Help Center/
Cloud Container Engine/
User Guide (Paris Regions)/
Node Pools/
Managing a Node Pool/
Migrating a Node
Migrating a Node
Nodes in a node pool can be migrated to the default node pool. Nodes in the default node pool or a custom node pool cannot be migrated to other custom node pools.
- In the navigation pane, choose Nodes and click the Node Pools tab.
- Click View Node in the Operation column of the node pool to be migrated.
- Click More > Migrate in the Operation column of the target node to migrate the node.
- In the displayed Migrate Node dialog box, confirm the information.
- The migration does not affect custom resource tags, Kubernetes labels, and taints of the node.
- After the migration, system labels cce.cloud.com and cce-nodepool on the node will be deleted. If an existing workload uses these labels for affinity or anti-affinity scheduling, the existing pods on the node will be stopped and rescheduled when kubelet is restarted.
Parent topic: Managing a Node Pool
