On this page
Modifying Cluster Configurations
CCE allows you to manage cluster parameters, through which you can let core components work under your requirements.
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Locate the target cluster, click ... to view more operations on the cluster, and choose Manage.
  3. On the Manage Components page on the right, change the values of the Kubernetes parameters listed in the following table.
    Table 1 kube-apiserver configurations
    Item
    Value
    Toleration time for nodes in NotReady state
    default-not-ready-toleration-seconds
    Specifies the default tolerance time. The configuration takes effect for all pods by default. You can configure different tolerance time for pods. In this case, the tolerance time configured for the pod is used. For details, see Configuring Tolerance Policies.
    If the specified tolerance time is too short, pods may be frequently migrated in scenarios like a network jitter. If the specified tolerance time is too long, services may be interrupted during this period after the node is faulty.
    Default: 300s
    Toleration time for nodes in unreachable state
    default-unreachable-toleration-seconds
    Default: 300s
    Maximum Number of Concurrent Modification API Calls
    max-mutating-requests-inflight
    Maximum number of concurrent mutating requests. When the value of this parameter is exceeded, the server rejects requests.
    The value 0 indicates that there is no limitation on the maximum number of concurrent modification requests. This parameter is related to the cluster scale. You are advised not to change the value.
    Manual configuration is no longer supported since cluster v1.21. The value is automatically specified based on the cluster scale.
    • 200 for clusters with 50 or 200 nodes
    • 500 for clusters with 1000 nodes
    • 1000 for clusters with 2000 nodes
    Maximum Number of Concurrent Non-Modification API Calls
    max-requests-inflight
    Maximum number of concurrent non-mutating requests. When the value of this parameter is exceeded, the server rejects requests.
    The value 0 indicates that there is no limitation on the maximum number of concurrent non-modification requests. This parameter is related to the cluster scale. You are advised not to change the value.
    • 400 for clusters with 50 or 200 nodes
    • 1000 for clusters with 1000 nodes
    • 2000 for clusters with 2000 nodes
    NodePort port range
    service-node-port-range
    NodePort port range. After changing the value, go to the security group page and change the TCP/UDP port range of node security groups 30000 to 32767. Otherwise, ports other than the default port cannot be accessed externally.
    If the port number is smaller than 20106, a conflict may occur between the port and the CCE health check port, which may further lead to unavailable cluster. If the port number is greater than 32767, a conflict may occur between the port and the ports in net.ipv4.ip_local_port_range, which may further affect the network performance.
    Default: 30000 to 32767
    Value range:
    Min > 20105
    Max < 32768
    Request Timeout
    request-timeout
    Default request timeout interval of kube-apiserver. Exercise caution when changing the value of this parameter. Ensure that the changed value is proper to prevent frequent API timeout or other errors.
    This parameter is available only in clusters of v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later versions.
    Default: 1m0s
    Value range:
    Min ≥ 1s
    Max ≤ 1 hour
    ServerSideApply
    feature-gates: ServerSideApply
    Whether to enable ServerSideApply of kube-apiserver. For details, see Server-Side Apply. If this function is enabled, the system stores the resource field management information in metadata.managedFields to record the subject, time, and fields of historical operations.
    This parameter is available only in clusters of v1.19.16-r30 or later patch versions, v1.21.10-r10 or later patch versions, v1.23.8-r10 or later patch versions, and v1.25.3-r10 or later patch versions. This feature is enabled by default for clusters v1.27 or later and cannot be disabled.
    Default: true
    Overload Control
    support-overload
    Cluster overload control. If enabled, concurrent requests are dynamically controlled based on the resource pressure of master nodes to keep them and the cluster available.
    This parameter is available only in clusters of v1.23 or later.
    • false: Overload control is disabled.
    • true: Overload control is enabled.
    Node Restriction Add-on
    enable-admission-plugin-node-restriction
    This add-on allows the Kubelet of a node to operate only the objects of the current node for enhanced isolation in multi-tenant scenarios or the scenarios with high security requirements.
    This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
    Default: true
    Pod Node Selector Add-on
    enable-admission-plugin-pod-node-selector
    This add-on allows cluster administrators to configure the default node selector through namespace annotations. In this way, pods run only on specific nodes and configurations are simplified.
    Default: true
    Pod Toleration Limit Add-on
    enable-admission-plugin-pod-toleration-restriction
    This add-on allows cluster administrators to configure the default value and limits of pod tolerations through namespaces for fine-grained control over pod scheduling and key resource protection.
    Default: false
    API Audience Settings
    api-audiences
    Audiences for a service account token. The Kubernetes component for authenticating service account tokens checks whether the token used in an API request specifies authorized audiences.
    Configuration suggestion: Accurately configure audiences according to the communication needs among cluster services. By doing so, the service account token is used for authentication only between authorized services, which enhances security.
    An incorrect configuration may lead to an authentication communication failure between services or an error during token verification.
    This parameter is available only in clusters of v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions.
    Default value: "https://kubernetes.default.svc.cluster.local"
    Multiple values can be configured, which are separated by commas (,).
    Service Account Token Issuer Identity
    service-account-issuer
    Entity identifier for issuing a service account token, which is the value identified by the iss field in the payload of the service account token.
    Configuration suggestion: Ensure the configured issuer URL can be accessed in the cluster and trusted by the authentication system in the cluster.
    If your specified issuer URL is untrusted or inaccessible, the authentication process based on the service account may fail.
    Table 2 Scheduler configurations
    Item
    Value
    QPS for communicating with kube-apiserver
    kube-api-qps
    QPS for communicating with kube-apiserver.
    • If the number of nodes in a cluster is less than 1000, the default value is 100.
    • If the number of nodes in a cluster is 1000 or more, the default value is 200.
    Burst for communicating with kube-apiserver
    kube-api-burst
    Burst for communicating with kube-apiserver.
    Whether to enable GPU sharing
    enable-gpu-share
    Whether to enable GPU sharing. This parameter is supported only by clusters of v1.23.7-r10, v1.25.3-r0, and later.
    • When disabled, ensure that pods in the cluster cannot use shared GPUs (no cce.io/gpu-decision annotation in pods).
    • When enabled, ensure that there is a cce.io/gpu-decision annotation on all pods that use GPU resources in the cluster.
    Default: true
    Table 3 kube-controller-manager configurations
    Item
    Value
    Number of concurrent processing of deployment
    concurrent-deployment-syncs
    Number of deployment objects that can be synchronized concurrently
    Default: 5
    Concurrent processing number of endpoint
    concurrent-endpoint-syncs
    Number of endpoint syncing operations that will be done concurrently
    Default: 5
    Concurrent number of garbage collector
    concurrent-gc-syncs
    Number of garbage collector workers that can be synchronized concurrently
    Default: 20
    Number of job objects allowed to sync simultaneously
    concurrent-job-syncs
    Number of job objects that can be synchronized concurrently
    Default: 5
    Number of CronJob objects allowed to sync simultaneously
    concurrent-cron-job-syncs
    Number of scheduled jobs that can be synchronized concurrently
    Default: 5
    Number of concurrent processing of namespace
    concurrent-namespace-syncs
    Number of namespace objects that can be synchronized concurrently
    Default: 10
    Concurrent processing number of replicaset
    concurrent-replicaset-syncs
    Number of replica sets that can be synchronized concurrently
    Default: 5
    ResourceQuota
    concurrent-resource-quota-syncs
    Number of resource quotas that can be synchronized concurrently
    Default: 5
    Concurrent processing number of service
    concurrent-service-syncs
    Number of services that can be synchronized concurrently
    Default: 10
    Concurrent processing number of serviceaccount-token
    concurrent-serviceaccount-token-syncs
    Number of service account token objects that can be synchronized concurrently
    Default: 5
    Concurrent processing of ttl-after-finished
    concurrent-ttl-after-finished-syncs
    Number of ttl-after-finished-controller workers that can be synchronized concurrently
    Default: 5
    RC
    concurrent_rc_syncs (used in clusters of v1.19 or earlier)
    concurrent-rc-syncs (used in clusters of v1.21 through v1.25.3-r0)
    Number of replication controllers that can be synchronized concurrently
    This parameter is no longer supported in clusters of v1.25.3-r0 and later versions.
    Default: 5
    HPA
    concurrent-horizontal-pod-autoscaler-syncs
    Number of HPA auto scaling requests that can be concurrently processed
    Default 1 for clusters earlier than v1.27 and 5 for clusters of v1.27 or later
    Value range: 1 to 50
    Cluster elastic computing period
    horizontal-pod-autoscaler-sync-period
    Period for the horizontal pod autoscaler to perform auto scaling on pods. A smaller value will result in a faster auto scaling response and higher CPU load.
    Make sure to configure this parameter properly as a lengthy period can cause the controller to respond slowly, while a short period may overload the cluster management plane.
    Default: 15 seconds
    Horizontal Pod Scaling Tolerance
    horizontal-pod-autoscaler-tolerance
    The configuration determines how quickly HPA will act to auto scaling policies. If the parameter is set to 0, auto scaling will be triggered immediately when the related metrics are met.
    Configuration suggestion: If the service resource usage increases sharply over time, retain a certain tolerance to prevent auto scaling which is beyond expectation in high resource usage scenarios.
    Default: 0.1
    HPA CPU Initialization Period
    horizontal-pod-autoscaler-cpu-initialization-period
    During the period specified by this parameter, the CPU usage data used in HPA calculation is limited to pods that are both ready and have recently had their metrics collected. You can use this parameter to filter out unstable CPU usage data during the early stage of pod startup. This helps prevent incorrect scaling decisions based on momentary peak values.
    Configuration suggestion: If you find that HPA is making incorrect scaling decisions due to CPU usage fluctuations during pod startup, increase the value of this parameter to allow for a buffer period of stable CPU usage.
    Make sure to configure this parameter properly as a small value may trigger unnecessary scaling based on peak CPU usage, while a large value may cause scaling to be delayed.
    Default: 5 minutes
    HPA Initial Readiness Delay
    horizontal-pod-autoscaler-initial-readiness-delay
    After CPU initialization, this period allows HPA to use a less strict criterion for filtering CPU metrics. During this period, HPA will gather data on the CPU usage of the pod for scaling, regardless of any changes in the pod's readiness status. This parameter ensures continuous tracking of CPU usage, even when the pod status changes frequently.
    Configuration suggestion: If the readiness status of pods fluctuates after startup and you want to prevent HPA misjudgment caused by the fluctuation, increase the value of this parameter to allow HPA to gather more comprehensive CPU usage data.
    Configure this parameter properly. If it is set to a small value, an unnecessary scale-out may occur due to CPU data fluctuations when the pod enters the ready state. If it is set to a large value, HPA may not be able to make a quick decision when a rapid response is needed.
    Default: 30s
    kube-api-qps
    kube-api-burst
    The maximum number of terminated pods that can be kept before the Pod GC deletes the terminated pod
    terminated-pod-gc-threshold
    Number of terminated pods that can exist in a cluster. If there are more terminated pods than the expected number in the cluster, the terminated pods that exceed the number will be deleted.
    If this parameter is set to 0, all pods in the terminated state are retained.
    Default: 1000
    Value range: 10 to 12500
    If the cluster version is v1.21.11-r40, v1.23.8-r0, v1.27.3-r0, v1.25.6-r0, or later, the value range is changed to 0 to 100000.
    Unhealthy AZ Threshold
    unhealthy-zone-threshold
    When more than a certain proportion of pods in an AZ are unhealthy, the AZ itself will be considered unhealthy, and scheduling pods to nodes in that AZ will be restricted to limit the impacts of the unhealthy AZ.
    If the parameter is set to a large value, pods in unhealthy AZs will be migrated in a large scale, which may lead to risks such as overloaded clusters.
    Default: 0.55
    Value range: 0 to 1
    Node Eviction Rate
    node-eviction-rate
    This parameter specifies the number of nodes that pods are deleted from per second in a cluster when the AZ is healthy. The default value is 0.1, indicating that pods can be evicted from at most one node every 10 seconds.
    If the parameter is set to a large value, the cluster may be overloaded. Additionally, if too many pods are evicted, they cannot be rescheduled, which will slow down fault recovery.
    Default: 0.1
    Secondary Node Eviction Rate
    secondary-node-eviction-rate
    This parameter specifies the number of nodes that pods are deleted from per second in a cluster when the AZ is unhealthy. The default value is 0.01, indicating that pods can be evicted from at most one node every 100 seconds.
    There is no need to set the parameter to a large value for nodes in an unhealthy AZ, and this configuration may result in overloaded clusters.
    Default: 0.01
    Configure this parameter with node-eviction-rate and set it to one-tenth of node-eviction-rate.
    Large Cluster Threshold
    large-cluster-size-threshold
    If the number of nodes in a cluster is greater than the value of this parameter, this is a large cluster.
    kube-controller-manager automatically adjusts configurations for large clusters to optimize the cluster performance. Therefore, an excessively small threshold for small clusters will deteriorate the cluster performance.
    Default: 50
    For the clusters with a large number of nodes, configure a relatively larger value than the default one for higher performance and faster responses of controllers. Retain the default value for small clusters. Before adjusting the value of this parameter in a production environment, check the impact of the change on cluster performance in a test environment.
    Table 4 Networking component configurations (supported only by the clusters using a VPC network)
    Item
    Value
    Retaining the non-masqueraded CIDR block of the original pod IP address
    nonMasqueradeCIDRs
    In a CCE cluster using the VPC network model, if a container in the cluster needs to access externally, the source pod IP address must be masqueraded as the IP address of the node where the pod resides through SNAT. After the configuration, the node will not SNAT the IP addresses in the CIDR block by default. This function is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
    By default, nodes in a cluster do not perform SNAT on packets destined for 10.0.0.0/8, 172.16.0.0/12, or 192.168.0.0/16 that is detected by CCE as a private CIDR block. Instead, these packets are directly transferred using the upper-layer VPC. (The three CIDR blocks are considered as internal networks in the cluster and are reachable at Layer 3 by default.)
    Default: 10.0.0.0/8, 172.16.0.0/12, or 192.168.0.0/16
    To enable cross-node pod access, the CIDR block of the node where the target pod runs must be added.
    Similarly, to enable cross-ECS pod access in a VPC, the CIDR block of the ECS where the target pod runs must be added.
    Table 5 Extended controller configurations (supported only by clusters of v1.21 and later)
    Item
    Value
    Enable resource quota management
    enable-resource-quota
    Indicates whether to automatically create a ResourceQuota when creating a namespace. With quota management, you can control the number of workloads of each type and the upper limits of resources in a namespace or related dimensions.
    • false: Auto creation is disabled.
    • true: Auto creation is enabled. For details about the resource quota defaults, see Configuring Resource Quotas.
      In high-concurrency scenarios (for example, creating pods in batches), the resource quota management may cause some requests to fail due to conflicts. Do not enable this function unless necessary. To enable this function, ensure that there is a retry mechanism in the request client.
    Default: false
  4. Click OK.
