CRDs
Check Items
Check the following items:
  • Check whether the key CRD packageversions.version.cce.io of the cluster is deleted.
  • Check whether the cluster key CRD network-attachment-definitions.k8s.cni.cncf.io is deleted.
Solution
If check results are abnormal, contact technical support.
