": "parameter type",
      "description": "parameter description"
  "required": ["mandatory parameters"]
Parameters must conform to JSON specifications.
Default value: N/A
Response Parameters (Non-Streaming)
Type
id
string
Unique ID of the response object.
type
enum<string>
For the message type, the value is message.
role
string
Role of the output content.
model
string
Name and version of the model used in this request.
content
array
Model-generated content.
content.type
enum<string>
Type of the generated content.
Deep thinking response (type: thinking)
content.thinking
string
Deep thinking content of the model.
content.signature
string
Complete thinking content encrypted and returned in the signature field.
Formal reply response (type: text)
content.text
string
Formal reply content of the model.
Tool input response (type: tool_use)
content.id
string
Tool call ID.
content.name
string
Name of the tool to be called.
content.input
object
Structured input information required for tool calls.
Other parts
stop_reason
enum<string>/null
Reason why the model stops generating tokens. Range:
  • end_turn: The model output ends naturally.
  • max_tokens: The model output triggers the max_tokens limit.
  • stop_sequence: The model output token matches the token in stop_sequence.
  • tool_use: The model determines that a tool needs to be called.
stop_sequence
string/null
Indicates which custom stop_sequence was matched. Returns null if none were matched.
usage
object
Token usage of this request.
usage.output_tokens
integer
Tokens spent on the model's output content.
usage.input_tokens
integer
Number of tokens input to the model for processing.
Response Parameters (Streaming)
Type
event
Options:
  • message_start: first chunk.
  • content_block_delta: Contains the text of the formal reply, input_json for tool calls, and thinking of deep thinking.
  • content_block_stop: Indicates that a segment of content has been fully output.
  • message_delta: Contains stop_reason, stop_sequence, and usage information.
  • message_stop: Indicates that all messages have been returned.
event: message_start
type
string
Type of the chunk.
message
object[]
Response message.
message.id
string
Unique ID of a request.
message.type
string
Response message type. The value is message.
message.role
string
Role of the information.
message.model
string
ID of the called model.
message.stop_sequence
string/null
Hit stop sequence.
message.usage
object
Token usage statistics of the current request.
message.usage.input_tokens
integer
Number of input tokens.
message.usage.output_tokens
integer
Number of output tokens.
message.content
array
Content output by the model.
message.stop_reason
enum<string>/null
Reason why the model stops outputting.
event: content_block_start
type
string
Type of the chunk.
index
integer
Index of the current element.
content_block
object
Content output module of the model.
content_block.type
string
Output content type.
content_block.thinking
string
content_block.text
string
content_block.id
string
Tool call ID.
content_block.name
string
content_block.input
object
event: content_block_delta
type
string
Type of the chunk.
index
integer
delta
object
Incremental output from the model.
delta.type
string
Incremental content type.
delta.text
string
Incremental text output from the model.
delta.partial_json
string
JSON data required for tool calls during model streaming.
event: content_block_stop
type
string
Type of the chunk.
index
integer
event: message_delta
type
string
Type of the chunk.
delta
object
Incremental content of the message.
delta.stop_sequence
string/null
Hit stop sequence.
delta.stop_reason
string
usage
enum<string>/null
usage.output_tokens
integer
event: message_stop
type
string
Type of the chunk.
event: ping
type
string
Type of the chunk.
Model
thinking.type Default Value
thinking.type Options
GLM-5.2
GLM-5.1
GLM-5
enabled
  • enabled
  • disabled
DeepSeek-V4-Flash
DeepSeek-V4-Pro
enabled
  • enabled
  • disabled
DeepSeek-R1-0528
enabled
enabled
DeepSeek-V3.1
DeepSeek-V3.2
disabled
  • enabled
  • disabled
Tool Choices for Models
Model
Supported Tool Choice
GLM-5.1
GLM-5.2
  • none
  • auto
  • named
GLM-5
  • none
  • auto
DeepSeek-V4-Flash
DeepSeek-V4-Pro
DeepSeek-V3.2
DeepSeek-R1-0528
  • none
  • auto
  • named
DeepSeek-V3
DeepSeek-V3.1
  • auto
  • named
