Updated on 2026-08-20 GMT+08:00
MaaS Standard API V1
This chapter describes the specifications for calling chat APIs.
MaaS Standard API V1 is no longer evolving; prioritize the use of MaaS Standard API V2.
API Information
Table 1 API information
Example Value
API URL
API URL for calling the model service.
https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions
model
model parameter in an API call
For details about the value of model, see How Do I Obtain Model Parameters?
Creating a Chat Request
  • Authentication description
    MaaS inference services support API key authentication. The authentication header is in the following format:
    'Authorization': 'Bearer API key of the region where the service is deployed'
  • The request and response parameters are as follows.
    Table 2 Request parameters
    Mandatory
    Type
    model
    Yes
    String
    Definition
    Model parameter to call. For details about the value, see Table 1.
    N/A
    Range
    N/A
    Default Value
    N/A
    messages
    Yes
    Array
    Definition
    Input question. role shows the role, and content shows the dialog content. Example:
    "messages": [
        {"role": "system","content": "You are a helpful AI assistant."},
        {"role": "user","content": "Which number is larger, 9.11 or 9.8?"}
    For more information, see Table 3.
    N/A
    messages.prefix
    No
    Boolean
    Definition
    Controls whether to enable continuation mode. In this mode, the user provides a message starting with assistant, and the model completes the rest based on that beginning and the input instruction.
    To use this feature, ensure that the last message in the messages list has the role set to assistant and the prefix parameter set to true. Example:
    messages = [ {"role": "user", "content": "Write a snippet of Python code"}, {"role": "assistant", "content": "```python\n", "prefix": True} ]
    Range
    • True: Enable prefix continuation.
    • False: Disable prefix continuation.
    Default Value
    False
    stream_options
    No
    Object
    Definition
    Specifies whether to display the number of used tokens during streaming output.
    This parameter is only valid when stream is set to True. You need to set stream_options to {"include_usage": true} to print the number of tokens used. For more information, see Table 4.
    max_tokens
    No
    Int
    Definition
    Maximum number of tokens that can be generated for the current task, including tokens generated by the model and reasoning tokens for deep thinking.
    N/A
    Range
    The value varies depending on the model. For details, see the maximum output length on the model details page of the MaaS console.
    Default Value
    N/A
    top_k
    No
    Int
    Definition
    Controls the model to select only from the top k most probable tokens, influencing the randomness of the generated text. Higher values increase randomness, while lower values enhance determinism.
    N/A
    Range
    >=0
    Default Value
    N/A
    top_p
    No
    Float
    Definition
    Nucleus sampling probability threshold, used to control the diversity of the content generated by the model. Similar to the temperature parameter, it influences randomness, but offers finer control by dynamically adjusting the pool of possible tokens.
    Setting this value near 0 restricts sampling to the highest-probability tokens, yielding highly predictable and deterministic text. Setting this value near 1 allows the model to sample from virtually the entire vocabulary, resulting in higher randomness and more creative, divergent outputs.
    It is recommended that you adjust either temperature or top_p.
    Range
    (0,1.0]
    Default Value
    1.0: All tokens are considered.
    temperature
    No
    Float
    Definition
    Model sampling temperature. The higher the value, the more random the model output; the lower the value, the more deterministic the output.
    Adjust either temperature or top_p separately for best results, not both at once.
    Range
    0 to 2.0
    Recommended value: 0.6 for Qwen3 series models.
    Default Value
    1.0
    stop
    No
    None/String/List
    Definition
    A list of strings used to stop generation. The output does not contain the stop strings.
    For example, if the value is set to ["You," "Good"], text generation will stop once either You or Good is reached.
    N/A
    stream
    No
    Boolean
    Definition
    Controls whether to enable streaming inference.
    N/A
    Range
    • False: Disable streaming inference.
    • true: Enable streaming inference.
    Default Value
    False
    n
    No
    Int
    Number of responses generated for each input message.
    • If beam_search is not used, the recommended value range of n is 1 ≤ n ≤10. If n is greater than 1, ensure that greedy_sample is not used for sampling, that is, top_k is greater than 1 and temperature is greater than 0.
    • If beam_search is used, the recommended value range of n is 1 < n ≤ 10. If n is 1, the inference request will fail.
      • For optimal performance, keep n at 10 or below. Large values of n can significantly slow down processing. Insufficient VRAM may cause inference requests to fail.
    use_beam_search
    No
    Boolean
    Definition
    Controls whether to use beam_search to replace sampling.
    When this parameter is used, the following parameters must be configured as required:
    • n: > 1
    • top_p: 1.0
    • top_k: -1
    • temperature: 0.0
    Range
    • False: Do not replace sampling with beam search.
    • True: Replace sampling with beam search.
    Default Value
    False
    presence_penalty
    No
    Float
    Definition
    Presence penalty coefficient, which is an important parameter used to control the diversity of model outputs. This reduces the probability that the model will repeatedly use previously mentioned tokens or topics, thereby encouraging it to generate new content.
    As long as a token has appeared at least once in the previously generated text, the model imposes a fixed penalty on it to reduce the probability of it being selected again. The model determines this penalty based solely on whether the token has appeared so far. A positive value increases the likelihood of the model generating novel content.
    N/A
    Range
    [-2,2]
    • 0: No penalty is applied.
    • Positive value: Increases the penalty. A larger value makes the model more likely to introduce new tokens and topics to avoid repetition.
    • Negative value: Reduces the penalty (acting as a reward). The model becomes more inclined to reuse previously generated words, which often results in repetitive and verbose text (generally not recommended).
    Default Value
    0.0
    frequency_penalty
    No
    Float
    Definition
    Frequency penalty coefficient, which is an important parameter used to control the diversity of model outputs.
    The probability of a token reappearing decreases proportionally based on its frequency in the generated text. The more frequently a token appears, the lower its likelihood of being used again.
    N/A
    Range
    [-2.0,2.0]
    Default Value
    0.0
    length_penalty
    No
    Float
    Definition
    Imposes a larger penalty on longer sequences in a beam search process.
    • top_k: -1
    • use_beam_search: true
    • best_of: > 1
    Range
    N/A
    Default Value
    1.0
    thinking
    No
    Object
    Definition
    Controls whether to enable the deep thinking mode for a model.
    N/A
    thinking.type
    Yes
    String
    Definition
    N/A
    Range
    • enabled: The deep thinking mode is enabled. The model must think before answering.
    • disabled: The deep thinking mode is disabled. The model directly answers questions without thinking.
    Default Value
    The default value varies depending on the model. You can log in to the MaaS console and view the description of the deep thinking mode in the Version area on the Model Square > Model Details page.
    Table 3 Request parameter messages
    Mandatory
    Type
    role
    Yes
    String
    Definition
    Role that sends a message.
    N/A
    Range
    • system: developer-entered instructions like response formats and roles for the model to follow.
    • user: user-entered messages including prompts and context information.
    • assistant: responses generated by the model.
    • tool: information returned by the tool when the model calls it.
    Default Value
    N/A
    content
    Yes
    String
    Definition
    Message content of the corresponding role.
    N/A
    Range
    • When role is set to system, this parameter indicates the AI model's personality.
        "role": "system",
    • When role is set to user, this parameter indicates the question asked by the user.
      • Text-based dialogue:
          "role": "user",
          "content": "Which one is larger, 9.11 or 9.8?"
      • Image understanding:
        Supported image formats: PNG, JPEG, JPG, WEBP, BMP, and TIFF.
        Supported input methods: You can use either the Base64-encoded content of the image or a publicly accessible image URL. Below are code examples for both methods:
        • Using Base64-encoded image content:
            "role": "user",
            "content": [
                "type": "image_url",
                "image_url": {
                  "url": f"data:image/png;base64,{base64_image}"
                "type": "text",
                "text": "What does the image show?"
          The Base64-encoded image format (image/{format}) must match the Content Type in the supported image list. The f denotes a string formatting method used to embed the Base64-encoded image data into the URL. Example:
          # PNG image
          # JPEG image
          f"data:image/jpeg;base64,{base64_image}"
          # WEBP image:
          f"data:image/webp;base64,{base64_image}"
        • Using a publicly accessible image URL:
            "role": "user",
            "content": [
                "image_url": {
                  "url": "https://example.com/xxx.jpeg"
                "type": "text",
    • When role is set to assistant, this parameter indicates the content generated by the AI model.
      {"role": "assistant","content": "9.11 is larger than 9.8."}
    • When role is set to tool, this parameter indicates the responses returned by the tool when the model calls it.
      {"role": "tool", "content": "The weather in Shanghai is sunny today. The temperature is 10°C."}
    Default Value
    N/A
    Table 4 Request parameter stream_options
    Mandatory
    Type
    include_usage
    No
    Boolean
    Definition
    Specifies whether the streaming response includes token usage information.
    N/A
    Range
    • True: The token usage information is included in the response. Each chunk contains a usage field that shows the total token usage.
    • False: The token usage information is not included in the response.
    Default Value
    True
    Table 5 Response parameters
    Type
    id
    String
    Definition
    Unique identifier of this request.
    Range
    N/A
    object
    String
    Definition
    Dialog type.
    Range
    chat.completion
    created
    Int
    Definition
    Time when the request is created, in timestamp format, for example, 1782271333.
    Range
    N/A
    model
    String
    Definition
    Model parameter used in this request.
    Range
    choices
    Array
    Definition
    Model output, including the index and message parameters. In message:
    • content is the model's final reply.
    • reasoning content is the model's deep thinking content (for DeepSeek models only).
    usage
    Object
    Definition
    Statistics on tokens consumed by this request:
    • prompt tokens: number of input tokens.
    • completion tokens: number of output tokens.
    • total tokens: total number of tokens (including input and output tokens).
    prompt_logprobs
    Float
    Definition
    Log probability. You can use this to measure the model's confidence in its output or to explore other options the model provides.
    Range
    N/A
