Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Network/ Ingresses/ LoadBalancer Ingresses/ Configuring a LoadBalancer Ingress Using Annotations
You can add annotations to a YAML file for more advanced ingress functions. This section describes the annotations that can be used when you create a LoadBalancer ingress.
Interconnection with ELB
Table 1 Annotations for interconnecting with ELB
Type
Supported Cluster Version
kubernetes.io/elb.class
String
Select a proper load balancer type.
  • union: shared load balancer
  • performance: dedicated load balancer, which can be used only in clusters of v1.17 and later.
v1.9 or later
kubernetes.io/ingress.class
String
  • cce: A proprietary LoadBalancer ingress is used.
  • nginx: Nginx Ingress is used.
This parameter is mandatory when an ingress is created by calling the API.
For clusters of v1.23 or later, use the parameter ingressClassName. For details, see Using kubectl to Create a LoadBalancer Ingress.
Only clusters of v1.21 or earlier
kubernetes.io/elb.port
String
This parameter indicates the external port registered with the address of the LoadBalancer Service.
The value ranges from 1 to 65535.
Some ports are high-risk ports and are blocked by default, for example, port 21.
v1.9 or later
kubernetes.io/elb.id
String
Mandatory when an existing load balancer is to be interconnected.
ID of a load balancer.
How to obtain:
On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the target load balancer. On the Summary tab page, find and copy the ID.
v1.9 or later
kubernetes.io/elb.ip
String
Service address of a load balancer. The value can be the public IP address of a public network load balancer or the private IP address of a private network load balancer.
v1.9 or later
kubernetes.io/elb.autocreate
Table 10 Object
Mandatory when load balancers are automatically created.
Example
  • If a public network load balancer will be automatically created, set this parameter to the following value:
    '{"type":"public","bandwidth_name":"cce-bandwidth-1551163379627","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}'
  • If a private network load balancer will be automatically created, set this parameter to the following value:
    {"type":"inner","name":"A-location-d-test"}
v1.9 or later
kubernetes.io/elb.subnet-id
String
Optional when load balancers are automatically created.
ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
  • Mandatory when a cluster of v1.11.7-r0 or earlier is to be automatically created.
  • Optional for clusters later than v1.11.7-r0.
Mandatory for clusters earlier than v1.11.7-r0
Discarded in clusters later than v1.11.7-r0
The following shows how to use the preceding annotations:
Using HTTP/2
Table 2 Annotations of using HTTP/2
Type
kubernetes.io/elb.http2-enable
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves the access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
  • true: enabled
  • false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
For details, see Configuring HTTP/2 for a LoadBalancer Ingress.
Configuring ELB Certificates
Table 3 ELB certificate annotations
Type
kubernetes.io/elb.tls-certificate-ids
String
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained.
To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name.
v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later
For details, see Using the ELB Certificate.
Interconnecting with HTTPS Backend Services
Table 4 Annotations for interconnecting with HTTPS backend services
Type
kubernetes.io/elb.pool-protocol
String
To interconnect with HTTPS backend services, set this parameter to https.
v1.23.8, v1.25.3, or later
For details, see Configuring HTTPS Backend Services for a LoadBalancer Ingress.
Configuring Timeout for an Ingress
Table 5 Annotations of configuring ingress redirection rules
Type
kubernetes.io/elb.keepalive_timeout
String
Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
Value:
  • For TCP listeners, the value ranges from 10 to 4000 (in seconds). The default value is 300.
  • For HTTP or HTTPS listeners, the value ranges from 0 to 4000 (in seconds). The default value is 60.
For UDP listeners, this parameter does not take effect.
Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later
Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
kubernetes.io/elb.client_timeout
String
Timeout for waiting for a request from a client. There are two cases:
  • If the client fails to send a request header to the load balancer during the timeout duration, the request will be interrupted.
  • If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
The value ranges from 1 to 300 (in seconds). The default value is 60.
This parameter is available only for HTTP and HTTPS listeners.
Minimum value: 1
Maximum value: 300
Default value: 60
kubernetes.io/elb.member_timeout
String
Timeout for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
Minimum value: 1
Maximum value: 300
Default value: 60
For details, see Configuring Timeout for a LoadBalancer Ingress.
Adding Resource Tags
Table 6 Annotations
Type
kubernetes.io/elb.tags
String
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created.
A tag is in the format of "key=value". Use commas (,) to separate multiple tags.
v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later
For details, see Creating an Ingress - Automatically Creating a Load Balancer.
Blocklist/Trustlist
Table 7 Annotations for ELB access control
Type
kubernetes.io/elb.acl-id
String
  • If this parameter is not specified, CCE does not modify access control on the ELB.
  • If this parameter is left empty, all IP addresses are allowed to access the load balancer.
  • If this parameter is set to the IP address group ID of the load balancer, access control is enabled and you need to configure an IP address blocklist or trustlist for the load balancer. Additionally, you need to configure both kubernetes.io/elb.acl-status and kubernetes.io/elb.acl-type.
    How to obtain:
    Log in to the console. In the Service List, choose Networking > Elastic Load Balance. On the Network Console, choose Elastic Load Balance > IP Address Groups and copy the ID of the target IP address group.
v1.23.12-r0, v1.25.7-r0, v1.27.4-r0, v1.28.2-r0, or later
String
Access control status. This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
  • on: Access control is enabled.
  • off: Access control is disabled.
String
IP address list type. This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
  • black: indicates a blocklist. The selected IP address group cannot access the load balancer.
  • white: indicates a trustlist. Only the selected IP address group can access the load balancer.
For details, see Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress.
Configuring a Custom Listening Port
A custom listening port can be configured for an ingress. In this way, both ports 80 and 443 can be exposed.
Table 8 Annotations for a custom listening port
Type
kubernetes.io/elb.listen-ports
String
Create multiple listening ports for an ingress. The port number ranges from 1 to 65535.
The following is an example for JSON characters:
kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
  • Only the listening ports that comply with both HTTP and HTTPS are allowed.
  • Only newly created ingresses are allowed. Additionally, after multiple listening ports are configured, annotations cannot be modified or deleted.
  • If both kubernetes.io/elb.listen-ports and kubernetes.io/elb.port are configured, kubernetes.io/elb.listen-ports takes a higher priority.
  • Ingress configuration items such as the blocklist, trustlist, and timeout concurrently take effect on multiple listening ports.
  • Advanced forwarding policies are not supported.
v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later
For example, if an existing ELB is used, the configuration is as follows:
kind: Ingress
  annotations:
    kubernetes.io/elb.id: 2c623150-17bf-45f1-ae6f-384b036f547e     # ID of an existing load balancer
    kubernetes.io/elb.class: performance    # Load balancer type
    kubernetes.io/elb.listen-ports: '[{"HTTP": 80},{"HTTPS": 443}]'    # Multi-listener configuration
    kubernetes.io/elb.tls-certificate-ids: 6cfb43c9de1a41a18478b868e34b0a82,6cfb43c9de1a41a18478b868e34b0a82   # HTTPS certificate configuration
  namespace: default
  ingressClassName: cce
  rules:
  - host: example.com
    http:
      paths:
      - backend:
          service:
            port:
              number: 8888
        path: /
        property:
Configuring a Custom Header Forwarding Policy
Table 9 Annotations for configuring a custom header forwarding policy
Type
kubernetes.io/elb.headers.${svc_name}
String
Custom header of the Service associated with an ingress. ${svc_name} is the Service name.
Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
  • key/value indicates the key-value pair of the custom header. A maximum of eight values can be configured.
    Enter 1 to 40 characters for a key. Only letters, digits, hyphens (-), and underscores (_) are allowed.
    Enter 1 to 128 characters for a value. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
  • Either a custom header or grayscale release can be configured.
  • Enter 1 to 51 characters for ${svc_name}.
v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later
For details, see Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress.
Parameters for Automatically Creating a Load Balancer
Table 10 elb.autocreate data structure
Mandatory
Type
name
No
String
Name of the automatically created load balancer.
The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Default: cce-lb+service.UID
type
No
String
Network type of the load balancer.
  • public: public network load balancer
  • inner: private network load balancer
Default: inner
bandwidth_name
Yes for public network load balancers
String
Bandwidth name. The default value is cce-bandwidth-******.
No
String
Bandwidth mode.
  • bandwidth: billed by bandwidth
  • traffic: billed by traffic
Default: bandwidth
bandwidth_size
Integer
Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
  • The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
  • The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1000 Mbit/s.
  • The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1000 Mbit/s.
bandwidth_sharetype
String
Bandwidth sharing mode.
  • PER: dedicated bandwidth
eip_type
String
EIP type.
  • 5_bgp: dynamic BGP
The specific type varies with regions. For details, see the EIP console.
vip_subnet_cidr_id
No
String
Subnet where a load balancer is located. The subnet must belong to the VPC where the cluster resides.
If this parameter is not specified, the ELB load balancer and the cluster are in the same subnet.
This field can be specified only for clusters of v1.21 or later.
vip_address
No
String
Private IP address of the load balancer. Only IPv4 addresses are supported.
The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block.
This parameter is available only in clusters of v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions.
available_zone
Yes
Array of strings
AZ where the load balancer is located.
This parameter is available only for dedicated load balancers.
l4_flavor_name
Yes
String
Flavor name of the layer-4 load balancer.
l7_flavor_name
No
String
Flavor name of the layer-7 load balancer.
This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, that is, both are elastic specifications or fixed specifications.
elb_virsubnet_ids
No
Array of strings
Subnet where the backend server of the load balancer is located. If this parameter is left blank, the default cluster subnet is used. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block.
Example:
"elb_virsubnet_ids": [
   "14567f27-8ae4-42b8-ae47-9f847a4690dd"
