Container Engines
Introduction to Container Engines
Container engines, one of the most important components of Kubernetes, manage the lifecycle of images and containers. The kubelet interacts with a container runtime through the Container Runtime Interface (CRI).
CCE supports containerd and Docker. containerd is recommended for its shorter traces, fewer components, higher stability, and less consumption of node resources.
Table 1 Comparison between container engines
Item
containerd
Docker
Tracing
kubelet --> CRI plugin (in the containerd process) --> containerd
  • Docker (Kubernetes v1.23 and earlier versions):
    kubelet --> dockershim (in the kubelet process) --> docker --> containerd
  • Docker (community solution for Kubernetes v1.24 or later):
    kubelet --> cri-dockerd (kubelet uses CRI to connect to cri-dockerd) --> docker--> containerd
Command
crictl/ctr
docker
Kubernetes CRI
Native support
Support through dockershim or cri-dockerd
Pod delayed startup
Minor
High
kubelet CPU/memory usage
Minor
High
Runtime's CPU/memory usage
Minor
High
Common Commands of containerd and Docker
containerd does not support Docker APIs and Docker CLI, but you can run crictl commands to implement similar functions.
Table 2 Image-related commands
Operation
Docker Command
containerd Command
docker
crictl
ctr
List local images.
docker images
crictl images
ctr -n k8s.io i ls
Pull images.
docker pull
crictl pull
ctr -n k8s.io i pull
Push images.
docker push
None
ctr -n k8s.io i push
Delete a local image.
docker rmi
crictl rmi
ctr -n k8s.io i rm
Check images.
docker inspect
crictl inspecti
None
Table 3 Container-related commands
Operation
Docker Command
containerd Command
docker
crictl
ctr
List containers.
docker ps
crictl ps
ctr -n k8s.io c ls
Create a container.
docker create
crictl create
ctr -n k8s.io c create
Start a container.
docker start
crictl start
ctr -n k8s.io run
Stop a container.
docker stop
crictl stop
None
Delete a container.
docker rm
crictl rm
ctr -n k8s.io c del
Connect to a container.
docker attach
crictl attach
None
Access the container.
docker exec
crictl exec
None
Query container details.
docker inspect
crictl inspect
ctr -n k8s.io c info
View container logs.
docker logs
crictl logs
None
Check the resource usage of the container.
docker stats
crictl stats
None
Update container resource limits.
docker update
crictl update
None
Table 4 Pod-related commands
Operation
Docker Command
containerd Command
docker
crictl
ctr
List pods.
None
crictl pods
None
View pod details.
None
crictl inspectp
None
Start a pod.
None
crictl start
None
Run a pod.
None
crictl runp
None
Stop a pod.
None
crictl stopp
None
Delete a pod.
None
crictl rmp
None
Containers created and started by containerd are immediately deleted by kubelet. containerd does not support suspending, resuming, restarting, renaming, and waiting for containers, nor Docker image build, import, export, comparison, push, search, and labeling. containerd does not support file copy. You can log in to the image repository by modifying the configuration file of containerd.
Differences in Tracing
  • containerd:
Although Docker has added functions such as swarm cluster, docker build, and Docker APIs, it also introduces bugs. Compared with containerd, Docker has one more layer of calling. Therefore, containerd is more resource-saving and secure.
